 Forum index » Instruments and Equipment » Kyma
CapyTalk on Pacarana
Page 1 of 1 [5 Posts]
Acoustic Interloper
Audio files: 79
PostPosted: Wed Jan 26, 2011 7:09 pm    Post subject: CapyTalk on Pacarana
Subject description: My Pacarana arrived
My Pacarana arrived last weekend, got through the sanity check after cleaning up my study for a while (which is now jammed with banjos, guitars and amplifiers because we have guests staying in the spare room where many instruments often live). Its sure says, "Kyma."
Have they put CapyTalk on the Pacarana yet?
Afraid I may not get a lot of time to learn this thing until semester's end in May, but I do have some plans for the little bugger Smile
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Audio files: 340
PostPosted: Wed Jan 26, 2011 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations Dale!! Very Happy Very Happy
Yes you can use CapyTalk expressions and scripts with the Pacarana. Is there anything specific you have in mind? Kyma runs on this just as well as it does on the older Capybara. The only thing to my knowledge that does not run on the Pacarana is third party microsounds, as these have to be rewritten for the new processors in the Paca/rana.
BTW, do we know now what these new processors are?
Muied Lumens Base Star
Acoustic Interloper
Audio files: 79
PostPosted: Wed Jan 26, 2011 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It's exciting. Blessings on the Kutztown University Research Committee. Let us pray
Nothing in mind yet, I just like to get under the hood. Actually, I was writing some Java code to do "lull detection" in real-time audio streams for some grammar-based restructuring of spoken word performances, that I might port as a tutorial to CapyTalk at some point. There has to be some communication between a parser and the audio streamer. Right now they run in Java and ChucK respectively, and communicate using OSC. I reckon I can use Kyma/CapyTalk instead of ChucK for this. There is probably a Kyma component that'll do the lull detection, not sure about the audio subsequence shuffling, though.
Some day I'll have something ready to play, to make sense of that last paragraph!
I've read discussions. Don't remember whether anybody had an answer.
Take care.
Audio files: 340
PostPosted: Thu Jan 27, 2011 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I think I understand what you have in mind. The grammar based shuffling is out of my league for the moment, but you can write audio live to a sample sound (or module if you will) and use amp and/or brightness follower to rearrange words. I have not experimented with this yet but I'm wondering whether a good place to start would be a drum loop remixer sound of some kind.
CapyTalk is not quite as flexible as programing in Java as you can't declare new objects, only use or multiply existing ones as a short cut to programming them graphically. Someone please correct me if I'm wrong.
sitarman
PostPosted: Fri Jan 28, 2011 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
However smalltalk is available in kyma and is a general purpose language.
