Joined: Jan 07, 2009 Posts: 588 Location: Scottish Borders
Audio files: 69
Posted: Sun Jan 30, 2011 7:41 am Post subject:
also at the back there on the AUX FB send/FB return connections i tried a 100K trimmer , set to about 4 or 5K set the feedback kicking in at about 2 o clock on the main feedback pot, are these connections for further proccesing ??.
running the pcb on +/- 12V.
Dave _________________ www.myspace.com/skrogproductions |
Inventor
Joined: Oct 13, 2007 Posts: 5947 Location: San Antonio, Tx, USA
Audio files: 256
Posted: Sun Jan 30, 2011 9:51 am Post subject:
Yes Dave, those feedback connections wore for anyone who wanted to put in a filter or delay or anything really into the feedback loop. I think it was wmonk who wanted that. I added it last minute.
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
Posted: Sun Jan 30, 2011 9:56 am Post subject:
| Inventor wrote: | Yes Dave, those feedback connections wore for anyone who wanted to put in a filter or delay or anything really into the feedback loop. I think it was wmonk who wanted that. I added it last minute.
Les |
do those connections have standard modular levels, or should I add a little circuit there to compensate for that? Can't wait to add a frequency shifter in the loop  _________________ Weblog!
Kits for synthesiser modules in Europe |
Audio files: 69
Posted: Sun Jan 30, 2011 10:11 am Post subject:
Thanks Les, i think i will link them or maybe use a 1K5 res coupling them , gonna try setting the v/oct , before dinner then couple it up to the modular for a bit of KS sounds
Dave. _________________ www.myspace.com/skrogproductions |
Inventor
Audio files: 256
Posted: Mon Jan 31, 2011 3:38 am Post subject:
I'm not sure but I think the levels are 0V to 5V. LOL you would think that I would frickin know how my own board works but I don't recall...
rosch
Posted: Mon Jan 31, 2011 4:59 pm Post subject:
hi Les,
i'd like to build your Boolean Sequencer, could you please point me to the latest schematic?
thank you! |
Joined: Mar 28, 2006 Posts: 1190 Location: Kansas City, Mo USA
Audio files: 27
Posted: Mon Jan 31, 2011 10:05 pm Post subject:
| Inventor wrote: | I'm not sure but I think the levels are 0V to 5V. LOL you would think that I would frickin know how my own board works but I don't recall...
Les |
Yes indeed, and there are clamp diodes as part of the feedback return -- so the circuit is protected against out-of-range voltages. _________________ -- Kevin
http://kevinkissinger.com |
Inventor
Audio files: 256
Posted: Tue Feb 01, 2011 12:36 am Post subject:
| rosch wrote: | hi Les,
thank you! |
rosch, to make a boolean sequencer you can be creative. I don't so much have a schematic as I have a description, and here it is:
Start with an LFO square wave suitable for driving CMOS such as a 555 timer ciricuit. Send that into a CD4040 binary counter to get a 12 bit binary count. Attach any logic you wish to that binary count, including no logic at all. Add a resitive aggregator to the bits. This gives you CV. For KS stim, just add a series 0.1uF capacitor. Aggregator should use resistors in the 100kOhm range.
OK that's a lot to say but it summarizes the design. It's interesting, the history of it, one time in a ChucK software version, I could swear I heard the theme from the old TV show Bonanza. I think the history of this thing goes way back, I just re-inbented it and talked it up on the forum. So to summarize, you need:
LFO => CD4040 => LOGIC => AGGREGATOR => CV => 0.1uF => STIM
That's it.
Audio files: 69
Dan Lavin
Joined: Nov 09, 2006 Posts: 602 Location: Spring Lake, Mi, USA
Audio files: 20
Posted: Sun Feb 13, 2011 7:54 am Post subject:
Skrog:
Very nice!  _________________ Synth DIY since 1977! |
Audio files: 22
Posted: Sun Feb 13, 2011 8:31 am Post subject:
I love this new build. I am blown away as usual. May I ask what jack types, and part numbers, your using?
Is there any reference on how you make your front panel art? I have been wanting to ask.
Keep up the fine work Dave, VERY impressed as always.
Bill |
Inventor
Audio files: 256
Posted: Sun Feb 13, 2011 12:44 pm Post subject:
Looks great Dave, now I'm extra happy I sent you a second board. As you know, you can not only use the second board as a second voice, but you can use it as a resonator for the first board or for other stuff. The fact that you opened up the feedback path only adds to the possibilities. Well done, can't wait to hear some tunes.
Audio files: 69
Posted: Sun Feb 13, 2011 2:08 pm Post subject:
Dan ... Thank you , this was fun to build & fine tune read all the pages of this thread if anyone is starting a fresh pcb , lots of handy info .
Bill , Hey thanks Bill .... the jacks are pvc mono switching ones for all CV's & chrome switching ones for audio (same as the rest of the modular) all from Rapid uk electronics, front panel is a sticker , i designed the layout myself on Corel draw programme then took the panel files on a memory stik to my local sign makers shop ,
White printable adhesive vinyl with lazer printed blue ink design giving the impression of a white print ( white ink is available for his big Roland printer but is very expensive to buy in just for my prints)
so it is an inverted print with blue only outline leaving the clean white underneath.
i could have sprayed with a clear laquer but i have found the prints to be quite robust for home only use .
Les ..... i've been getting some crazy sounds from these , my fave is running the MN3209 KS as a bass line with the MN3208 acting as a sub osc both fed from the same cv input  _________________ www.myspace.com/skrogproductions |
Audio files: 69
Posted: Sun Feb 13, 2011 2:51 pm Post subject:
KS SOUNDS....quite nice
| Here is the dual KS running from a RYK m-185 sequencer i built with me playing along with the Roland TD electronic drum kit (some bad drum timing in there :) heh) all sounds from Dual KS apart from the drum kit sounds |
 Download |
| Filename: |
Karplus Strong dual seq & drums em.mp3 |
4.63 MB |
| Downloaded: |
187 Time(s) |
| Dual KS running from an arpp (midi to cv converted) from my Yamaha RM1X hardware sequencer to the vco cv in , while turning KS dials + lfo to vcf cv in |
 Download |
| Filename: |
KS arpp & twidle em.mp3 |
2.4 MB |
| Downloaded: |
179 Time(s) |
| KS 1 into KS 2 feedback loop both running from the same sequencer cv |
 Download |
| Filename: |
KS 1 into KS2 feedback loop em.mp3 |
1.3 MB |
| Downloaded: |
163 Time(s) |
Audio files: 69
Inventor
Audio files: 256
Posted: Mon Feb 14, 2011 1:34 am Post subject:
I listened to the first one and the last one so far. The first one is very much a conventional "song" music style to me, being what you could make with plain stringed instruments and drums. The second one starts out like a bunch of propeller airplanes flying overhead in formation, then changes to a helicopter, then a UFO, then crazy weird stuff. I love it! I will return to hear the others another time, thanks Dave!
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Tue Feb 15, 2011 12:02 am Post subject:
Dave, great looking modules. Also, great sounding tracks. These modules have great potential.  _________________ --Howard
my music and other stuff |
Peake
Joined: Jun 29, 2007 Posts: 1095 Location: Loss Angeles
Posted: Wed Mar 23, 2011 11:37 am Post subject:
Hi all!
I am a touch confused about the expo "error" described in the thread, regarding pinout for the transistors.
Looking at the parts side of the PCB, with the power connectors at the top, are the transistor pins like this, starting from 9 O'Clock, top trannie far left pin going clockwise: EBCEBC ?
Thanks! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
Peake
Posted: Tue Mar 29, 2011 12:55 pm Post subject:
And by that, I mean was the schematic corrected per the mistake found a few pages back in this thread? _________________ We are selling emotions, there are no emotions in a grid. -mwagener
rosch
Peake
Posted: Wed Mar 30, 2011 10:27 am Post subject:
I tend to see components with all manner of different pinout...of the same type/number. I've seen 2N3904 with entirely different pinout than the ones I got from another store, so a physical representation is good but not "the" solution. I plan to try THAT 340 transistor arrays for a board's two sets of expo trannies. I guess that I have to conclude that the error noted a couple of pages back supercedes the schematic? I'll try that. Thanks, sorry. _________________ We are selling emotions, there are no emotions in a grid. -mwagener
Inventor
Audio files: 256
Posted: Thu Mar 31, 2011 11:52 pm Post subject:
Sorry folks, i've been guess where - the hospital - again! eek! I'm good, they just freaked out over a little high blood pressure but they did figure out that my sleep apnea machine needs recalibration. Anyway i'm sprung free out of jail and I've got high priority other work but soon I will delve into this transistor thing and do an updated schematic or whatever is needed to remedy the problem.
Les
p.s. i'm sorry but my time is divided and i am SO VERY THANKFUL for all those who have carried the torch in my absence. Be back on this soon as i can!!! _________________ "Let's make noise for peace." - Kijjaz |
BobTheDog
Posted: Fri Apr 01, 2011 2:42 am Post subject:
| Good to see you back Les. |
Inventor
Audio files: 256
Posted: Fri Apr 01, 2011 5:38 am Post subject:
thanks Andy, I'm poked, prodded, injected, dejected, and psychologically wrung out but damn does it feel good to get out of that God-forsaken Hell hole of a hospital! four days without a computer or music! Arrrgh!!
Les
p.s. they kept offering me TELEVISION! ew! _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 256
Posted: Fri Apr 01, 2011 5:43 am Post subject:
oh, one note regarding the bjt mixup, it might be me (most likely), it might be a schematic error from the source (unlikely) or it might be an adjustment at the board house (possible but unlikely), but whatever it is you should know this: when you hook a bjt up backwards, what you get is, well, a bad bjt. In other words if you reverse emitter and collector but keep the base connected properly, you just get an out-of-spec, poorly operating bjt but IT WILL STILL WORK OK.
That's why i did testing to a rough degree and didn't really notice. It was good enough for me. But cooler heads prevail and our patient and methodical brethren (especially Kevin) got down to the real cause and stuff. I will get to this and update the schematic as soon as i can.
Les
p.s. in other words, just solder it best you can, it will work if not optimally. _________________ "Let's make noise for peace." - Kijjaz |
