Bogus Noise
Posted: Sun Jan 30, 2011 3:52 pm Post subject:
Bench power supplies |
The time has come for me to pick up a bench power supply for working on circuits and building up modular boards. From a bit of research it seems I'm needing a variable linear power supply with +/- 15v, and somewhere in the region of 3a. Been scanning about on eBay over the weekend, wondering if this one should do the trick?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300514871499&ssPageName=STRK:MESINDXX:IT
Thinking 2a should be plenty. Haven't been able to find out for sure if it's switched or linear though. Any thoughts? |
rosch
Posted: Sun Jan 30, 2011 5:49 pm Post subject:
this seems to be just for +15V, not bipolar |
Bogus Noise
Posted: Sun Jan 30, 2011 5:53 pm Post subject:
Ah, is it?
I thought from looking at the sockets on the front that - GND + meant that it'd be giving a bipolar supply. |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sun Jan 30, 2011 6:31 pm Post subject:
On bench supplies often - (minus) and GND are separate terminals, GND being connected to the case and to the safety ground when connected to mains with a three prong plug, the - and + being floating to that.
Edit : so you could ground + or - or none, as is best for the situation you want to use the supply in. _________________ Jan
Bogus Noise
Posted: Sun Jan 30, 2011 7:05 pm Post subject:
Hmmm, ok then, thanks for the info!
How can I be sure I've found a bipolar power supply? Is there anything else I should be particularly keeping an eye out for? Was hoping to be able to get one for a bit cheaper than the £80+ I've been seeing in the usual online shops. |
Audio files: 278
nerdware
Posted: Mon Jan 31, 2011 12:25 pm Post subject:
I use a Maplin bench PSU. When you use all 3 power rails, it operates as a dual +- supply. _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
Bogus Noise
Posted: Tue Feb 01, 2011 3:00 pm Post subject:
Thanks for the tip and links
Both a bit more than I was planning on spending, though expect something similar to the Maplins one could be found cheaper elsewhere.
Still a bit confused though! The Maplins one doesn't say anything like dual or bipolar, but can be used in that way. Checked the manual and it mentions you can connect the ground to positive or negative, or leave it floating, like the one from the eBay link I posted.
How can I tell the important difference between the Maplins one and the eBay one? It feels like I'm missing something to understanding how to choose the right power supply.
The Maplins one also says switching, but I've been hearing that switching/linear doesn't really matter so much. |
nerdware
Posted: Tue Feb 01, 2011 6:18 pm Post subject:
Yes, the Maplin PSU is smart. However...
I just remembered, the Maplin PSU has limited voltage, so it's not so good if you want a +-15 or +-12 supply. It's great for testing more general, lower voltage circuits, but not so good for modules. It can also add a +5 rail to a +-15 or +-12 supply, but that's not what you asked for. Sorry.
I forgot this because I now use an Oakley Compact PSU for module testing. I've spent more time in the last year messing about with non-bench PSUs. So I'd forgotten the details of this thing. In fact, I had to get both PSUs out just now and test them again to confirm this. I get 15v across the 2 Maplin rails and 30v across the 2 Oakley rails, so I'd say definitely get the Oakley, not the Maplin!
You can buy the CPSU ready made with a Yamaha PA-20 from Krisp1. That's how most of my recent tests have been done, with 2 or 3 modules in isolation from the rest of the synth. It was a literal test bed. _________________ http://soundcloud.com/nerdware/
Bogus Noise
Posted: Tue Feb 01, 2011 6:43 pm Post subject:
Hehehe, cheers for digging them out and testing them!
The voltage issue had been mentioned on the circuitbenders.co.uk forum, so am after a 30v one to get +/-15v. But need to be sure that whichever I go for can act as a bipolar/dual supply. Good to have the voltage side of it clearer in my mind though!
The Oakley one doesn't quite do what I'm after, as I want something adjustable, and be more suitable for putting on a bench.
I will at some point be building power supplies, and already have a board waiting to be drilled and populated, but want the versatility of a bench supply. Also don't think I should be building power supplies until I know a little bit more about them! |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
nerdware
Posted: Wed Feb 02, 2011 1:58 am Post subject:
I bought my CPSU built, so all I had to do was pay for it, but I agree that a variable supply is more versatile and better suited to a lab bench. adambee7's recommendation looks good. _________________ http://soundcloud.com/nerdware/
prgdeltablues
Audio files: 12
Posted: Wed Feb 02, 2011 4:34 am Post subject:
It's probably just me being ignorant, but why would some-one need so much current capacity in a bench supply for synth diy? To test modules I'm building, I just use one of Ray Wilson's wall-wart based dual power supplies using LM317L/337L, built into a little ABS box. Only 100ma capacity, but that's enough for the job. Cost less than £10.
Peter |
nerdware
Posted: Wed Feb 02, 2011 7:35 am Post subject:
Of course, you wouldn't a PA-20 for a bench PSU. I only use that because that's what I have. I bought my CPSU at a time when the PCBs for the Low Noise PSU weren't in stock, so I wanted to use it with a PA-20.
For bench use only, you should ask for a CPSU built for use with a lower current transformer. You won't even need a centre-tapped unit for that, as efficiency won't be an issue.
However, a proper bench dual PSU will be much better suited. I'll probably get a decent one someday, most likely when my CPSU gets installed in a cabinet and used to power parts of my synth. Until then, I'm happy with my bench setup. The only thing missing is an actual bench... _________________ http://soundcloud.com/nerdware/
adambee7
Posted: Wed Feb 02, 2011 11:30 am Post subject:
prgdeltablues wrote: | It's probably just me being ignorant, but why would some-one need so much current capacity in a bench supply for synth diy? To test modules I'm building, I just use one of Ray Wilson's wall-wart based dual power supplies using LM317L/337L, built into a little ABS box. Only 100ma capacity, but that's enough for the job. Cost less than £10.
Peter |
I use a proper supply with 3A because i do other audio stuff aswell and repair work. its handy i can tell you. but if your just building modules, ray's PSU boards are pretty easy and reliable. Add two pots and its adjustable from the front. |
jurekprzezdziecki
Posted: Fri Apr 01, 2016 4:22 am Post subject:
did you ever needed more then one output for building, testing, repair work?
i just consider single output vs double outputs bench power supply.
your advice would help
thanks j |
Posted: Fri Apr 01, 2016 11:00 am Post subject:
Most synthesizer circuits out there use a dual supply -- +15V and -15V for 5U stuff, +12 and -12V for Eurorack.
Old Moog stuff used +12V and -6V. |
jurekprzezdziecki
Posted: Fri Apr 01, 2016 12:28 pm Post subject:
AlanP wrote: | Most synthesizer circuits out there use a dual supply -- +15V and -15V for 5U stuff, +12 and -12V for Eurorack.
As an output I mean one single channel of a certain voltage / current source.
For example TTI PL303 power supply. Sorry for not being precise. |
