VC Master Clock with PWM - PCB run
Page 2 of 4 [95 Posts]
bf
PostPosted: Tue Feb 01, 2011 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Just noticed this.
At lease 2, perhaps up to 6.
PostPosted: Wed Feb 02, 2011 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
deadline for pre-orders is 7th of february. PCBs should be available mid/end of february...
Tech Budday at Random*Source
bf
PostPosted: Wed Feb 02, 2011 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually these might be nice with the VCPS pcbs still in the to do list. Better make that 8.
ach_gott
PostPosted: Wed Feb 02, 2011 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
4 for me, please!
tazer
PostPosted: Wed Feb 02, 2011 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'd like 2 please
cheers
fluxmonkey
PostPosted: Wed Feb 02, 2011 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
three for me, plee(z)
bbob
www.fluxmonkey.com
diablojoy
PostPosted: Wed Feb 02, 2011 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will make that 12 thanks mathias if that's ok Smile
patchdub
PostPosted: Wed Feb 02, 2011 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
can someone discuss the awesomness of having 6-12 of these. starting to feel like i am missing out on something by just asking for one.
www.patchdub.com
PostPosted: Thu Feb 03, 2011 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
why 12?
build 12, sell 11.
build 3 quad units, with master/slave selectors?
12 just give you more options Very Happy
magman
PostPosted: Thu Feb 03, 2011 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias,
I've decided to raise my order to 6 boards.
3 boards should fit behind a 2U MOTM panel quite nicely in Master Clock mode.
Regards
Magman
TekniK
PostPosted: Thu Feb 03, 2011 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
well,you can't never get enough of these imo,but the board is so small,i can't immagine me to hook 4 behind a panel Sad too much hassle.
All the connectors take more room as the circuit on itself
I would have buyed a few if they where quads.
I think i gonna redraw this one ,quad on one pcb.
PostPosted: Thu Feb 03, 2011 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
i understand your concerns and objections. however, the connectors are there to make wiring easier. wrong wiring is a common source for not-working modules, i believe. all the more when the builder is not that experienced...
whomper
PostPosted: Thu Feb 03, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Setting my order to four.
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
monokinetic
PostPosted: Thu Feb 03, 2011 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias, I would like two please.
diablojoy
PostPosted: Thu Feb 03, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
why 12 ?
as mathias said more options Smile I can see many uses and as usual they will all probably end up with some modifications eventually
certainly won't be selling any though
I use a fairly large panel format so lots of room for multiples
and i don't mind wiring up as much as i do drilling lots of panels
so will be a mix of quad and dual panels
brother303
PostPosted: Thu Feb 03, 2011 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
what about wiring up a switch to the clock-out to obtain a start/stop function?
And a little 5V cirquit wired to the same switch (dpst) and an additional jack to start the MFOS 16-step sequencer...
Wink
Best regards
Greg
PostPosted: Thu Feb 03, 2011 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
brother303 wrote:
Hi all,
Wink
Best regards
Greg
why not? an on-off-on switch for the slave modules: self - off - slave, and an on-off switch for the master module: on - off.
i put wirepads and a jumper to the board, so one could decide how to connect the clocks with the comparators.
patchdub
PostPosted: Thu Feb 03, 2011 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok think i wanna bump my order up to four then. seeing as i've got a klee and am in the middle of building the vcps-8 and mfos 16 step. thanks!
www.patchdub.com
Jojjelito
PostPosted: Sun Feb 06, 2011 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Two for me please! These will come in handy...
Cheers!
-J
unterbit
PostPosted: Sun Feb 06, 2011 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I demand 1 consequently.
guitarfool
PostPosted: Sun Feb 06, 2011 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woah, almost missed this one!
I'll take 4
PostPosted: Tue Feb 08, 2011 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
boards ordered now... will take about two weeks from now.
LektroiD
PostPosted: Wed Feb 16, 2011 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like I missed the boat.. If there are any spares, please add me to the list.
LektroiD
tazer
PostPosted: Wed Feb 16, 2011 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll give you one of mine that i ordered rich when they arrive, no worries
ian
LektroiD
PostPosted: Wed Feb 16, 2011 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
ian
That's really kind of you, thank you!
Another build session on the cards methinks Cool
LektroiD
