<on air> PHOBoS presents: There is no show, or is there ?
on board sounds
Page 1 of 1 [8 Posts]
Dimitree
PostPosted: Wed Feb 09, 2011 9:27 am    Post subject: on board sounds Reply with quote  Mark this post and the followings unread
hi everyone
this is my first topic here and I hope I haven't used the wrong section!
I'd like to know how it work a sound module like those used on board of some keyboards (for example M audio KeyStudio 49i). Is that a microcontroller loading recorded samples from a ROM, and playing them with a DAC? is every note recorded, or are them shifted? how about velocity and sustain? it's a compromise of quality-storage (more storege available, more samples, less shift, and so on?)
many thanks everyone
Dimitri
Dan Lavin
Audio files: 20
PostPosted: Thu Feb 10, 2011 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
Welcome to the E-M Forum!
yes, that's basically how they work. They generally have a limited amount of samples and do some stretching to cover in between notes. Velocity can be covered by different samples or an algorithm to change harmonics. If you google "rompler" you'll probably get a better explanation. This technology is 20 years old now (Emu Proteus and soundblasters)
Synth DIY since 1977!
Dimitree
PostPosted: Thu Feb 10, 2011 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
many thanks Smile
is the stretching performed with DSP hardware? or there are other simpler technics? is this different than wavetable synthesis?
Dan Lavin
Audio files: 20
PostPosted: Thu Feb 10, 2011 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure how they stretch, but wavetable synthesis is what it is.
Dimitree
PostPosted: Fri Feb 11, 2011 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
is this something DIY-able (maybe a DSPic with SD card support and good DAC)? I know buying a EMU rack would be cheaper and easier, but the fun would disappear Very Happy
Dan Lavin
Audio files: 20
PostPosted: Fri Feb 11, 2011 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dimitree:
We already did this back in 2007!:
http://electro-music.com/forum/topic-21634.html
Dimitree
PostPosted: Mon Feb 14, 2011 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
many thanks! looks great, I will study it to understand if it fits my needs!
I was wondering, digital pianos like clavinova work like a pure rompler?
how poliphony is achieved in software? mixing the waves of 2 or more files?
I saw that software samplers like Kontakt or Sampletank use 1 sample for each pair of notes (more or less), so there's a minimum amount of stretching, while, if I understood good wavetable synthesis uses just 1 waveform and stretch it for every note. is it right?
egasimus
PostPosted: Tue Feb 15, 2011 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
the very "best" way, if you're going in that direction is to have one or even multiple samples for each note. but that's sampling. wavetable synthesis is a compromise, and the "best" wavetable synthesis is the best compromise you can get between availabe memory, processing power, sample rate, etc. you could use a wavetable synthesizer instead of a VCO - that would let you use non-standard waveforms.
http://elm-chan.org/works/mxb/report.html
check this out, too. built one a year ago, works great.
Custom-built wavetable music box. Behind the mask there's a perfboard with an ATtiny85, a 2032 coin cell, and little else. Note the ingenious amplification solution (metal bell on top of the speaker).
 Filesize:  110.66 KB
 Viewed:  69 Time(s)
Niio2
