WIN7 64 & G1 Nord Modular - Which midi interface is working?
Page 1 of 1 [12 Posts]
dynamixii
PostPosted: Mon Feb 14, 2011 7:01 pm    Post subject: WIN7 64 & G1 Nord Modular - Which midi interface is working?
Subject description: WIN7 64 & G1 Nord Modular - Which midi interface is working?
WIN7 64 & G1 Nord Modular - Which midi interface is working with the editor?
Ive tried the NI DJ8 doesn't work
Sonic Core Midi in and out doesn't work
Thanks for the help
Twisted Evil
dynamixii
PostPosted: Mon Feb 14, 2011 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just figured something out!!!!
I was able to get the usb NI DJ 8 interface to work in win7 64 by
right clicking the editor, going to properties and checking the following:
Run in compatibility for windows2000
Disable windows visual themes
Run this program as an administrator
I was stumped cause 98 mode didnt work neither did xp mode but win2000 seemed to do the trick
dynamixii
PostPosted: Mon Feb 14, 2011 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another note
The browser in the app causes a runtime error
the work around is this:
don't use the internal browser to load patches just open the windows folder that the patches are in and first associate the patches to be opened by the nord modular editor.
To do this right click on one of the patches and go to properties then click the change next to opens with and direct it to eh nord modular editor and tick always use this program to open this file type.
To load a patch from then on just double click the patch
dynamixii
PostPosted: Wed Feb 16, 2011 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
another note:
compatibility for xp sp2 seems to work better the midi connection hasn't dropped yet after close to 4 hours of loading patches
spam4life
PostPosted: Sat Apr 23, 2011 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
i don´t know if this is from any help, but i use an Edirol UM-2EX in Windows XP 64 and is work great.
In the webpage are also drivers for Win7 64.
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=UM-2EX
LFLab
PostPosted: Tue Apr 26, 2011 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I sometimes use a midisport 2x4 under win7, works fine.
rowett
PostPosted: Wed May 25, 2011 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
midisport 2x2 and 4x4 have given me no trouble on windows 7 (xp mode) and xp, both natively and when running in a VM on a mac.
LFLab
PostPosted: Wed Jun 01, 2011 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the meantime, i also bought a g1 keys, which came with a el cheapo chinese usb to midi cable, doesn't always work.
dynamixii
PostPosted: Tue Oct 21, 2014 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks!!!
dynamixii
PostPosted: Fri Nov 14, 2014 1:22 am    Post subject: Update... Its not working in win7 64 anymore ....
Subject description: Update... Its not working in win7 64 anymore ....
Anyone have this working in win7 64? The editor opens fine and can open patches but wont connect via the pc to send the patches over and in the menu where you select the midi you are using to communicate with the pc in and out on the g1 it says "still searching... Sad help//
Audio files: 278
PostPosted: Fri Nov 14, 2014 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Windows 8.1 Here, 64 bits, Edirol UM-3ex .. works .. except that after some time (weeks it seems) the driver will stop working .. when I reboot windows it is fine again.
Never tried it on win-7 though, I had Vista before 8.1.
Silagemaker
PostPosted: Mon Nov 17, 2014 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got a Nord Modular 1.
Works with Motu Fastlane and Motu Midi Express on Windows 7 64 run in compatibility mode no problems.
Also runs on old PPC G5 tiger 4.11 with no problems except the known bugs of not using control click to delete or rename.
Absolutely love the sound and the different modules.
Seriously evaluating everything else in my studio including my Alesis Andromeda!
