What to send from sequencer to make Andy switch to Mix Mode?
Page 1 of 1 [4 Posts]
look37
PostPosted: Wed Nov 03, 2010 2:33 pm    Post subject: What to send from sequencer to make Andy switch to Mix Mode? Reply with quote  Mark this post and the followings unread
Hi guys,
when I load a new project in my sequencer where Andy is used, as long as I stay in the A6's program mode it will switch to the program and bank I previously selected in the sequencer which is quite handy, because like this you don't have to toggle with the A6's buttons any more to make it play what you need Wink
But sometimes you want to use the mix mode in your song, so the question is whether there is any chance with MIDI program/bank select or whatever to switch Andy "remotely" (means initiated from the sequencer) from program into mix mode?
Any ideas?
Regards,
look37
In this world, we all share one and the same god. And everybody actually knows it, just one should always take it, and this world will be peaceful and the greatest thing for mankind.
look37
PostPosted: Wed Nov 03, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
... I forgot to point out when using the term "sequencer" here I mean my software sequencer which is Cubase, and not the A6's built-in one Wink
Shreddie
PostPosted: Mon Nov 08, 2010 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not many synths have that facility so I always just change manually... The Andromeda may be capable of it as it is well specified as far as MIDI controls go but I'm afraid I don't know for sure.
Some synths (usually older ones) actually transmit Sysex when any button/control has been activated so try disabling any filters in your MIDI preferences on Cubase, poke record then press the mix button to see if and midi data is transmitted... If so, you should just be able to copy and paste that into any songs that need it.
RETRIVOX
PostPosted: Wed Mar 16, 2011 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
check this
F0 00 00 0E 1D 0D <mode> F7
/<mode> = 0 = Program mode; 1 = Mix mode/
so you may send this Sysex:
F0 00 00 0E 1D 0D 01 F7
to switch da mix mode on your andy.
