jumunius
Joined: Apr 19, 2010 Posts: 330 Location: San Francisco, CA
Posted: Sun Sep 26, 2010 10:59 am Post subject:
[quote="defex"] | jumunius wrote: | | defex wrote: | | Here is another LVCO |
If i build another one i will make a circuit board for the pots, it would save a lot of time. |
That's funny, I was thinking your solution might be cheaper and easier than pot chiclets. I guess having done it you would disagree. |
magman
Joined: Feb 04, 2009 Posts: 351 Location: Liverpool, UK
Posted: Mon Sep 27, 2010 12:45 am Post subject:
I believe there are two main variants of these BI/TT Tech pots, the P260P and P260T.
The P260P are classed as Side adjust and have the pins designed to mount the pot to a PCB with the shaft in line with the PCB.
The P260T is classed as a Top adjust and have longer pins that are designed to mount the pot to a PCB with the shaft at 90 degrees to the PCB.
Here's a link to a datasheet that may make things a little clearer:
http://www.rapidonline.com/netalogue/specs/68-1175e.pdf
It looks to me that the variant defex has used is the P260T. Most of the P260 series I have seen for sale (and bought from places like Rapid in the UK) are the P260P type. A neat solution to panel wiring though.
Oh, and by the way, for MTA connectors to fit this pin spacing you will need MTA100 connectors, not MTA156 (0.1" compared to 0.156").
I hope that makes things a little clearer.
Regards
Magman |
jumunius
Posted: Mon Sep 27, 2010 10:18 am Post subject:
| magman wrote: | It looks to me that the variant defex has used is the P260T. Most of the P260 series I have seen for sale (and bought from places like Rapid in the UK) are the P260P type. A neat solution to panel wiring though.
Thanks, indeed that does make it clearer. I've looked all over for variations on the P260 and have found the same, that the P260P is the only one generally available. I'm saving up to buy 240 from a US distributor... God knows how many I'd have to buy if I were to order the P260T.
-Jim |
defex
Joined: Jun 27, 2008 Posts: 33 Location: Toronto, canada
Posted: Tue Sep 28, 2010 10:45 am Post subject:
[quote="jumunius"] | defex wrote: | | jumunius wrote: | | defex wrote: | | Here is another LVCO |
I meant creating a whole single sided board for all of the PC mount pots and having just a couple of big headers instead of all those small ones. Just to make it neater. I can do that pretty fast now and the pulsar pro paper + laminator makes it really easy
for smaller projects i will keep doing it this way, it does have the advantage of making it easy to replace a pot if one dies. |
sduck
Posted: Mon Oct 18, 2010 6:11 pm Post subject:
A page back you can see my first Son of Storm Tide Flanger build - but I recently built another one for someone else, and took the opportunity to tweak the panel a little. I moved the pots around, so that the ones I was using the most were all at the top, and added the v/oct tracking knob I completely forgot on the first one.
JoeMorris
Posted: Wed Dec 08, 2010 1:46 pm Post subject:
finally got my triple chorus, krautrock phaser and tau behind a proper labellled panel rather than a cheap piece of anyonymous plastic. never one for being economical, I've let these little beauties stretch their legs amongst no less than 4, yes count 'em 4U of spacious grounds. gave them my own names, as I am often wont to do for a bit of fun. A firm nod is always directed towards Mr Haible whenever their provenance is discussed, however.
L-1
Posted: Fri Dec 17, 2010 8:27 am Post subject:
JH Living VCO's are ready and works! |
I just added mixer. Great design. Recommended for all DIYers.
45.45 KB |
| Viewed: |
138 Time(s) |
71 KB |
| Viewed: |
117 Time(s) |
68.74 KB |
| Viewed: |
107 Time(s) |
L-1
Posted: Fri Dec 17, 2010 8:44 am Post subject:
JH String Filter |
String Filter sounds very good. Thanks Juergen! Will buy other your projects.
59.49 KB |
| Viewed: |
99 Time(s) |
62.79 KB |
| Viewed: |
101 Time(s) |
58.24 KB |
| Viewed: |
104 Time(s) |
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
Posted: Mon Dec 20, 2010 1:20 pm Post subject:
Re: JH Living VCO's are ready and works! |
@L-1 Very nice Living VCO build! I love the mounting bracket. I'm considering something very similar on a large panel I'm building now. |
Luka
zarko
zarko
Posted: Thu Mar 17, 2011 9:22 am Post subject:
The FSH1A FREQ SHIFTER.
1.22 MB |
| Viewed: |
120 Time(s) |
2.06 MB |
| Viewed: |
100 Time(s) |
1.82 MB |
| Viewed: |
108 Time(s) |
zarko
Posted: Thu Mar 17, 2011 9:28 am Post subject:
The Krautrock phaser.
1.21 MB |
| Viewed: |
99 Time(s) |
1.62 MB |
| Viewed: |
94 Time(s) |
zarko
zarko
Posted: Thu Mar 17, 2011 9:36 am Post subject:
.. Last edited by zarko on Thu Mar 17, 2011 9:58 am; edited 2 times in total |
zarko
zarko
sduck
Posted: Thu Mar 17, 2011 9:08 pm Post subject:
| Wow! Great stuff zarko! |
zarko
Posted: Fri Mar 18, 2011 2:41 pm Post subject:
Thanks,your modules are very nice too, and your front panels are clean in comparaison of mine.  |
mph
Posted: Sat Mar 19, 2011 4:14 pm Post subject:
Congrats zarko!
I'd like to see them in your huge white Yusynth. |
zarko
Posted: Mon Mar 21, 2011 11:11 am Post subject:
Merci MPH pas encore comme le yusynth est plein de doit fabriquer un autre meuble
Not yet because i have to build an other cabinet my Yusynth is full  |
Luka
The Bad Producer
Joined: Mar 08, 2009 Posts: 235 Location: The Manhole
The Bad Producer
Posted: Thu Mar 07, 2013 6:11 am Post subject:
Been a while since posting anything here, but here is a Solina Chorus module I finished t'other day. I'm really pleased with the finish on this, something I've been considering for some time and now feel able to show and continue using for all my builds from now on... Now to repanel all the other stuff!
 _________________ http://loudestwarning.tumblr.com/
http://soundcloud.com/thebadproducer |
sonicwarrior
Joined: Dec 22, 2005 Posts: 189 Location: Cologne, Germany
Posted: Fri Apr 12, 2013 10:24 am Post subject:
How could I miss this thread?
Here is my CA3046 Tau Phaser I finished last year.
85.59 KB |
| Viewed: |
12 Time(s) |
82.84 KB |
| Viewed: |
13 Time(s) |
