the architech
Joined: Oct 29, 2010 Posts: 55 Location: Philadelphia
Posted: Wed Nov 03, 2010 11:32 am Post subject:
Loyd, I'm confused. did you use FPD to cut those panels? They look like the stock ones from the site except for the 16-Step Sequencer, which looks like the Thomas White one he showcases. I'm planning out a 16-Step Sequencer myself and have never used FPD before. Interface seems rather clunky. How did you import an illustrator dxf file into it? I emailed them asking if I could import an AutoCAD dxf in, since I have my panel all layed out in that. They told me I had to plot the drill holes via coordinates... |
ashleym
Posted: Wed Nov 03, 2010 2:29 pm Post subject:
Architect,
Yes you do use FPD via co-ordinates. The interface is what it is but it works. I have uploaded a couple of variations to Thomas White's design that he has so kindly shared.
If you have a design, print it out and measure. In FPD you choose where you want to measure from, my designs measure from the bottom left as is normal. Look at my designs for the Ultimate and you will see I have tried to position the pots and sockets on a grid. I made a couple of variations on Ray's layout to work to this grid. I printed out his panel designs and measured the positions and used these as the start points for my layout.
Once you have a grid to work to you can position the holes but directly entering the co-ordinates. For example
horizontal x= 60mm, vertical y= 30mm
next hole is the same height but the next grid slot along, 30mm further along
horizontal x= 90mm, vertical y= 30mm
next
horizontal x= 120mm, vertical y= 30mm etc
Sorry if you understand all this already I was just showing you that FPD isnt so hard to use. |
the architech
Posted: Wed Nov 03, 2010 2:36 pm Post subject:
yeah ok, that's what I suspected. Was hoping there might be an easier way. I measured my layout and printed out an excel spreadsheet. Will try to lay it out tonight and see how it goes. Thanks for the help! |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Posted: Wed Nov 03, 2010 3:04 pm Post subject:
These panels are all stock (MFOS and Bridechamber). The one for my mini-controller was Front Panel Express, and I'll be filling up the 'blank' space in this build with a custom FPE panel as well.
Export your file from Illustrator as a DXF.
In FPD, File -> New
Change the 'Basic Shape' dropdown to DXF. _________________ MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/post-308797.html#308797
MFOS Mini-Controller Build Log [FINISHED!]: http://www.electro-music.com/forum/topic-42968.html |
loydb
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Tue Jan 18, 2011 6:18 am Post subject:
loydb wrote: | the PCB is just sitting here mocking me. |
Yeah - they'll do that. Words have seldom shamed me as much as a stack of half finished PCB's. _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
loydb
Posted: Fri Feb 04, 2011 5:43 pm Post subject:
Ok, I unpacked a bunch of Mouser boxes that had accumulated for the last couple of months and finished adding the hardware to the Ultimate and Expander. I started in on the 16-step, but realized that I'm going to have to do some drilling for the 12-step switch, and stopped.
When I started planning out some mults and 1/4" to banana jacks (I want to keep the 16-step 1/4"), I decided just to stick an MOTM 940 in there. That cuts down on the space I have for other stuff, so I'm probably just going to stick the stereo panner in the blank spot and call it a day.
loydb
RF
Audio files: 28
Posted: Mon Feb 07, 2011 9:32 pm Post subject:
Awesome!
Those resistors were really a pain, weren't they. I hate stuffing resistors.
bruce _________________ www.sdiy.org/rfeng
loydb
Posted: Wed Feb 09, 2011 2:38 pm Post subject:
I like stuffing. It's wiring I hate... Look at all of those damn wires I have to run.
After 30 minutes of searching, I found my thermal adhesive, and stuck the 2k Tempcos onto the SSM2210 chips. One of the first things I did with the PCB was put red ink on the resistor labels that are omitted in favor of Tempcos.
1) Clean the top of the chip and the resistor body with a little bit of iso alcohol.
2) (For Arctic Silver) Mix 1:1 of the two part epoxy. You now have 5 minutes.
3) Hang the edge of the board over the lip of the table.
4) Put a dab of the paste. It's not conductive, but you really don't want to glue the chip into the socket, so be careful.
5) Slide the resistor leads through the holes, reach under the board, and pull the leads down, nestling the resistor into the paste.
6) Bend the leads under the board to hold in place.
7) Put some more paste over the top of the resistor. Don't go crazy.
Let cure. I let it go 24 hours before I solder, even though that's probably overkill.
loydb
loydb
Posted: Thu Feb 10, 2011 12:52 pm Post subject:
Taking into account the reduced panel space, I'm going to have to give up on the 292s, removing the 'hint of Buchla' alluded to in the threat title. I'll be keeping the 4/8-phase shifter and stereo autopan, making this a 100% MFOS build.
The labels are, obviously, not correct, they're just to show spacing.
loydb
ashleym
Posted: Tue Feb 22, 2011 2:09 pm Post subject:
This all looks great.
Did you think of an overdrive or distortion unit? I find a little roughening up of the sound can work a treat on a synth. |
loydb
loydb
Posted: Wed Feb 23, 2011 1:26 pm Post subject:
More PCB madness. Everything is socketed now, except the two big 24-pin chips on the sequencer -- the sockets I got were too narrow, I'll order the right ones when I've got another Mouser order together, or when I'm ready to start wiring, whichever comes first. On the up side, the 100K trimpot I needed to finish the autopan showed up, so it's done now.
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Wed Feb 23, 2011 10:32 pm Post subject:
loyd with the tempco placement I recently changed from doing it similar to way you describe to using sil pins and placing the tempco under the chip
i figured that way the chip can be changed very easily if needed and the tempco is actually in a better position regarding heat transfer being enclosed somewhat by the sil pins and the chip. just a thought for the future
cheers |
jordroid
Joined: Jan 17, 2010 Posts: 193 Location: ithaca, new york
Posted: Sat Feb 26, 2011 5:47 pm Post subject:
I accidentally ended up with narrow 24 pin sockets as well, i chopped them in half and installed them as two rows, it works quite fine if you're in a pinch and not too fussy. Nice projects as well, i like all the photo documentation. Is your mini controller in use yet? That one came out beautifully! |
loydb
Posted: Sun Feb 27, 2011 8:36 am Post subject:
I'm fortunate to have a Mouser close enough that plain old UPS ground == overnight, so I'm just going to wait and get the proper 24-pin sockets whenever I'm ready.
The minicontroller works, but I have nothing really to play it with. I've got an MFOS VCO that I need to calibrate (the impetus behind the whole project) -- it's waiting on my new Protek 6506 oscilloscope to show up on Wednesday.
Interesting idea about burying the tempco. I'd be worried about difficulty of removing the chip if it needed to be replaced (if it's glued to the PCB, that's going to be tricky... _________________ MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/post-308797.html#308797
RF
Audio files: 28
Posted: Sun Feb 27, 2011 7:37 pm Post subject:
loydb wrote: | ... the tempco... |
I just used some regular heat sink compound on top of the IC and pulled the tempco tight on top of it. Tracking and stability are great, and it stays in tune with normal variations in the room temp. _________________ www.sdiy.org/rfeng
loydb
Posted: Sat Mar 05, 2011 6:49 pm Post subject:
Made some good progress on the 8-stage phaser, I just need to solder in the electrolytics, and it will be done. The 16-step shoudn't take too long (it's the wiring that sucks, the PCBs are pretty simple). I'm saving the Expander for last, just because it will be motivational to get 'er done. _________________ MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/post-308797.html#308797
loydb
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Mar 05, 2011 9:33 pm Post subject:
loydb wrote: | Wife on phone with mother == finished phaser. |
_________________ Jan
iopop3
Joined: May 28, 2010 Posts: 94 Location: Malmö, Sweden
Posted: Sun Apr 03, 2011 12:23 pm Post subject:
Any trouble drilling on the panel? I'd really like to use CLB300 led lenses but they are too big and the 3mm variant are too small. so I have to drill..
Why is the hardest part of SDIY the metal drilling?! |
loydb
Posted: Mon Apr 04, 2011 5:07 am Post subject:
For drilling, just clamp it down onto a wood backing board, use a centerpunch to get a small bit centered, drill a pilot hole, then use a stepped bit to get the size you need. If you're enlarging an existing hole, you just need the step bit (all of this is assuming a drillpress).
Oak pollen is so bad right now I'm scared to compound it with working in the shop _________________ MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/post-308797.html#308797
