Symatic Star
Posted: Wed May 04, 2011 1:55 am Post subject:
So this makes me ask the question, what do you use the demo software for ? I have a few ideas but just wondering ?
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed May 04, 2011 2:09 am Post subject:
To Roland it is a vital tool developing his turorials/DvD's. It is included for those who don't own a NordModular G2. It's obvious the author has to check it on the G2 Demo platform too. I just can't help with the problem: Flash...?
Wout |
Symatic Star
Posted: Wed May 04, 2011 2:35 am Post subject:
Thanks for the reply re my question Wout, I did not know Roland did tutorials etc so it was not obvious to me, sounds interesting. Though maybe there still is more uses for the demo software - can you run it along side the full editor on the same computer and have it being used with a midi keyboard? I would not know as I said I never got the demo software running ( had the same message as Roland ) but my full editor for g2 worked straight away.
Symatic |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed May 04, 2011 3:23 am Post subject:
Symatic wrote: | ... Though maybe there still is more uses for the demo software - can you run it along side the full editor on the same computer and have it being used with a midi keyboard? ... | Yes, it can be controlled by a Midi Keyboard. Can be usefull to run together with the hardware loaded with the same Patch, so it will function as a monophonic Delay due to its latency
Wout |
rhombus
Posted: Thu May 05, 2011 11:56 am Post subject:
Yeah I can't get the demo to work on my work laptop at all. It's too bad cuz sometimes I get a thought and want to draw out a patch to save for later. |
dorremifasol
Joined: Sep 28, 2006 Posts: 814 Location: Barcelona, Spain
G2 patch files: 49
Posted: Thu May 05, 2011 11:58 am Post subject:
I'd really pay for a native G2 plugin for PC....
I use the demo a lot in my work to make sound effects for our games. My G2 is at home. _________________ Cheers,
Albert |
Roland Kuit
G2 patch files: 127
Posted: Thu May 05, 2011 3:40 pm Post subject:
Yes, I travel a lot by train with laptop and earphone.. So it is soooo handy. |
Symatic Star
Posted: Wed May 11, 2011 8:33 pm Post subject:
All interesting , I will keep checking this post as I have not solved the demo running challenge either...
rhombus
Posted: Tue May 31, 2011 3:23 pm Post subject:
Workaround for Windows 7 |
I got it working in Windows 7 XP Mode. Get it here:
http://www.microsoft.com/windows/virtual-pc/download.aspx
After it installs, XP Mode will start. It's basically Windows XP in Virtual PC. Once it starts up, install the G2 Demo within it, set up the audio, and try it out.
Close out XP Mode then go to your Windows 7 Start menu, you'll find your G2 Demo program group in Windows Virtual PC\Windows XP Mode Applications. Start it up from here and the application will appear as if it's running within Windows 7. Of course, the first time you start up the demo it'll need to bring XP Mode out of hibernation but at least you don't have to use the demo within a VPC window. Last edited by rhombus on Tue May 31, 2011 4:02 pm; edited 1 time in total |
Audio files: 278
Posted: Tue May 31, 2011 3:47 pm Post subject:
But .. the demo just works in Vista
Well, here it does at least. _________________ Jan
rhombus
Posted: Tue May 31, 2011 3:54 pm Post subject:
OK wait it was Roland that was having the problem in Vista.
It looks like the latest MS Virtual PC is for Windows 7 only so don't bother with that. It's also not worth trying the old VPC 2007 because I'm pretty sure it doesn't virtualize the audio.
For Vista users I'd try out VirtualBox:
http://www.virtualbox.org/
It's free and virtualizes hardware I'm pretty certain. The downsides are needing a copy of XP and also you'll need to run the G2 Demo directly in VirtualBox. Please correct me if you try it out and find that the audio doesn't work properly. |
dorremifasol
G2 patch files: 49
Posted: Wed Jun 01, 2011 1:41 pm Post subject:
Even better than VirtualBox (which I personally use), is VmWare ThinApp.
It encapsulates a single application with all the files needed to run virtually, so there is no need to install all the guest operating system.
http://www.vmware.com/products/thinapp/overview.html
I have not tried it, though. _________________ Cheers,
Albert |
cebec
G2 patch files: 31
Posted: Mon Jul 18, 2011 10:23 am Post subject:
I encountered the same issue / error with a Windows 7 Dell Latitude laptop.
I had to open Control Panel / Sound / Playback and disable the 'Communications Headphones: IDT High Definition Audio CODEC' in order for the G2 Demo to work. It seems as if this might've been holding on to the audio device.
It also works without compatibility mode enabled.
Maybe this will help someone or lead them in the right direction... _________________ http://www.soundcloud.com/cebec |
Roland Kuit
G2 patch files: 127
Posted: Wed Jul 27, 2011 8:24 am Post subject:
G2Demo is working again. Because the new motherboard and the notification about memory, I was lost. Today I thought lets update my driverstuff. And that worked. Thanks all for your help. |
dorremifasol
G2 patch files: 49
Posted: Wed Jul 27, 2011 8:34 am Post subject:
That's very nice, I'm glad you sorted out the problem _________________ Cheers,
Albert |
Roland Kuit
G2 patch files: 127
Posted: Thu Jul 28, 2011 3:04 am Post subject:
Thanks. The Demo is so handy in teaching mod synthesis and fun in the train. Wish they would make it a vst too. |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Fri Dec 26, 2014 11:53 pm Post subject:
cebec wrote: | I encountered the same issue / error with a Windows 7 Dell Latitude laptop.
I had to open Control Panel / Sound / Playback and disable the 'Communications Headphones: IDT High Definition Audio CODEC' in order for the G2 Demo to work... |
I got the “not enough memory to perform requested action” error after installing the G2 Demo on the same model laptop and OS. After searching this forum and finding this suggestion, I tried it and now the Demo is up and running.
Thanks for the tip cebec _________________ varice |
cebec
G2 patch files: 31
Posted: Sat Dec 27, 2014 7:02 pm Post subject:
varice wrote: | cebec wrote: | I encountered the same issue / error with a Windows 7 Dell Latitude laptop.
Thanks for the tip cebec |
You're welcome. Glad to hear it! _________________ http://www.soundcloud.com/cebec |
sitarman
Joined: Jul 08, 2007 Posts: 20 Location: New Lenox Il.
Posted: Thu Jan 01, 2015 12:01 pm Post subject:
Yes...
Once I selected the proper output I could then re-enable the other codecs and the demo continued working. |
varice
Audio files: 29
G2 patch files: 54
Posted: Tue Jan 06, 2015 10:55 am Post subject:
sitarman wrote: | Yes...
I just tried enabling the CODEC. The G2 Demo starts and still runs, but when I go to Setup, Audio/MIDI, the same error pops up and the settings cannot be changed. So the G2 Demo and the CODEC still aren’t 100% playing nice together. But at least I know now what to do to get the G2 Demo able to change settings if need be. _________________ varice |
