How to quickly reset a patch to stored value...
Page 1 of 1 [6 Posts]
goldphinga
PostPosted: Wed May 04, 2011 10:27 am    Post subject: How to quickly reset a patch to stored value... Reply with quote  Mark this post and the followings unread
Hey guys, me again!
Say you have changed the filter cutoff on a bass patch whilst performing, how do you reset the changed filter cutoff value to the stored value on the fly? Is there a way to do this?
Dan g
SynthasaurusRex
PostPosted: Sat May 07, 2011 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Press PROGRAM, up arrow, down arrow. (or down arrow, up arrow Smile ) In other words, you change to another patch, then back; the original values are all restored.
Stephen
goldphinga
PostPosted: Sun May 08, 2011 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers. But youre missing my point. Of course if u change patch and back it resets the sound. I'm talking about in mid performance, say u change the filter cutoff how do you put it back to the stored value? Can't be changing patches! Some boards allow u to press enter to reset to stored values but as there is no enter button I wonder how it's done on the a6.
sunny pedaal
Audio files: 12
PostPosted: Sun May 08, 2011 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
like syntasaurus descibes, just imagine the up-down arrows to be 1/2 reset buttons
SynthasaurusRex
PostPosted: Sun May 08, 2011 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right Goldphinga, the method I mentioned will clear everything that's been changed, not just one parameter.
As far as I know, there is no simple way to do this on the Andromeda, and it's a pity too, but that's the way it is. The only real method I know of is to look at the parameter before you change it, then try to set it back to that value, definitely not suited for live performance I'm afraid.
Stephen
CoolColJ
PostPosted: Mon May 16, 2011 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a compare button though....
Press it to listen to the original and show original values, press it again to revert back
Niio2
