Chaining MIDI patch bays together
Page 1 of 1 [4 Posts]
nobody
PostPosted: Mon May 16, 2011 6:37 am    Post subject: Chaining MIDI patch bays together
Subject description: Does it work?
I was wondering what would happen if I connect the MIDI out of patch bay A to the MIDI in of patch bay B, with A connected to my computer but B is not. Will I see B as a MIDI device with only port 1 available (the first 16 channels) or will I see multiple MIDI devices and get all 8 ports of B?
Of course, I should just try it, but I was wondering if anyone's already done this.
EdisonRex
Audio files: 168
PostPosted: Mon May 16, 2011 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
It depends on a lot of factors, but the answer is that although cascading MIDI patchbays works, you probably won't see the downstream cascaded unit as most MIDI patchbays don't have any way to respond to midi messages. And this is operating system dependent too. In short, it's a lot of aggravation when there might be better ways to achieve the same end.
More specifics will get a more refined conjecture.
I stopped cascading midi patchbays about 20 years ago. I currently have a 8in/8out MOTU patchbay which gives me 16 channels per hose, and I chain equipment that don't need a lot of channels (analogs, the Nords, etc).
Garret: It's so retro.
nobody
PostPosted: Mon May 16, 2011 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have an AMT8 and a MOTU MIDI Express XT. The XT doesn't have a Linux driver, so I figured...
I could chain my less-than-16-channel devices, but when I run out of room doing that, I'm hoping to make use of existing hardware before buying more.
Also, major geek factor involved. Razz
pyrosonic
PostPosted: Mon May 16, 2011 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not gonna work,sorry.What you'd get,if anything is the first option which would make the 2nd "patch bay" irrelevant.
BTW:Those aren't patch bays they're interfaces.If device B actually were a patch bay and was programmable like say,the Digital Music Corp MX-8,it would at least function like a splitter to give you multiple outs without the latency you'd get by daisy chaining,but the MOTU wouldn't even give you that.And you wouldn't be able to address specific ports on it either way.You're gonna have to bite the bullet and buy a 2nd interface that has the drivers you need available or live with daisy chaining.
http://soundcloud.com/pyrosonic-1
https://www.facebook.com/pages/Pyrosonic/106761076017889
https://www.facebook.com/pages/Whorlweaver/133469163426410
http://www.youtube.com/user/pyrosonic
http://www.myspace.com/pyrosonicmusic
