Q - Andromeda knob spare part model
Page 1 of 1 [14 Posts]
yoshimodular
PostPosted: Mon May 23, 2011 2:27 am    Post subject: Q - Andromeda knob spare part model Reply with quote  Mark this post and the followings unread
This is my first post here, so hello all!
I'm a long time A6 user and lover, but my Andy is having some issues with the pots. The guy who repairs my stuff (a really number one) restored all the pots but one of them is damaged. He also told me that the build quality is very low.
The question is:
Does anyone know the brand and model of any spare part?
The knob is not branded, so I can't find any spare over the net BUT the one at http://www.instrumentalparts.com/ala6ansppa.html that it's astronomical expensive for a pot (11$ + shipping), when it should be something like 2$ and I'd like having a stock of them.
Thanks for your help!
Regards,
sunny pedaal
Audio files: 12
PostPosted: Mon May 23, 2011 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
isn't there more info in the service manual ? ( in the tips and tricks link somewhere on the end : http://electro-music.com/forum/download.php?id=24140 )
otherwise he could have measured the pot ?
CoolColJ
PostPosted: Sat May 28, 2011 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
edit - whoops Smile
Mike peake might know?
yoshimodular
PostPosted: Wed Jun 01, 2011 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
Thanks for answering. I'll give a look to that manual (I had the BOM). Measuring is not enough, due I need to know the shape of the knob (for the cup) and the legs positioning.
Who is Mike peake?
Regards.
CoolColJ
PostPosted: Wed Jun 01, 2011 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Someone here
He is one of the devs of the A6 Smile
yoshimodular
PostPosted: Wed Jun 01, 2011 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
sunny pedaal
Audio files: 12
PostPosted: Fri Jun 03, 2011 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd simply buy a few of the above mentioned "highly expensive" pots ( i think there are 2 or 3 different types mostly used: small/ big / audiostereo (1 for the mainout ) ), just a couple of all types,
also a few spare pushbuttons.
buy them all at once, thereby spare on future "extensive" shippingcosts.
and for ? 60 euro or less you'll have created a sparepackage for future use for your favorite analogsynth , which once costed 5000+
not a bad deal i guess and giving a lot of mindpeace in future too
yoshimodular
PostPosted: Fri Jun 03, 2011 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you're right if you don't have to change a bunch of them. I think that the pots are expensive for buying 70, not for one or two. I'll keep looking for the reference and I'll let you know. I think it's a ver valuable info for all A6 users.
Regards.
sunny pedaal
Audio files: 12
PostPosted: Fri Jun 03, 2011 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
you're right about that too.
probably the pots are commonly used in lots of other machines too.
in which and or what type exactly indeed is the question.
Peake
PostPosted: Thu Jun 09, 2011 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
The designers who selected the pots did so regarding a price/performance ratio, and found the best possible combination. Remember that when producing a product like this, it is sometimes necessary to have a lot of items in stock and that can become pricey. IIRC the next-best pot was significantly more expensive than the one chosen.
I never knew the brand or number of said potentiometers.
If you have a problem with multiple pots going wrong, try the power-up calibration routine, which includes all of the controllers/ribbon/wheels etc. You'll have to find online the procedure, or find it in the manual; it will be listed along with the hard and soft reset procedures.
yoshimodular
PostPosted: Thu Jun 09, 2011 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Peak. I've solved some problems with that (one day I always had random autotune problems in 3 OSC until I did it). Cleaning the pots deeply solved part of the issues. Anyway, I'll try to find them out.
CoolColJ
PostPosted: Sat Jun 11, 2011 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Mike, I have a question while your here
is the Sram card in the A6 capable of being hot swapped?
Peake
PostPosted: Thu Jun 16, 2011 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember. It's been several years since I've had hands-on time with an Andromeda. What does the group say?
CoolColJ
PostPosted: Thu Jun 16, 2011 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Someone said it's fine, he's done it many times Smile
