Summer Solstice 2011 Streaming Concert
Page 5 of 5 [121 Posts]
Goto page: Previous 1, 2, 3, 4, 5
Audio files: 705
PostPosted: Sun Jun 19, 2011 10:02 am    Post subject: Re: here is my set
Subject description: my two DIY boxes of synths
Ganzha wrote:
here my synts that I use for Summer concert only
your set was played later on. (I think it was instead of Allen Goodman)
I liked it Smile will check the videos later.
PostPosted: Sun Jun 19, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
audiodef wrote:
Antimon wrote:
featuring some Octatrack sequences that I had pieced together the past couple of weeks, some Nord Modular G2 fast sequences, a lot of plain PEK playing, some Origin pigh-pitched things that was MIDI-routed through ChucK, some VG99 and some plain old geetar.
Dude, you should totally be a guest on Programmed Hell some time. I think it would be a neat mix. compress shakng2 thumright
Cheers Damien. Smile That could be fun!
/Stefan
electro-nyc
PostPosted: Sun Jun 19, 2011 1:05 pm    Post subject: redgreenblue live at FiGMENT
Subject description: It may not have been the SS2011, but is is what I probably would have played
I played at FiGMENT, it was a great show and I debuted the live version of Synaesthetic 2.
All rights reserved, enjoy!
btw, my new album, Synaesthetic, is available for streaming at
http://soundcloud.com/redgreenblue/sets/synaesthetic-1/
and for download at
http://redgreenblue.bandcamp.com/
redgreenbluefigment.zip
 Filename:  redgreenbluefigment.zip
 Filesize:  70.52 MB
 Downloaded:  721 Time(s)
wmonk
Audio files: 15
PostPosted: Sun Jun 19, 2011 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's mine Smile
Things did go well until minute 21. In the last part some stuff didn't get into the recording and not into the stream.
Enjoyed listening to all sets. Thanks a lot Shane for organising this!
Woody
20110618-summersolstice2011-woodymonk.mp3
Woody Monk Summer Solstice 2011 performance - Fresh Trout and BBQ Smokes.
 Filename:  20110618-summersolstice2011-woodymonk.mp3
 Filesize:  27.64 MB
 Downloaded:  5648 Time(s)
Weblog!
Symatic Star
PostPosted: Sun Jun 19, 2011 10:50 pm    Post subject:
Subject description: volume - loudness
Hi, I am wondering about volume - loudness of my recording, I am happy with the sound quality, my recording does seem quieter than other peoples sessions, maybe because I use no compression? Listeners can always reach for the volume control button ( or maybe I should slightly boost the master volume without compression? )... Just some thoughts/questions.
PostPosted: Mon Jun 20, 2011 4:30 am    Post subject:
I'd say, yes it is a bit quieter. This is better than digital distortion from being too loud. As for future files, if you have a wave editor, I'd simply normalize them. As I understand it, normalize looks at the peak amplitudes, sets the top to whatever setting you choose, and then adjusts the levels of the entire file. As I understand compression, you can process levels differently--i.e., lower loudness and raise softness (pardon the over simplification--perhaps others can elaborate).
To me your set doesn't seem to have a problem with having too wide a range for which compression might be helpful. I'd suggest normalization should do it. (Get others' opinions, too.)
For performance time, better to be a little to soft than have digital distortion--but that's just my opinion.
Steve
1:11
Audio files: 109
PostPosted: Mon Jun 20, 2011 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's our ear-bleeding set. Confused
BIG THANK YOU to everyone who makes electro-music.com and its events possible. Pretty dang cool!!
About this set:
First time performing as a Quartet. (Scott K, 1:11, Mate0, Dante)
We went a "Summer" theme: Water, Surf Guitar, Fireworks, melted plastic, ect.
Some silence at the beginning, and an early fade out at the end.
Video of the performance is posted here: http://www.myspace.com/acid-trash
Solstice Show '11.mp3
 Filename:  Solstice Show '11.mp3
 Filesize:  26.42 MB
 Downloaded:  5544 Time(s)
Symatic Star
PostPosted: Tue Jun 21, 2011 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Steve ! Thanks for the feedback about "volume etc" that I was wondering about. Yes I agree much better a wee quiet than distorting from loudness.
Will look into which programmes I have that may help with normalization of loudness as you call it. I am into keeping as much dynamic range as possible so have so far avoided all compression. As well as all sharing music with each other here, new friendships etc another great aspect is this learning from each other especially with tech stuff like this question. Loving e-m Smile
This was a lot of fun to do my first official e-m show, and I was very happy with my performance and loved all the other players music and sounds , such a diversity - GREAT!
Audio files: 277
PostPosted: Tue Jun 21, 2011 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Normalization of loudness seems to involve compression, what Steve mentioned is usually called volume normzlization I think. Anyway, audacity can do the latter. I usually try to keep some headroom too, and then before I post a track I do a volume normalization to -0.1 dB - sometimes I'll shave off a couple of peaks before that.
zreentoyz
PostPosted: Tue Jun 21, 2011 4:55 am    Post subject: Symatic > volume - loudness
@ Symatic
I use this technique : low‑threshold, low‑ratio compressor followed by a good limiter > see article :
http://www.soundonsound.com/sos/jan11/articles/qanda-0111-1.htm
Symatic Star
PostPosted: Tue Jun 21, 2011 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
zreentoyz wrote:
@ Symatic
Thanks Zreentoyz I did give this a play and it certainly is louder overall, it does seem like a real artform to retain as much dynamic range as possible and to some degree still keep up with the loudness levels people are now used to.
Jan that sounds very similar to what I just did with this article also thanks for your reply, and thanks Steve Very Happy
nobody
PostPosted: Tue Jun 21, 2011 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
1:11
Audio files: 109
PostPosted: Tue Jun 21, 2011 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
i would LOVE to hear that!! Is it possible for you guys to play at the same time?
Lots of awesome sets here...spendin the day goin through em all. Looks like a good day Very Happy
nobody
PostPosted: Tue Jun 21, 2011 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and it's done around here frequently. Very Happy
Ganzha
Audio files: 27
PostPosted: Tue Jun 21, 2011 5:54 pm    Post subject: my set in video
Subject description: comparisons
Hi!
I have check sound in video and did compare with sound from digital recorder (recorded from mixer main outut) the sound from camcorder is much better! I need to upload here a new version - or just use compressor to improove previously downloaded sound from streaming set!
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Tue Jun 21, 2011 7:03 pm    Post subject: compressed set Reply with quote  Mark this post and the followings unread
this is my set after compression (output from mixer)
18-06-2011_gazna_comp.MP3
 Filename:  18-06-2011_gazna_comp.MP3
 Filesize:  44.98 MB
 Downloaded:  5521 Time(s)
http://ziart.kz
Symatic Star
PostPosted: Wed Jun 22, 2011 1:38 am    Post subject: loudness
Subject description: adjusted
Yes I also found my set on the quiet side, so have boosted the loudness in the way shared by Zreentoys from the SOS website
Thankyou to all the downloaders of the first file, I think it's fine if you are happy to reach for the volume knob, but I think this one will sit better in a playlist with the rest of the files as it is a bit louder.
Symatic Star -Beyond the Heliosphere -Live Improv e-m SS 2011.mp3
Copyright © 2011 by Symatic-Star. CC BY NC ND . Permission is granted for playing on radio.electro-music.com , and downloading for personal listening, Please Enjoy!
 Filename:  Symatic Star -Beyond the Heliosphere -Live Improv e-m SS 2011.mp3
 Filesize:  56.31 MB
 Downloaded:  5370 Time(s)
Audio files: 277
PostPosted: Wed Jun 22, 2011 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
For a recording of the performance by dRachEmUsiK and urbster1 see : http://electro-music.com/forum/post-333538.html
Pehr
PostPosted: Fri Aug 19, 2011 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there going to be an autumn live event?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Fri Aug 19, 2011 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I sure hope so! Smile
shanemorris
Audio files: 92
PostPosted: Fri Aug 19, 2011 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Pehr
Likely we will be, though sign up has not started. The likely day will be Sept 24 on Saturday.
Thanks for the reminder
ElectroCasa
