Audio files: 254
Posted: Sun Jun 19, 2011 10:02 am Post subject:
Re: here is my set Subject description: my two DIY boxes of synths |
| Ganzha wrote: | | here my synts that I use for Summer concert only |
your set was played later on. (I think it was instead of Allen Goodman)
I liked it will check the videos later. _________________ "My perf, it's full of holes!"
http://www.acidtrash.com/ |
Audio files: 211
G2 patch files: 92
Posted: Sun Jun 19, 2011 10:13 am Post subject:
| audiodef wrote: | | Antimon wrote: | featuring some Octatrack sequences that I had pieced together the past couple of weeks, some Nord Modular G2 fast sequences, a lot of plain PEK playing, some Origin pigh-pitched things that was MIDI-routed through ChucK, some VG99 and some plain old geetar.
Dude, you should totally be a guest on Programmed Hell some time. I think it would be a neat mix.  |
Cheers Damien. That could be fun!
@soundcloud @Flattr @myspace A blog home - you can't explain music |
electro-nyc
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
Symatic Star
Posted: Sun Jun 19, 2011 10:50 pm Post subject:
Subject description: volume - loudness |
| Hi, I am wondering about volume - loudness of my recording, I am happy with the sound quality, my recording does seem quieter than other peoples sessions, maybe because I use no compression? Listeners can always reach for the volume control button ( or maybe I should slightly boost the master volume without compression? )... Just some thoughts/questions. |
Joined: Aug 08, 2009 Posts: 548 Location: Upstate New York USA
Audio files: 151
Posted: Mon Jun 20, 2011 4:30 am Post subject:
| Symatic wrote: | | Hi, I am wondering about volume - loudness of my recording, I am happy with the sound quality, my recording does seem quieter than other peoples sessions, maybe because I use no compression? Listeners can always reach for the volume control button ( or maybe I should slightly boost the master volume without compression? )... Just some thoughts/questions. |
I'd say, yes it is a bit quieter. This is better than digital distortion from being too loud. As for future files, if you have a wave editor, I'd simply normalize them. As I understand it, normalize looks at the peak amplitudes, sets the top to whatever setting you choose, and then adjusts the levels of the entire file. As I understand compression, you can process levels differently--i.e., lower loudness and raise softness (pardon the over simplification--perhaps others can elaborate).
To me your set doesn't seem to have a problem with having too wide a range for which compression might be helpful. I'd suggest normalization should do it. (Get others' opinions, too.)
For performance time, better to be a little to soft than have digital distortion--but that's just my opinion.
Steve |
Audio files: 100
Posted: Mon Jun 20, 2011 11:47 am Post subject:
Here's our ear-bleeding set.
BIG THANK YOU to everyone who makes electro-music.com and its events possible. Pretty dang cool!!
About this set:
First time performing as a Quartet. (Scott K, 1:11, Mate0, Dante)
We went a "Summer" theme: Water, Surf Guitar, Fireworks, melted plastic, ect.
Some silence at the beginning, and an early fade out at the end.
Video of the performance is posted here: http://www.myspace.com/acid-trash
| Description: |
 Download |
| Filename: |
Solstice Show '11.mp3 |
| Filesize: |
26.42 MB |
| Downloaded: |
350 Time(s) |
Symatic Star
Posted: Tue Jun 21, 2011 3:19 am Post subject:
Hi Steve ! Thanks for the feedback about "volume etc" that I was wondering about. Yes I agree much better a wee quiet than distorting from loudness.
Will look into which programmes I have that may help with normalization of loudness as you call it. I am into keeping as much dynamic range as possible so have so far avoided all compression. As well as all sharing music with each other here, new friendships etc another great aspect is this learning from each other especially with tech stuff like this question. Loving e-m
This was a lot of fun to do my first official e-m show, and I was very happy with my performance and loved all the other players music and sounds , such a diversity - GREAT! |
Joined: Apr 03, 2004 Posts: 19582 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Tue Jun 21, 2011 4:37 am Post subject:
| Symatic wrote: | | normalization of loudness |
Normalization of loudness seems to involve compression, what Steve mentioned is usually called volume normzlization I think. Anyway, audacity can do the latter. I usually try to keep some headroom too, and then before I post a track I do a volume normalization to -0.1 dB - sometimes I'll shave off a couple of peaks before that. _________________ Jan |
zreentoyz
Symatic Star
Posted: Tue Jun 21, 2011 10:16 am Post subject:
| Blue Hell wrote: | | Symatic wrote: | | normalization of loudness |
Normalization of loudness seems to involve compression, what Steve mentioned is usually called volume normzlization I think. Anyway, audacity can do the latter. I usually try to keep some headroom too, and then before I post a track I do a volume normalization to -0.1 dB - sometimes I'll shave off a couple of peaks before that. |
Thanks Zreentoyz I did give this a play and it certainly is louder overall, it does seem like a real artform to retain as much dynamic range as possible and to some degree still keep up with the loudness levels people are now used to.
Jan that sounds very similar to what I just did with this article also thanks for your reply, and thanks Steve  |
nobody
Posted: Tue Jun 21, 2011 11:04 am Post subject:
Audio files: 100
Posted: Tue Jun 21, 2011 12:21 pm Post subject:
| Antimon wrote: | | audiodef wrote: | | Antimon wrote: | featuring some Octatrack sequences that I had pieced together the past couple of weeks, some Nord Modular G2 fast sequences, a lot of plain PEK playing, some Origin pigh-pitched things that was MIDI-routed through ChucK, some VG99 and some plain old geetar.
/Stefan |
i would LOVE to hear that!! Is it possible for you guys to play at the same time?
Lots of awesome sets here...spendin the day goin through em all. Looks like a good day  |
nobody
Posted: Tue Jun 21, 2011 12:22 pm Post subject:
| 1:11 wrote: |
Yes, and it's done around here frequently.  |
Ganzha
Posted: Tue Jun 21, 2011 5:54 pm Post subject:
my set in video Subject description: comparisons |
Hi!
I have check sound in video and did compare with sound from digital recorder (recorded from mixer main outut) the sound from camcorder is much better! I need to upload here a new version - or just use compressor to improove previously downloaded sound from streaming set! _________________ http://ziart.kz
http://www.livestream.com/ziart |
Ganzha
Symatic Star
Audio files: 116
G2 patch files: 317
Pehr
Joined: Aug 14, 2005 Posts: 1306 Location: Björkvik, Sweden
Audio files: 211
G2 patch files: 92
shanemorris
Audio files: 83
Posted: Fri Aug 19, 2011 6:50 am Post subject:
Hi Pehr
Likely we will be, though sign up has not started. The likely day will be Sept 24 on Saturday.
Thanks for the reminder _________________ ElectroCasa |
