Post Your KLEE Panels Designs Here
Page 16 of 16 [393 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16
mig27
PostPosted: Wed Jun 29, 2011 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I was actually talking knob lever length, not taper length (or did I miss your irony?)
Anyhow, in the mean time I figured that 19mm should be the way to go.
Audio files: 22
PostPosted: Sat Jul 02, 2011 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was just me being a goofball. lol ..... Laughing Seriously, sounds like a good choice. Wink
Bill
citric acid
PostPosted: Wed Oct 05, 2011 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
i still have a 2nd set of klee2 PCBs in the drawer and i toy with the idea of building myself a eurorack module from it despite my backlog)! currently i shrunk it to 60HP using pushbuttons with built in LEDs (as seen on my LPG with gate controlled mode). i would replace the manual range selection switch by a voltage controlled switch.
what do you think? ideas?
cool idea... nice and small not so big . im still looking for a smal one.
do you share this files ? if not i understand ...but if you like it will be fine .
br
http://soundcloud.com/citric-acid-303
brother303
PostPosted: Thu Oct 06, 2011 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Cit,
br
Yes,nice panel,isn`t it?
But you have to build a midi-interface and the voltage controlled range-switch by yourself since there are no out-of-the-box solutions available...
Wink
Best regards
Greg
el-bee
PostPosted: Fri Oct 21, 2011 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I'm planning..:
At the moment, my plan is to make a rack unit with detachable rack ears to allow desktop use too.
If you feel like reading more about my Klee build as it happens, check what this has to offer Smile
Captain Biscuits
PostPosted: Tue Nov 15, 2011 2:58 pm    Post subject: Another Day; Another Panel Reply with quote  Mark this post and the followings unread
I've been gradually knocking this into shape for a little while now, on and off, so have reached the point that I don't think I'm capable of noticing even the most glaring errors!
Any advice from those who have been there gratefully received.
Many thanks
Ian
 Filesize:  190.94 KB
 Viewed:  251 Time(s)
EdisonRex
Audio files: 168
PostPosted: Tue Nov 15, 2011 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
From a human factors point of view, the two buttons manual load and manual step need to be somewhere you can get at them, as they are by FAR the most used panel controls. Locate them together and out of the way of other switches, connectors and indicators. This is probably the most important piece of the panel layout.
I got my connectors away from my switches and knobs by locating them off to one side. It helps keep cable congestion away from those all important pushbuttons. While well compartmentalised for function, you may find that there are other ways to group that help keep track of steps. You probably will not use all of the merge, invert, etc switches as much as the pattern switches and the gate bus switches, and you'll hate them being in the way, so watch for that.
Oh and also the clock enable gets used a lot when you're programming. I don't think it has to be right next to your pushbuttons but it'll want to be somewhere you can feel for it.
Garret: It's so retro.
Captain Biscuits
PostPosted: Tue Nov 15, 2011 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks for the speedy response!
I'll bear all of that in mind. I've kept the whole pattern, gate bus set up on the top half so it's separate and hopefully clear, but I might re-arrange the bottom half a bit.
I've tried to avoid some obvious labeling so the switch above the clock input is clock enable and the push switch above that is the clock step momentary switch. The same with the Load section so the load enable switch is directly above the Load in jack and the manual load is above that. I like my logical set up (all nicked from other people's designs it must be said Smile ) but I can see what you mean about the advantages of not having a dirty great jack plug in the way right under my momentary switches.
It gives me something to ponder and, at the end of the day function may have to rule over form so I'll look at re-jigging it here & there.
Your input is much appreciated, I'm really keen to make some progress and have this up and running, it looks like such fun to play with!
Ian
EdisonRex
Audio files: 168
PostPosted: Tue Nov 15, 2011 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
A pleasure. I'm not saying my panel was perfect, but there were some major design decisions that worked and some I would do much differently after using the thing fairly constantly over a 2 year period. Grouping the connectors out of the way on a big panel like that is practical. Getting the glide. random and range select out of the way (although range select is another one you're likely to use a lot in practice) has worked for me.
Paradigm X
PostPosted: Fri Apr 20, 2012 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
grüner klee (germ.) = green clover
Holy Moly ! Shocked Shocked Shocked Shocked
Two things.
That looks amazing !!! I have been scanning some for inspiration but jeez that looks amazing, loving the green.
MIDI Shocked Shocked Shocked
How is this implemented, is it the Kendall thing you did? : edit found your thread, its the papareil one. Smile That said, the Dave Kendall/Fonitronik one would be an amazing compiment to this beast!
wow!
Thats very impressive.
Off to your site to look for .fpd files Very Happy
PostPosted: Mon May 21, 2012 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
this is how it looks in real (chnged the knob, though). the MIDI is a small pic based converter from marc bareille (papareil).
the whole sequencer is sold(!), however, i am working on a small eurorack module version for this awesome squencer...
fonitronik at
Paradigm X
PostPosted: Mon May 21, 2012 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
salut
Amazing. That does look really nice, and that green is a really nice colour. Everything I've seen of yours is really nice.
Im still deciding between sliders and a circular layout. Both have their pros and cons.
How did you find those 45(?)/60mm sliders? Are they long enough in practise? I had a novation controller and found the 45mm sliders a bit fiddly, although they were terrible cheap plastic ones anyway. Id love 100mm sliders...
Ive got one of your VC Clock PCBs now thanks to a kind person on here with the PWM so im going to incorporate that. Midi in i think ill leave external, for the DK/Fonik M2C, but it would be nice live. MIDI out would be an awesome addition but probably a bit complex for me.
Thanks for showing off the pictures, Ben
octavecat
PostPosted: Thu Jan 03, 2013 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Did anyone successfully make eurorack panels? I see some line art here, but no confirmation of successful builds...
lucid
PostPosted: Wed Apr 10, 2013 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, finally dreams come true my new MU baby is alive
decision made 11/2012
PCBs arrived 01/2013
panels arrived 03/2013
first switch on 3 days ago
lucid
MU KLEE
 Filesize:  364.22 KB
 Viewed:  19 Time(s)
roglok
PostPosted: Wed Apr 10, 2013 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
lucid
looks great! i like the square layout. congratulations.
PostPosted: Wed Apr 10, 2013 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
lucid
Do you mind if I ask if the panel files are available? I like how compact your panel is for frac! Do you have any photos of the back? I'm curious how you mated the panel and pcbs. Thanks for any info, you've done a great job in my eyes.
lucid
PostPosted: Thu Apr 11, 2013 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
pmed with some more files
backside here
back without wires
 Filesize:  134.11 KB
 Viewed:  965 Time(s)
back- wired
 Filesize:  202.1 KB
 Viewed:  965 Time(s)
PostPosted: Thu Apr 11, 2013 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I see...not frac Embarassed Those are 1/4" jacks (I thought they were 1/8", so the size in my head was 1/4 actual) Rolling Eyes
Thanks a lot for posting, lucid. This looks great!
Niio1
