electri-fire
G2 patch files: 4
Posted: Wed Nov 25, 2009 9:48 am Post subject:
Zeitgeist Schematics |
I asked for the Zeitgeist schematics, but....
Edit: I just remembered Rob mailed them to me. As he also posted the Benjolin schematics I presume he won't mind me posting the Zeitgeist.
| Description: |
| Filesize: |
111.69 KB |
| Viewed: |
627 Time(s) |
| Description: |
| Filesize: |
72.5 KB |
| Viewed: |
316 Time(s) |
| Description: |
 Download |
| Filename: |
ZeitgeistSchematic.pdf |
| Filesize: |
34.07 KB |
| Downloaded: |
953 Time(s) |
Ginsengbob
Joined: Jul 04, 2011 Posts: 3 Location: Alabama United States
Posted: Mon Jul 04, 2011 12:59 pm Post subject:
This May be a stupid question but...... |
How can you use the board graphic for making a pcb when it's got the component graphics on it like that?
Thanks |
CJ Miller
Posted: Thu Mar 15, 2012 5:48 am Post subject:
| I noticed a small error on the schematic diagram. It has C9 - pin 9 on the delay chip - as 9100nF. Looking at the overlay and photo here it appears that the extra 9 is a typo, it should probably be 100nF. |
Ginsengbob
Posted: Fri Mar 16, 2012 10:43 am Post subject:
Seriously |
On the Benjolin post there is a graphic with the components and a graphic for using a transfer with no components to print on the transfer paper.
Is there something I'm missing?
Please tell me.
Thanks |
PickNick
Posted: Sun Mar 18, 2012 9:21 am Post subject:
i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805? _________________ Allow theex.nl |
inlifeindeath
Joined: Apr 02, 2010 Posts: 290 Location: Albuquerque, NM
Posted: Sun Mar 18, 2012 10:14 am Post subject:
| PickNick wrote: | i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805? |
yes, it's just a 5v line for the delay chip. 7805 work fine. _________________ http://www.youtube.com/user/borisandfef |
PickNick
Posted: Mon Mar 19, 2012 7:49 pm Post subject:
great news!
thanks mate! _________________ Allow theex.nl |
tokyomatik
Audio files: 6
Posted: Tue Apr 23, 2013 8:28 pm Post subject:
Re: Seriously |
| Ginsengbob wrote: | On the Benjolin post there is a graphic with the components and a graphic for using a transfer with no components to print on the transfer paper.
Please tell me.
Thanks |
so? no pnp transfer layout??  |
xiwi
Posted: Sat May 18, 2013 6:59 pm Post subject:
Re: Seriously |
| tokyomatik wrote: | | Ginsengbob wrote: | On the Benjolin post there is a graphic with the components and a graphic for using a transfer with no components to print on the transfer paper.
Please tell me.
Thanks |
This might be sacrilege, but I'm currently working on an alternate PCB layout for the Zeitgeist with external pots and jacks. Here's an image. Not making it fully available yet, as I haven't had the time to confirm that it's working perfectly.
http://imgur.com/1TLzkLx |
tokyomatik
Audio files: 6
Posted: Sat May 18, 2013 7:58 pm Post subject:
i already feel better  |
Dogenigt
Posted: Sun May 26, 2013 6:38 am Post subject:
Hi can anyone tell me what these potentiometers on Rob's board is called? I often need ones this size!
And can anyone explain the 10 pin connector for the jumper if I wanted to make one myself? _________________ www.dogenigt.com |
LFLab
Joined: Dec 17, 2009 Posts: 149 Location: Rosmalen, Netherlands
Posted: Sun Jun 02, 2013 1:43 am Post subject:
Those are 9mm pots, several manufacturers make them, Alpha too.
Just need to specify that you want vertical mount. |
boundlessFX
Posted: Tue Jun 11, 2013 12:20 am Post subject:
n00b question |
| What exactly are the components labeled "HDR_3"? I recognize everything else and have most of it on hand, but I've never seen these before. Are they some type of transistor? |
inlifeindeath
boundlessFX
Posted: Wed Jun 12, 2013 6:50 pm Post subject:
| Awesome. Thanks! |
