questionable
Joined: Aug 27, 2006 Posts: 42 Location: southern california
Posted: Sat Mar 05, 2011 1:10 pm Post subject:
Thanks, Yves, for the nice redesign. I've just etched 3 boards this morning and will be building them shortly. _________________ Sounds Questionable |
furio
yusynth
Posted: Fri Jul 15, 2011 9:50 am Post subject:
Excellent  _________________ Yves |
iopop3
Joined: May 28, 2010 Posts: 95 Location: Malmö, Sweden
Posted: Wed Nov 30, 2011 1:12 am Post subject:
Started on my ADSR boards last weekend, noticed a tiny error in the bom.
The number of 1N4148s should be 5 not 4. D5 is missing.
Also the D5 configuration is quite interesting, whats the purpose? I can think of a few reasons, but none of them feels right. |
HexInverter
Posted: Sun Jul 08, 2012 10:57 am Post subject:
Just built a dual one of these in my 5U Serge-style format. Besides the usual blemishing on the panel from acid eating away irregularly, I think they turned out great. They work very well! Thanks for the excellent design, Yves
When I first built them, my LEDs were not working. I did observe correct envelope generation on my oscilloscope, though, so was confused. I did some searching and found the thread where you described that the LED and D5 were reverse biased. I swapped them around and now they work great
Here are a couple of photos!
94.7 KB |
| Viewed: |
39 Time(s) |
106.37 KB |
| Viewed: |
41 Time(s) |
83.22 KB |
| Viewed: |
34 Time(s) |
_________________ hexinverter.net -- Shop DIY projects and modules for modular synthesis
sympleSEQ -- the simple to build analog step-sequencer
seqSQUARED -- the Analogue Pattern Generator
--> Put yourself on the hexinverter.net mailing list to be notified when in stock! |
El Mop
Posted: Sun Dec 09, 2012 11:14 am Post subject:
Same Problem here.
Working envelope but not the LED.
Could not find that thread with the search function.
Do I just have to change the direction of both, the LED and the diode?
Thank you. |
HexInverter
Posted: Sun Dec 09, 2012 11:16 am Post subject:
| El Mop wrote: | Same Problem here.
Thank you. |
I am pretty sure I changed both...it's been awhile though!!! I kinda forgot  _________________ hexinverter.net -- Shop DIY projects and modules for modular synthesis
