 Forum index » Instruments and Equipment » Theremin
Theremin to Midi
Page 1 of 1 [5 Posts]
Muied Lumens
Audio files: 204
PostPosted: Sat Jul 16, 2011 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Theremin and MIDI are not very compatible; MIDI was designed for a typical keyboard layout, and the theremin is a monophonic, gliding pitch with a wide range. If there is such a thing, it will depend on pitch bend to track the glide, and is thus dependent on the target synth for it's success. It will also depend on your playing style.
However, there may be a possibility that a continous controller or NRPN (non-registered parameter number) can do the trick. OSC (open sound control) may be worth looking into too.
You will simply need something that can track pitch (pitch-to-midi, voice-to-midi) and convert that into suitable data. Some theremins also output CV which can be digitized.
Muied Lumens Base Star
DES
Audio files: 6
PostPosted: Sat Jul 16, 2011 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Didn't Moog have a MIDI Theremin?
www.davesneed.com
www.myspace.com/desneed
ben2012ben
PostPosted: Sun Apr 22, 2012 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I must dis-agree. Theremin and Midi go extremly well together. Check out this Theremin Instrument at: http://www.wave-theremin.com/theremin-instrument.php to get an appreciation as to "how well" they go together. Look for the theremin videos.
Muied Lumens
Audio files: 204
PostPosted: Mon Apr 23, 2012 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, the original post in this thread seems to have been deleted...
Anyways, welcome to the forum ben2012ben! Very Happy
I am happy to be proved wrong. I can't remember why I was so sceptical in my previous reply. Confused
bschiett
PostPosted: Mon May 07, 2012 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you already check out the AudioCubes? Every AudioCube has 4 infrared high speed sensors, one on each side, which can measure the distance from your hand to the sensors. This data can then be sent as MIDI CCs to your daw using the midibridge app (an application that comes with the audiocubes). You could say that an audiocube is a kind of 4D optical theremin Smile
More information here: http://bit.ly/LtjZl0
AudioCubes - smart blocks and software for composition, sound design and live performance. Learn more at http://www.percussa.com
