 Forum index » Instruments and Equipment » Cwejman Sound
opening the S1
Page 1 of 1 [2 Posts]
verstaerker
PostPosted: Sun Jul 17, 2011 8:58 am    Post subject: opening the S1 Reply with quote  Mark this post and the followings unread
hello there
i was just about to unmount the rack-ears from my S1, while one of the screws doesn't went off, another one lost a nut wich fall into the inside of the device
i'm now worried that this will cause trouble when using the machine. Did any of you ever openend the S1? Can i easily open the S1? is there anything i should pay attention to? what screws shall be removed in order to open it completly
thx for answering
monads
PostPosted: Fri Jul 27, 2012 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Opening the S1 is pretty easy. You'll have to remove the screws around the casing (I don't think the rack ears are required for removal to open the S1).
Follow these steps in this order for removing the PCB and opening and read further for ONLY opening:
1. Remove all knobs
2. You will have to remove all the jack nuts (time consuming)
3. There is 1 central nut, I think it's on the LFO that'll have to be removed. Look for it (can't remember off the top of my head)
4. Remove hex screws around the casing
5. Carefully open the unit up.
If you only want to open the unit and not remove the PCB, you only have to do #4 & 5 above.
Looks like you might have already found the solution in another forum, but figured I post the above for others Wink
