MFOS VCA X4
Page 1 of 1 [9 Posts]
Audio files: 69
PostPosted: Wed Jul 20, 2011 10:43 am    Post subject: MFOS VCA X4
Subject description: Quad VCA
Hi there.
Last module from 2005 to get the "space management" treatment Smile .
Ordered another twin VCA board from Ray a week ago & some envelopes.
Two Vca's required for bass / melody lines and the other two vca's for control of cv's.
Here's a pic of the old module and a pic of the new panel i made & a jpeg of the layout.
hope to finish this in a few weeks .
I hear PHoBos is building a Quad vca too Very Happy Very Happy Very Happy
 Filesize:  151 KB
 Viewed:  81 Time(s)
 Filesize:  134.71 KB
 Viewed:  81 Time(s)
 Filesize:  231.27 KB
 Viewed:  86 Time(s)
www.myspace.com/skrogproductions
ashleym
PostPosted: Tue Jul 26, 2011 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your system is still huge. Without these reductions it would have gone out of control- then again perhaps it did!!
If you dont mind me asking? I see you have some Ian Fritz modules, I was thinking of building the The DoubleDeka Ultrasonic VCO do you have any views or experience? (I know I can ask elsewhere but I am asking here because I have some level of "understanding" of what you are up to if you see what I mean??)
Audio files: 254
PostPosted: Wed Jul 27, 2011 5:59 am    Post subject: Re: MFOS VCA X4
yep Very Happy, 2x MFOS "another Dual VCA". got the perf PCB finshed, so I only have
to wire it up. For that I need a panel design first and I'm not completely
happy with what I have so far. It looks like I need a bit more panel space, but
I see you even managed to get pots for the CV's in there on the same space. Shocked
http://www.acidtrash.com/
bubzy
Audio files: 47
PostPosted: Thu Jul 28, 2011 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
nice design as always dave. Just a quick question though, those "log/lin" swiches you got, they switch the pots from log to linear? and how??
Audio files: 254
PostPosted: Thu Jul 28, 2011 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
bubzy wrote:
..,they switch the pots from log to linear? and how??
Dave 's not here, so let me answer that. The switches toggle
the VCA between lin. and log. responce, not the pots. Wink
here and here are some nice scope shots (shroll down)
Audio files: 69
PostPosted: Sat Jul 30, 2011 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
ashleym wrote:
I was thinking of building the The DoubleDeka Ultrasonic VCO do you have any views or experience???)
Hi Ashleym.
i've built the double well chaos & the 5Pulser boards from bridechamber (via Wmonk - thanks Woody ) i've not built the vco yet Smile.
PHOBoS ........
my panels are 250mm high by 100mm wide , there was just enough panel space Very Happy .
bubzy.........
Thanks Smile , yes the switch is for VCA mode select.
Audio files: 69
PostPosted: Sat Jul 30, 2011 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
finished the Quad VCA , sitting in the modular now contented Very Happy
I'll post a quick audio file over the weekend when i have time .
Top 2 VCA's are the 2010 version pcb and the lower 2 VCA's are the original 2005 pcb without the bias trimmers , these ones are for my "cv controlled modulations" Very Happy .
 Filesize:  165.94 KB
 Viewed:  73 Time(s)
wmonk
Audio files: 12
PostPosted: Sun Jul 31, 2011 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
So the top ones are AC coupled?
I finished a Quad VCA too btw. Not MFOS though.
Weblog!
Kits for synthesiser modules in Europe
Audio files: 69
PostPosted: Mon Aug 01, 2011 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Short sound test of manual trig push ADSR patched to a VCA cv input with an LFO patched to vca signal in , vca signal out to a vco cv in, the vco runs at a constant frequency until the ADSR is fired.
MFOS vca cv modulations.mp3
 Filename:  MFOS vca cv modulations.mp3
 Filesize:  2.29 MB
 Downloaded:  148 Time(s)
Niio2
