 Forum index » News... » Apple Computers
OS X 10.6.8 update kills network printing + a solution
Page 2 of 2 [38 Posts]
Goto page: Previous 1, 2
PostPosted: Wed Aug 03, 2011 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW.. more on the 016-749 error
ï Cause - A JCL command syntax error occurred.
ï Remedy - Confirm the print settings, or correct the JCL command.
THis error gets reported from the printer it seems..
And thus does not really apply to the solutions I´ve posted here as these apply to the "10.6.8 printers pause issue"
Hmm..
PostPosted: Wed Aug 03, 2011 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Buschmann wrote:
All it says is that the job completed. No errors there.
Yes. So this error happens in the RIP I guess.. in the printer that is.
Buschmann
PostPosted: Wed Aug 03, 2011 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aaargh! What do I do then?
on the web homepage\\skype\\iChat\\MSN\\soundcloud
PostPosted: Wed Aug 03, 2011 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems like this might be a PJL error.. possibly.. gotta check your printer model.
trivia:
Printer Job Language (PJL) is a method developed by Hewlett-Packard for switching printer languages at the job level, and for status readback between the printer and the host computer. PJL adds job level controls, such as printer language switching, job separation, environment, status readback, device attendance and file system commands. While PJL was conceived as an extension to Printer Command Language, it is now supported by most PostScript printers. Many printer vendors have extended PJL to include commands proprietary to their products. Not all PJL commands documented by HP are implemented in all HP or other vendor products. PJL resides above all the other printer languages and parses commands first. The syntax mainly uses plain English words.
PostPosted: Wed Aug 03, 2011 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is your printer?
http://www.office.xerox.com/multifunction-printer/color-multifunction/workcentre-7425-7428-7435/enus.html
PostPosted: Wed Aug 03, 2011 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does it have a job log?
In the printer?
I´m guesstimating that the error happens in the printer ( actually we know that for sure) because the print job contains "something" that violates "something". Xerox recommends checking print settings. Very helpful advice when we don´t know what to look for.
Btw.. what types of documents are you having problems with? What are you trying to print?
PostPosted: Wed Aug 03, 2011 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried the Xerox user forum? What we need to know is which print settings might return this specific error.
Buschmann
PostPosted: Wed Aug 03, 2011 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
It happens evrytime I print whatever document of whatever size. I've tried maaaany.
Yes thats our printer.
I've found this post and another on xerox on the subject 10.6.8 breaks network printing. Should I make a user and post the same thread there?
Buschmann
PostPosted: Wed Aug 03, 2011 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
And yes there is a log but all I found there, and I searched quite a bit, was the syntax error.
PostPosted: Wed Aug 03, 2011 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, possibly a new topic mentioning the actual error code from the printer?
Your case does not quite fit the bill for the 10.6.8 bug mentioned in the tread.
Have you tried deleting the printer and adding it again.. in the printers control panel?
Buschmann
PostPosted: Wed Aug 03, 2011 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ive restarted, repaired disc permissions, tried every bloody driver xerox has to offer, deleted everything, searched the webby, I've tried post generic drivers just for fun, and then I got 22 pages worth of gibberish - so something did get through... Juhu...
But the pc's in-house works perfectly fine, of course.
PostPosted: Wed Aug 03, 2011 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Shocked Crying or Very sad
I don´t think i can help you much. The error is an internal printer error code.
It is not unlikely that the 10.6.8 update has for some reason affected how certain stuff is being sent to the printer. This is however not a type of bug I´ve seen with 10.6.8.
Buschmann
PostPosted: Wed Aug 03, 2011 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much for your time! It's a support mail to xerox and/or the xerox forums next I guess...
Niio2
