Recording guitar in Logic.
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
BobTheDog
PostPosted: Thu Aug 11, 2011 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good stuff.
I am still a bit confused about how you were hearing both on playback though?
PostPosted: Thu Aug 11, 2011 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
Good stuff.
That bothers me as well.
scratch
Flickr
Oskar
PostPosted: Thu Aug 11, 2011 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
Good stuff.
It was an issue with the control software for the soundcard, a Focusrite Saffire Pro40. I had to find a suitable preset for DAW recording within Saffire Control. I've been busy with interpersonal interfacing, so I won't have time to delve further into the matter, but superficially it seems to have been solved, thanks to the good people at electro-music.com! cheers cheers cheers too much coffee too much coffee too much coffee thumb up cheeeezeeey cheeeezeeey cheeeezeeey jackson dancing banana banana banana happy birthday cake Hail the Master Hail the Master Hail the Master wave wave thanks props well done well done well done love love
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
DES
PostPosted: Thu Aug 11, 2011 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds similar to the problem I had with Total Mix for my RME HDSP9652. My symptoms though were that I kept getting a strange flanging/hollow sound...the total mix program was routing unprocessed audio in parallel with the audio going to my external reverb. Because of processing delay I got a comb fitering effect.
The sound card control/mixing/mintoring apps can cause some strange/ irritating problems if you're not careful...
www.davesneed.com
Oskar
PostPosted: Fri Aug 12, 2011 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Des, you're spot on! I suppose for a techno-ninny like myself, purchasing, or purloining, if you're a London hoodie, a piece of hardware with that kind of complexity should be approached with caution. I'm only speaking for myself, mind. Embarassed
