BobTheDog
Posted: Thu Aug 11, 2011 2:08 pm Post subject:
Good stuff.
I am still a bit confused about how you were hearing both on playback though? |
Posted: Thu Aug 11, 2011 2:15 pm Post subject:
BobTheDog wrote: | Good stuff.
That bothers me as well.
_________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Oskar
Posted: Thu Aug 11, 2011 5:44 pm Post subject:
It was an issue with the control software for the soundcard, a Focusrite Saffire Pro40. I had to find a suitable preset for DAW recording within Saffire Control. I've been busy with interpersonal interfacing, so I won't have time to delve further into the matter, but superficially it seems to have been solved, thanks to the good people at electro-music.com! _________________ Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976) |
DES
Posted: Thu Aug 11, 2011 10:35 pm Post subject:
Sounds similar to the problem I had with Total Mix for my RME HDSP9652. My symptoms though were that I kept getting a strange flanging/hollow sound...the total mix program was routing unprocessed audio in parallel with the audio going to my external reverb. Because of processing delay I got a comb fitering effect.
The sound card control/mixing/mintoring apps can cause some strange/ irritating problems if you're not careful... _________________ Dave
www.davesneed.com |
Oskar
Posted: Fri Aug 12, 2011 2:32 am Post subject:
Des, you're spot on! I suppose for a techno-ninny like myself, purchasing, or purloining, if you're a London hoodie, a piece of hardware with that kind of complexity should be approached with caution. I'm only speaking for myself, mind. _________________ Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
