jumunius
Joined: Apr 19, 2010 Posts: 330 Location: San Francisco, CA
Posted: Tue Mar 08, 2011 2:21 pm Post subject:
Are the trimpots best as multi-turn or single? I don't see it specified, but the graphics on the PCB look like multi-turn. (Unfortunately the single turn trimpots I ordered face into other components making them pretty useless!)
(I have the same question about the PS3100 which I received today thanks very much!)
Jim |
Posted: Tue Mar 08, 2011 2:33 pm Post subject:
| jumunius wrote: | | Are the trimpots best as multi-turn or single? I don't see it specified, but the graphics on the PCB look like multi-turn. (Unfortunately the single turn trimpots I ordered face into other components making them pretty useless!) |
it is meant to be multiturn, however for my SMT version i used single turn, which works well, too. you just need a calm hand
| Quote: | | (I have the same question about the PS3100 which I received today thanks very much!) |
see above. and the trims on the PS3100 are not critical anyways (IMHO) _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
jumunius
Posted: Tue Mar 08, 2011 2:53 pm Post subject:
| Ok, thanks. Good to know. |
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
jumunius
Posted: Sat Dec 10, 2011 12:59 pm Post subject:
Re: Powered up the VC RingMod last night |
| fonik wrote: | | kkissinger wrote: | | Both VCA's work ok. The Carrier signal is ok. The Modulator signal is clipped though ... so, I have some troubleshooting to do. |
does it clip at the testpiont TP2, or does it clip at the output? latter would be the feature, not a bug. |
Hi, I'm finally getting around to trying out this module more thoroughly and I'm having problems including the fact that it seems a little TOO distorted. If I use a triangle wave into either the mod or carrier, the waveform at the related test points looks a little sinusoidal. Not completely, just like a triangle with more curve. What could be causing this?
(Adjusting the trimmers seems to affect the waveform but the result never seems to be a proper triangle.... and anyways, I assume the trimmers are merely supposed to adjust DC offset, no?) _________________ -Jim |
Posted: Sat Dec 10, 2011 2:38 pm Post subject:
you never will get out what you put in
i tried it with a triangle, and i never got it perfect at the TP's. the VCA'a are stripped down.
anyways, unlike other ringmods you could not use this modulator as a VCA. it is a weird voltage mangler in the end... _________________
fonitronik at
jumunius
Posted: Sat Dec 10, 2011 5:09 pm Post subject:
| fonik wrote: | you never will get out what you put in
anyways, unlike other ringmods you could not use this modulator as a VCA. it is a weird voltage mangler in the end... |
Oh, ok, well, good to know. A little mangling always comes in handy. Good to know to expect it!  _________________ -Jim |
