 Forum index » Clavia Nord Modular » G2 Performances - Experimental
404IS
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri Mar 04, 2005 9:54 pm    Post subject: 404IS Reply with quote  Mark this post and the followings unread
This is a quite bad attempt at a 303 sound. I noticed from some real 303 samples that the basic waves are not close to there descriptions of saw and square. One is about an 80% rectangle while the other looks like alternating positive and negative, exponential saw tooth waves. It is difficult to tell exactly due to the high resonance on all the samples. I added a custom filter with 18dB slope, inter-stage distortion and the less well behaved “GC” off resonance. Even with some exponential shaping of the decay and a slide/accent implementation, it does not sound like a 303.
I got a LIN9000 snare sample from the same site. Using praat, I tried to recreate it and I’m quite pleased with the result. It is tuned a little higher than usual in this prf.
There is some attempt at structure using variation sequencing.
404IS.prf2
303ish
 Filename:  404IS.prf2
 Filesize:  12.16 KB
 Downloaded:  1180 Time(s)
Audio files: 143
PostPosted: Sat Mar 05, 2005 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are a master... Hail the Master
