Synthed Mind
bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
Posted: Tue Jun 14, 2011 4:18 am Post subject:
welcome to electro-music !
im not entirely sure what you mean by "master oscillator"
the circuit seems to be uncontrollable(you cannot control it, not that its chaotic), there are no inputs or variables so generally, at a glance, i would say no. BUT im a total noob and there are people here who are much better equipped to help you.
(having checked for this schematic i came up with an article from intstructables in which the guy states "For example I needed to build a bi-tonal tone, modulating an approximated 1kHz frequency with a 2,5 Hz frequency."
this would suggest that the circuit as it is is unsuitable, perhaps if you changed the resistors for potentiometers, you could get some better results. if you are looking for voltage controlled oscillators, you will be needing to use more components and a slightly more complicated build than the schematic you have posted here
you may want to check out http://electro-music.com/forum/topic-34550.html for some easy to build circuits that perform well.
-bubzy |
JovianPyx
Joined: Nov 20, 2007 Posts: 1081 Location: West Red Spot, Jupiter
Audio files: 123
Posted: Tue Jun 14, 2011 5:45 am Post subject:
As shown, it's a fixed frequency oscillator, as Bubzy points out. I believe that you can control the frequency by changing R1, like with a pot or a Vactrol or a bank of resisors and switches (crude keyboard) or a resistive strip and stylus. It's output waveform should be sort of sawtoothy with a curved instead of a straight ramp. Note that if you replace R1 with a pot - you really want to have a resistor in series with the pot. The series resistor will set the maximum frequency. If you use only a pot and crank it down to zero ohms, it will oscillate so high in frequency that you may not hear it. If you use a vactrol type device, the response will not be the least bit linear.
It depends on exactly what you want to do with an oscillator. If you want recognizable pitches to come out, this is probably not the best solution (even with a Vactrol). If you want to experiment with an oscillator that uses a pot to control it's pitch and you already have the parts - breadboarded and replace R1 with a pot and series resistor and see (hear) what happens. The values of the resistors and cap (or calculations for them) would be in the document where you found the drawing. _________________ FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff I am formerly known as ScottG here Time flies like a banana. Fruit flies when you're having fun. BTW, Do these genes make my ass look fat?
Synthed Mind
Posted: Wed Jun 15, 2011 3:37 am Post subject:
Fixed note |
Hi all,
Thx for the reply !
I forgot to mention that this circuit would be calculated for only 1 frequency.
The whole idea was to use 12 of these and then to divide to lower octaves.
What I would like to know if this circuit is stable enough so that frequencies will not drift during use.
Greetings |
JovianPyx
Audio files: 123
Posted: Wed Jun 15, 2011 6:34 am Post subject:
I don't see any components that are temperature variant enough to cause pitch drift over normal temperature range. Oscillator pitch drift you may have heard about in modular synths comes from the exponential current converter circuit which is a known temperature variant use of a transistor. There is no such circuit element in the oscillator shown. My opinion - it should work fine for your described use. _________________ FPGA Synth Stuff
FatMan Mods
ian-s
Joined: Apr 01, 2004 Posts: 2517 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
Posted: Wed Jun 15, 2011 12:28 pm Post subject:
| You might like to look at a different design unless you don't plan to implement vibrato and/or pitch bend. Maybe you could do vibrato with a bbd on the final output. |
Tony Deff
Posted: Sun Sep 04, 2011 9:53 am Post subject:
Re: Not a Fixed note |
| Synthed Mind wrote: | Hi all,
Sorry, do not use!
The internal switching thresholds (the input voltage level at which the output decides to change) will vary with supply voltage and temperature. You would need a very stable supply voltage, and even then it may not be good enough.
Use the good old 555.
A member of the Electronic Organ Constructors Society spent a lot of research time finding the right combination of capacitors and resistors to use so that a bank of 555s could be used as stable oscillators in what they call a "free-phase" organ (i.e. an instrument with an oscillator for every note). You might still be able to buy these
http://www.eocs.org.uk/scripts/thecfporgan.htm
The term MASTER OSCILLATOR was first used for the (typically) 2MHz. L-C oscillator used to drive a Top-Octave Generator (TOG) [called Top-Octave Synthesiser or TOS in the USA]. This top-octave drove octave dividers which not only generated the octave below, but from which staircase waveforms would be generated.
Thus varying the Master Oscillator (M.O.) would change every note in such an instrument. The term may also be used if (for example) you had 12 Master Oscillators, each driving octave dividers; varying one of these Master Oscillator (M.O.) would change one note in each octave.
The term is redundant if changing the oscillator pitch affects only one note.
Hope that does not disillusion you
Tony Deff (tone-deaf)  |
richardc64
Audio files: 25
