  Paulo Santos Synth-ing NºX
Steiner Microcon Project
Page 1 of 2 [48 Posts]
dingebre
PostPosted: Mon Sep 12, 2011 11:33 pm    Post subject: Steiner Microcon Project Reply with quote  Mark this post and the followings unread
Hi Everyone.
To compliment the Steiner Synthasystem resurrection I completed (see here http://www.xmission.com/~dingebre/Synthasystem.html), I'm now undertaking the Steiner Microcon. I'll put up a page with build/calibration notes and will have PCBs for sale. Be aware, it does use two Vactrols which may be hareder to find as time goes on. They are the VTL5C3/2 variety right now available at Allied Electronics. It also makes use of 5 74C14 Hex Inverters. There are some substitutes which I'll have in the build notes. It also uses a 2n5246 JFET which also recently went away, but it isn't really special and there are substitutes. Everything else should be relatively easy to find.
There are a couple of trimmers on the PCB which will be configured so you can make it a panel pot, like resonance, and sustain level. So, stay tuned.
The Microcon was a standalone synthesizer voice, VCO, LFO, VCF, EG (driving a VCA). It also had a unique way to "fatten" the VCO sound. Below is a photo taken of one Nyle mounted in a custom rack of 8 (or was it 9) Microcons as a special order.
Carry on...
 Filesize:  266.6 KB
 Viewed:  237 Time(s)
Original circuit board
 Filesize:  1.8 MB
 Viewed:  249 Time(s)
dingebre@3dphysics.net
diablojoy
PostPosted: Mon Sep 12, 2011 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm nice would like to hear a sample or three Smile
SubG (deactivated)
PostPosted: Tue Sep 13, 2011 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
nice
Tim Servo
PostPosted: Tue Sep 13, 2011 3:37 pm    Post subject: Steiner Microcon Project Reply with quote  Mark this post and the followings unread
Hi Dave,
Looks like a neat project. As far as the vactrols, Mammoth Electronics, Small Bear Electronics, and (in the UK) Banzai Music carry them. They are about $6 each, but it looks like they're available.
Tim (photoresistance is futile) Servo
dingebre
PostPosted: Tue Sep 13, 2011 4:07 pm    Post subject: Re: Steiner Microcon Project Reply with quote  Mark this post and the followings unread
Tim Servo wrote:
Hi Dave,
Thanks Tim. I just picked up a few more from Mammoth. Never bought there before. Good prices.
David
vladosh
PostPosted: Thu Sep 15, 2011 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Also interested in this project ,thank you for remaking it ..looks it's a lot ahead of it's time ,however i would like if the vcf could be patched out so it can be more modular ,i hope it won't be hard to modify the pcb's ..and forgot .. i've been looking at the schematics available somewhere on the net ,can't figure if it's using a tempco ?
thanks
Vlad
dingebre
PostPosted: Thu Sep 15, 2011 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
Hi
thanks
Vlad
Hi Vlad,
I'm considering adding other "patch" points, and yes there is a tempco as well as some high frequency tracking correction.
David
dingebre
PostPosted: Tue Sep 20, 2011 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the very preliminary schematic capture. If anyone has a suggestion of where to add a "patch point" let me know.
I've checked it several times and caught some errors already, but if anyone sees an error, let me know.
David
SP_Microcon_1.0.pdf
 Filename:  SP_Microcon_1.0.pdf
 Filesize:  134.5 KB
 Downloaded:  469 Time(s)
vladosh
PostPosted: Wed Sep 21, 2011 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ..thanks for sharing the schematic ,a little noob question straight away - can i relace the ssm chip with two matched transistors , iknow this has been discussed many times ,but anyway ,if so ,which transistors are best for that purpose 2N ,BC ?
Greetings
Vlad
dingebre
PostPosted: Wed Sep 21, 2011 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Greetings
Vlad
Remember, Vlad, the schematic is preliminary and probably has a mistake or two I haven't caught yet.
Yes. I haven't experimented, but any small signal NPNs should work. The SSM is primarily a place holder. The original used an AD810. The best I can figure out right now is it was a Semiconductor Technologies chip. http://www.semi-tech-inc.com/default.htm. Although I can't get them to answer me if they are still available. They list them at their webisite, though.
Bottom line is I'm pretty sure you can replace the AD810 (SSM2210) with any matched pair. There are a couple of monolithic pairs available. Linear Systems makes one, LS318 and Analogue Devices makes a new one, the MAT-12 available at Arrow Electronics (at least) in single quantities. http://components.arrow.com/part/detail/50655244S8707494N2771.
I"ve tried these as well as discrete generic NPNs in Nyle's other designs where a matched pair should be used and they worked fine. I see no reason whey they won't work here.
vladosh
PostPosted: Wed Sep 21, 2011 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info .. thought about match transistors just to cut down overall cost but even if this is not the cheapest project around i guess might be worth it ,so i'll watch for updates on it
cheers
Tim Servo
PostPosted: Wed Sep 28, 2011 5:26 pm    Post subject: Steiner Microcon Project Reply with quote  Mark this post and the followings unread
Hey Dave,
One more thought: maybe put together a small case and power supply and put one (or two) Microcons in there for a nifty little "desktop" synth.
Tim (that's my thought limit for the day) Servo
dingebre
PostPosted: Wed Sep 28, 2011 6:54 pm    Post subject: Re: Steiner Microcon Project Reply with quote  Mark this post and the followings unread
Tim Servo wrote:
Hey Dave,
Absolutely. Nyle has a custom "rack" he put together for someone once a long time ago. It has either 8 or nine modules and a rotary switch on the back which might be for combining the voices in different ways. Nyle couldn't remember...
David
SubG (deactivated)
PostPosted: Thu Sep 29, 2011 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
can't wait to get one of these boards
great stuff Very Happy
dingebre
PostPosted: Fri Oct 21, 2011 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
HI everyone. I have not forgotten. Family, work, and other projects put my SDIY stuff on hold for a few weeks. I am still in process of laying out the PCB. I'll stay in touch here as I make progress.
David
dingebre
PostPosted: Sun Nov 20, 2011 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Progress is made. I ordered some prototype PCBs this weekend. Right now, the PCB is 4 inches by 3.9 inches and will fit flat behind a 21 HP panel. I don't have any power conditioning on the PCB, so as it it, it has to have +/- 12. You can add one of my power conditioning PCBs from the Synthasystem project if you want some extra filtering and/or regulation.
I should have the PCBs in a few weeks and will post a panel design when done.
I could also split it into 2 PCBs if the width is more a problem than depth and then could put some power conditioning on the second PCB. What do you think?
David
 Filesize:  431.09 KB
 Viewed:  210 Time(s)
SubG (deactivated)
PostPosted: Sun Nov 20, 2011 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
my idea was to built one behind a buchla panel,but seems i will need to redraw the pcb
anyhow looks great
dingebre
PostPosted: Sun Nov 20, 2011 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
anyhow looks great
What form factor works best for Buchla? I can re-do the layout if it still works behind a Euro panel.
David
SubG (deactivated)
PostPosted: Mon Nov 21, 2011 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
to fit behind buchla panel pcb may be max. 105x155 mm,105x150mm is ideal
bod
PostPosted: Mon Nov 21, 2011 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
cool, i would be well into a couple of these!
dingebre
PostPosted: Mon Nov 21, 2011 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
So in my "english" unit mind, this is 4.13 by 6.1 inches. The PCB as it stands is 3.9 by 4 inches. So as is, it should fit, if not an ideal size.
What could be done to make it easier for you to use? Different mounting hole location?
SubG (deactivated)
PostPosted: Mon Nov 21, 2011 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
well for a buchla style module ideal would be to replace all connectors by 2 long headers parrallel ,but stretch the pcb to the buchla size then so the headers comes at outsides of the pcb,so the pcb just have to be plugged in into the hmm pot pcb .
but normaly first a front panel layout design have to be done to see where there is room for headers..
and provide on board +/- 15v psu (buchla compatibility) Wink
i think if you do a pot pcb aswell for buchla style you could sell some.
i probably will wire up mine.
something like this:
 Filesize:  501.78 KB
 Viewed:  218 Time(s)
dingebre
PostPosted: Mon Nov 21, 2011 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fascinating. Thank you for the info and example. For now, I think I will stick to my standard layout form. But if there is enough interest for a specific Buchla format, I'm willing to give it a go.
David
reve
PostPosted: Thu Nov 24, 2011 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Totes in for two of these if we're looking at like $20/each.
- r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik
dingebre
PostPosted: Thu Nov 24, 2011 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know prices yet. What I've done in the past is I'll go ahead and place an order for a bunch of stock and set a price based on how many I order. That way, I don't have to deal with the hassle of pre-orders and "interest" I don't mind having extras.
It also depends on whether or not it will need a piggy back power conditioning/regulating PCB. If you have a clean +/- 12 volt supply, you may not need anything else. If you have +/- 15, you'll have to regulate it down so you could benefit from my external conditioning PCB. If I put the regulators and filtering on the main PCB, the form factor will go up, so maybe a 2 PCB set from the get go is best. I can then make the overall form factor smaller, like a 14 U euro panel at the expense of being a bit deeper.
I'll figure that out as soon as I get the first prototype in and make sure the circuit works.
I know I want to build a few of these to play with so I'll almost certainly place a big'ish order and see how it goes. If they sell out, I'll make another order.
Sorry to ramble on like that.
David
