The Karplus Strong eChucK DIY Project
Page 22 of 22 [542 Posts]
Goto page: Previous 1, 2, 3, ..., 20, 21, 22
Jaba
PostPosted: Thu Jul 14, 2011 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Woody,
it would be great to have another run, thank you!
I would surely buy at least one PCB
Paolo
dnode
PostPosted: Thu Sep 22, 2011 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
At last found the time to read through the whole thread, great stuff! Thanks, Les et al!
I would be mucho interested in five boards ... and willing to help out anyway I can!
Idea is to built up two for a module in, well, my modular ... and use three for a separate box incl. sequencer (of any kind?! BS?)
Please, shout if help is needed!
Inventor
Audio files: 256
PostPosted: Sun Sep 25, 2011 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
dnode, i created "the brick"which was a bs into two ks boards, and it sounded awesome. into three would be something else. I strongly recommend your approach to use multiple ks together in each of the ways you choose to use the board as the sound so much better that way.
you might want different voices or you might chain them together for dronish weird sounds, lots of possibilities. I hope there is enough interest for another run.
Les
de_engineered
PostPosted: Sun Sep 25, 2011 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be game sir. I was fixing to just use some vectorboard to build one, but esp. if gangs of them lead to more coolness, I'd be down for a batch solution. I'd be interested in 3-4 boards.
de_sign : de_stroy : de_engineered
de_engineered
PostPosted: Sun Sep 25, 2011 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the stage count of the BBD essential btw? Sorry if this was answered somewhere in this thread - it is 22 pages long a this point Smile !
Ie: is there a minimum for the effect to work, or might it be like reverb tanks with larger springs :: longer reverb times?
Inventor
Audio files: 256
PostPosted: Sun Sep 25, 2011 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
de_engineered, nice nickname. You can use any of the BBD chips which vary from i believe 256 stages up to 2048 stages. Use a 256 chip for percussion and a 1024 chip for guitar, then a 2048 chip for deep resonance. In the synth i mentioned with two ks after a bs, the first ks was 1024 and the second was a 2048 acting as a resonator. It made the coolest darn sounds, it was easy to sell despite the fact it had no enclosure! A smart guy in France bought it for $150 + shipping.
Les
de_engineered
PostPosted: Wed Sep 28, 2011 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you sir Smile. I'm German (mostly) and like going from the other end of things, so it felt apropos.
More thinking aloud here... Can you stack BBDs in parallel like capacitors? Would they be driven by a common driver or need their respective clocks offset by some amount?
Idea being you could 'binary weight' gang BBDs to make effective stage lengths of more arbitrary amounts than the individual devices' respective stage counts.
Or maybe that'd just sound like all kinds of horrible, for good or bad I know not.
Given the going price of BBDs it might just be an overly expensive experiment at any rate...
Inventor
Audio files: 256
PostPosted: Thu Sep 29, 2011 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i would suggest prototyping any circuit geometry that you would like to create in software to see if it's what you think it is. Karplus Strong is powerful in it's simplicity, but physical modeling can be much more complex. Yes, you could parallel them for interesting effects. The KS board has a tap in it for inserting different filters and I'd suggest playing with that foremost.
Les
Audio files: 107
PostPosted: Thu Sep 29, 2011 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Inventor wrote:
"God gave rock and roll to you" - Argent, Kiss
"For those about to rock, we salute you" - AC/DC
Rock and Roll is dead - mosc Wink
mono-poly
PostPosted: Wed Apr 18, 2012 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Totaly missed this one.
If anyone got a spare pcb, i'd be interested!
Inventor
Audio files: 256
PostPosted: Wed Apr 18, 2012 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi mono-poly, welcome to the KS thread, lol. I have recently learned that www.sparkfun.com has a circuit board service in which you can get just one board made or any number you want. They queue up people's boards onto a large panel, much like the MOSIS chip service that queues up people's chips to a wafer, then they have the panel cut up to individual boards for us. With this service there is no longer any need to get a large enough order together - we can just order the number of boards we want. Prices are always reasonable at Sparkfun too (If not darned low).
It's up to woody, but I would be in for four boards myself. Why don't we start a board run tally with this post. Please end your post something like this:
Attention Woody Monk
Inventor: 4 boards requested
Running Total: 4 boards requested
PostPosted: Wed Apr 18, 2012 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I assume the service you're talking about is this one? http://batchpcb.com/forums.html/Products
Inventor
Audio files: 256
PostPosted: Wed Apr 18, 2012 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are indeed correct, any thoughts about or experiences with this service?
Les
PostPosted: Wed Apr 18, 2012 9:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm far too new to this to have ordered custom PCBs already Smile. But it took me a bit to find the SparkFun link so I figured I'd post the direct link.
I'm still playing with small circuits...although most of my parts are here at this point, life has prevented anything very ambitious. Just a variant on the MFOS calibrator and a ridiculous variant on Ian Fritz's transistor matching circuit...and those are both really still in planning because I need additional 1% resistors for the first and sockets for the second. I'm building both on protoboard (though the demands of the Ian Fritz ckt are so minor that I could practically wire it into the lid itself instead).
When I say ridiculous...I ordered a 4PDT on-off-on switch to switch between NPN and PNP variants with one circuit...without paying close attention to dimensions...and the switch I got was HUGE. It fits in the planned project box, but it's going to look very silly. Luckily the switch for transposing the emitters is from the same series/mfr, so they'll look silly together.
Inventor
Audio files: 256
PostPosted: Wed Apr 18, 2012 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
elmegil, nice to read your sharing of your project experiences. Those of us who have been around longer get a kick out of beginners' stories because they remind us of our own beginnings, both the success and the failures. The giant switch is a learning experience, and thanks for the link.
Les
PostPosted: Thu Apr 19, 2012 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I posted the unwired but mounted picture here: http://electro-music.com/forum/topic-51990.html Hopefully I'll get a chance to wire it up tomorrow, at which point I'll take some more pix and post to the build thread.
e-grad
PostPosted: Tue Oct 23, 2012 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I’m stuck with my project. Could someone please tell me whether I got the following right:
Some panels for this project include a ‘resonance pot’ and a ‘trigger level’ pot:
R43 of the summing amp is „resonance pot“?
Trigger level = a pot not shown on the schematics which is wired in front of “X4/Stim”?
There are three pads right above U3. Does a 100nF (= 0.1µF) goes here leaving the middle pad unused?
I received in a trade two different Les Hall’s Karplus Strong boards. One is from 2010 which is discussed in this thread. The second one is from 2009. Is there any documentation for this board available?
Any hint is highly appreciated!
Niio1
