TR808 kick pcb
Page 5 of 6 [145 Posts]
Dougster
PostPosted: Thu Sep 22, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
so the single voice idea has died? will have to ponder about it a little bit...
Umm, what gave you that idea?
To be honest, at this point, I'm probably going to make all three variants... Cool The multi-voice boards will be first, since I'm pretty much done with them already. I still have to decide about the potentiometers, board sizes and mounting holes for the individual voices...
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
PostPosted: Thu Sep 22, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
good to hear. i stay tuned...
brother303
PostPosted: Thu Sep 22, 2011 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Doug,
wow,way cool!
Any idea when a run could happen?
Best regards
Greg
Dougster
PostPosted: Thu Sep 22, 2011 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two things need to happen before I make new boards. 1) This batch of MB-808's has to be out the door, and 2) I want to build prototypes of each new board before I order and ship the final versions. I'll be back from my business trip in mid October, so I'm hoping to get the MB-808's out the door by the end of October. (/me crosses his fingers for luck.)
That said, I'm hoping for November some time. Of course, all of us developer types are optimists... Wink
Blue LEDs are evil.
brother303
PostPosted: Fri Sep 23, 2011 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m not in a hurry,no problem here.
Are there some leftovers for the next MB808 run or are all boards/kits spoken for? Maybe I should jump on this train...
Kind regards
Greg
Dougster
PostPosted: Fri Sep 23, 2011 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
All of the third batch kits are spoken for. I'll be making a fourth batch of kits, since I had to buy parts for 250 kits. (For example, the minimum order quantity for the colored switches was 1000, and each kit takes four.)
If the fourth batch is anything like the third, I'll have a bunch of people on the waiting list, but only about a quarter of them will actually buy...
Blue LEDs are evil.
inlifeindeath
PostPosted: Fri Sep 23, 2011 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's the price per kit if I may ask?
Peake
PostPosted: Fri Sep 23, 2011 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't wait to buy mine Cool
Dougster
PostPosted: Fri Sep 23, 2011 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Roughly speaking (it depends on the cost of pcb manufacturing, and I won't find out the final cost until I actually place the order) the kit from me is about $200, and you'll need about $150 of parts from Mouser or likesuchas, plus a toroid for the power supply. The one I use is about $30 from Digikey. That will get you a fully functioning 808 sound generator with MIDIbox sequencer.
After that, you'll need some kind of case. Most of the guys have been getting a Hammond 1456RL1 and then having Front Panel Express cut the holes and either having the top silkscreened or printing an overlay to stick on...
Blue LEDs are evil.
n.d
PostPosted: Thu Dec 22, 2011 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can I trigger the 808 sounds from a DR110?
Dougster
PostPosted: Thu Dec 22, 2011 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anybody have a DR110 I can borrow? Wink
I'm really slow, but I *will* get it back to you eventually...
Blue LEDs are evil.
Sebo
PostPosted: Fri Dec 23, 2011 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 808 is active high, and the DR-110 is active low, so you have to invert the signal. You can use a transistor for every trigger or a couple of 4069 (each will invert 6 triggers).
Also the DR-110 have a trigger output (is activated with the accent) that you can use as is, without any mod.
Sebo
My Music:
rosch
PostPosted: Sat Dec 24, 2011 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
doug,
that's nice to hear about another run of MB808 in the future. i'd be in if there's still room on your list. should i email / MB-pm you about it?
Dougster
PostPosted: Sat Dec 24, 2011 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Email is best. Doug (at) midibox addict (dot) com
Regards,
Doug
Blue LEDs are evil.
isak
PostPosted: Fri Jun 20, 2014 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sebo.
I see the microlarge site is down.
As i understand you did the 3 big boards?
Do you maybe have the PDF files and all the info about this project?
If you do please can I get them form you?
I really want to start this project.
Isak E.
EDIT:
did you eventually used the http://www.msc175.de/ as a sequencer module?
assuming you used http://www.msc175.de/ midi module, i see in your youtube vid you play from comp sequencer, is it directly from your sound card midi out to the midi in of the module?
n.d
PostPosted: Fri Jun 20, 2014 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Isak: you can find everything via waybackmachine.
isak
PostPosted: Fri Jun 20, 2014 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi thanks.
It's the first time I hear on this thing, how does it work?
How do I pull info from there?
Thanks again!
PostPosted: Fri Jun 20, 2014 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go to: https://archive.org/web/
enter a URL that isn't working into the search bar top center.
If they have an archive of it, they'll show you all the different snapshots they have of that site. Sometimes you have to go back a ways to get the info you're looking for.
isak
PostPosted: Fri Jun 20, 2014 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
amazing! thank you!
i got all the info i needed Smile
elmegil,
if i'm not mistaken yu built yours on stripboards, -minus- cool layouts, right?
have finish? do you have a sequencer?
PostPosted: Fri Jun 20, 2014 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finish? Hahahaha.
I have a completed BD and Snare--the Snare is not a stripboard, but just laying it out on protoboard from the schematics--and a 2/3's completed hats and cymbal and cowbell (they all go together since they share a noise source). I have my "voice box" stickered and drilled and a power supply and accent circuit (though I'm having some doubts about the supply's capacity at this point). And I have a couple weak attempts at a sequencer--one using and Arduino, and one I was encouraged in by someone else that could still turn into a real sequencer using a PIC. Neither of them is very far along though.
So I need to figure out
1) how to mount all the boards in the box
2) whether my power will be sufficient
3) when I'm going to finish it around a LOT of other projects, including three TTSH ARP 2600 clones that I haven't even started
I will eventually finish, but I doubt before I'm 50. Smile
PS I'm not very far from 50 now Wink
isak
PostPosted: Sat Jun 21, 2014 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Dont worry friend, 50 is the new 30 Wink
Do you think the MFOS wall wart PSU will do for the 808 modules?
PostPosted: Sat Jun 21, 2014 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That's the question, because that's exactly what I have in my voice box. I'm not sure, since I've only used it to run three voices so far.
I suspect what will be important is the current capability of the wall wart. Here's why I say that:
I recently refitted a Napa Valley 96 CD case to be a Eurorack case, and I tried using Frequency Central's wall wart supply which is very similar to Ray's. It uses a 1A wart, and I found that I could not drive two full 106HP rows with it, particularly with a Dual Mirror Core VCO (everything else seemed to tolerate the voltage falling down around 10V).
I ended up building a variant on Thomas Henry's supply from Analog Synth for the 21st Century, using LM317/LM337 so I could adjust the rails to be exactly +/-12V. I used a transformer with a fair bit more current capability and it works great now.
isak
PostPosted: Sat Jun 21, 2014 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
that's strange.
i build this synth...
it haves...
11 modules
4 multipliers
it runs under MFOS wall wart perfectly.
PostPosted: Sat Jun 21, 2014 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This case is a bit larger than that Smile
https://plus.google.com/photos/102657837209811792502/albums/5792706164967909073/6027398213719110738?pid=6027398213719110738&oid=102657837209811792502
