 Forum index » Clavia Nord Modular » G2 Patches - Completed » Lead
change LFO clk with step sequence????
Page 1 of 1 [7 Posts]
svoboda
PostPosted: Thu Sep 08, 2011 10:30 pm    Post subject: change LFO clk with step sequence????
Subject description: any way to switch between beat divisions (sync) on lfo B with step eq?
hi all
does anyone know how to have the step level sequencer change between sync values on lfo B???
ive got the level sync going to the rate, but it seems to just be changing it in rate value, and not by beat devision...
thanks.
svoboda
PostPosted: Tue Sep 13, 2011 5:16 am    Post subject: like this Reply with quote  Mark this post and the followings unread
as i was thinking of a way to "switch"
between syn values..
it suddenly hit me
USE A SWITCH!!
enjoy.
TWEAKER LFO.pch2
 Filename:  TWEAKER LFO.pch2
 Filesize:  2.28 KB
 Downloaded:  242 Time(s)
svoboda
PostPosted: Tue Sep 13, 2011 5:28 am    Post subject: NO... Reply with quote  Mark this post and the followings unread
posted too quick...
actually its still not "switching" between sync values....
still just moving through the Hz ....
ANYONE?????
iPassenger
G2 patch files: 78
PostPosted: Thu Sep 15, 2011 3:21 am    Post subject: Re: change LFO clk with step sequence????
svoboda wrote:
hi all
thanks.
I thought that worked as long as the lfo is in the sync/clock mode.
iP (Ross)
dNRML
PostPosted: Thu Sep 22, 2011 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe try using a midi control module and just force the knob?
Roland Kuit
G2 patch files: 124
PostPosted: Thu Sep 22, 2011 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm not sertain, but do you mean this?
tweaker_lfo_930 b.pch2
 Filename:  tweaker_lfo_930 b.pch2
 Filesize:  2.48 KB
 Downloaded:  259 Time(s)
Roland Kuit
http://rolandkuit.com/
Roland Kuit
G2 patch files: 124
PostPosted: Sat Sep 24, 2011 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't clock sync the lfo's, put them on bpm and mono
Roland Kuit
