Spooly Master
Page 1 of 2 [32 Posts]
bubzy
Audio files: 63
PostPosted: Mon Jul 11, 2011 12:28 am    Post subject: Spooly Master Reply with quote  Mark this post and the followings unread
yeah i know, ive got no imagination with circuit names Very Happy
Edit : R4 in the schematic is 1m but i say in the audio that its 100k. it is 100k on my circuit but i guess it wouldnt really matter what the value is Very Happy
 Filename:  spooly master.bmp
 Filesize:  385.06 KB
 Downloaded:  841 Time(s)
madskill42
PostPosted: Tue Jul 12, 2011 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought I've already seen this one Smile
Samples?
bubzy
Audio files: 63
PostPosted: Thu Jul 14, 2011 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ive not posted this circuit before, maybe someone else has done it i have posted the "SpooKy MasHer" this is the "SpooLy MasTer" Very Happy
STE-007.mp3
 Filename:  STE-007.mp3
 Filesize:  2.39 MB
 Downloaded:  667 Time(s)
madskill42
PostPosted: Thu Jul 14, 2011 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's kinda what I meant Smile
Sound pretty cool for two chips. I tried to use 4040 for dividing clock for 4017, but this sound much better! Can you run audio (like sines) through 4040? I can imagine it would sound rather strange Smile
And those diodes makes it sound like Mario's Nightmare!
Audio files: 137
PostPosted: Thu Jul 14, 2011 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is one wild and crazy circuit. Never seen anything quite like it. Sounds great too. Smile
inlifeindeath
PostPosted: Thu Jul 14, 2011 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
never tried it, but as far as I know, CMOS chips, using digital logic, can only process squarewaves ie. on off/0v Vcc/ 1 0 signals.
sndbyte
PostPosted: Thu Jul 14, 2011 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that sounds pretty good, thanks for posting. I'm going to have to try breadboarding this circuit this weekend!
bubzy
Audio files: 63
PostPosted: Fri Jul 15, 2011 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
been playing with this today and you can get some really nice rythyms out of this unit too, if you run a jumper straight from pin 2 or pin 3 (or both for another rythym) to the output capactior (positive side)
also a very high resistance pot in place of r4 (i used a 2m pot) gives some really nice sounds, slows the whole thing right down.
STE-008.mp3
 Filename:  STE-008.mp3
 Filesize:  3.72 MB
 Downloaded:  563 Time(s)
PostPosted: Fri Jul 22, 2011 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing this circuit! I like it a lot! Crazy sounds. I've experimented with pot values and cap values, and there's some interesting stuff. Changing which pins to use on the 4040 gives different stuff too. I'm thinking of putting it in a box.
Since they all have the same pin configuration, I blindly tried swapping the 4011 for a 4070 XOR, 4071 OR, 4077 XNOR and 4081 AND, but none of them produced anything. Maybe I messed something up.
richardc64
Audio files: 26
PostPosted: Fri Jul 22, 2011 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
You didn't mess anything up; you just used the wrong chips Laughing
The 4011 NANDs, which are incorrectly drawn as NORs, are configured as oscillators. A 4070 XOR output will be 0 if both inputs are the same, so in this circuit it won't oscillate. Similarly -- or rather, inversely -- a 4077 XNOR output will be 1 if both inputs are the same, so that won't oscillate here either. The 4071 OR and 4081 AND don't invert, so those will not oscillate.
If you had tried a 4001 NOR it would've worked.
Cool circuit.
"I am endeavoring, ma'am, to create a mnemonic memory circuit... using stone
knives and bearskins." -- Spock to Edith Keeler
bubzy
Audio files: 63
PostPosted: Fri Jul 22, 2011 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
they are incorrectly drawn as i just changed the schematic from some 4001's and changed the text on the chip Very Happy
i put it down to unadulterated ignorance.
and ty all for the kind words. this may form part of my "i propose a challenge" setup. but if it doesnt its been great fun messing about with these cmos chips.
PostPosted: Fri Jul 22, 2011 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
[... explanations ...]
Yeah, thanks for the explanations... I figured it had something to do with the logic, but I was too dumb/lazy to work it out in advance. I was just hoping I'd get lucky. Alas, I don't have any 4001's on hand.
Anyhow, I'm playing with the circuit right now. With various mods, it's pumping out a slow beat, which is not completely regular. And I like that.
[edit: added: ] Oh, yeah, I forgot to mention... I've got this plugged into my oscilloscope, and either it just can't keep up, or this thing puts out the bizarrest patterns! Maybe I'll try to do a little video.
PostPosted: Sun Jul 24, 2011 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, after changing cap values, adding a cap switch box for C2, and the configuration of which pins are used on the 4040, i made this little video of my oscilloscope screen whilst i tweaked knobs and switches....
http://youtu.be/BURzs1Gc_QA
bubzy
Audio files: 63
PostPosted: Sun Jul 24, 2011 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
heh, i hadn't thought of hooking this up to a scope, looks cool. nice work Smile
PostPosted: Sat Sep 24, 2011 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I've been working on this box since July and finally finished it. And now I see the Yum Yum Box also based on this crazy great circuit! Originally called the "Spooly J. Master" then shortened to "Spooly J" (partly because the enclosure I went with was a bit cramped for all the panel stuff).
The way I came up with to make this very flexible was to have 4 tap points and a matrix of terminals, each one connected to a different Q output of the 4040. Sounds like a recipe for chip-frying with static!
Also, the box is sensitive to flesh on the left side... i.e. moving your hand near it can change the sound!
Thanks again to Bubzy for sharing this cool circuit!
Video demo...
http://youtu.be/SEGU3fDxSdQ
 Filesize:  142.16 KB
 Viewed:  225 Time(s)
bubzy
Audio files: 63
PostPosted: Sat Sep 24, 2011 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool box, nice sounds. i feel like a proud parent Smile
jean bender
PostPosted: Sun Sep 25, 2011 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, great work there.
You can feell proud parent, bubzy, for real !! Your early design is great for experimentation.
Our Yumyum box gives us lots of fun !!
http://h.a.k.free.fr/
www.electroncanon.org
micheline
PostPosted: Tue Sep 27, 2011 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
RingMad, this is fantastic! Great crazy sounds!
I don't understand what you mean. What are the 4 tap points? How you wire that?
Audio files: 137
PostPosted: Wed Sep 28, 2011 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome micheline to electro-music.com
PostPosted: Wed Sep 28, 2011 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks and welcome to the forum!
OK, maybe I should draw a schematic of what I built, but I'm leaving town a few days, so it will have to wait. In the meantime, perhaps I can explain referring to Bubzy's schematic...
Firstly, the matrix of "Powers of Two" terminals (bolts) are numbered 1 through 12, and they are wired directly to the corresponding Q output pins of the 4040. e.g. terminal 1 is wired to Q1, terminal 3 is wired to Q3, etc..
Now, on the schematic... see the wire between pin 9 of the 4040 and the anode of D2? Well, instead of connecting it to pin 9, I connect it to my tap point "D" terminal. Now, with the alligator clip on that terminal, I can make the same connection as in the schematic (i.e to pin 9, which is Q1) by clipping it onto the "1" terminal. Or, I could connect it to any of the other Q outputs, thus making it more flexible.
HTH
micheline
PostPosted: Wed Sep 28, 2011 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi! Thanks for the welcoming ! This is a great forum. Sorry, I should have said hello before posting, I was too excited by that Spooly Master !
Thanks RingMad for taking the time to explain it. I'm not sure though about the "D" Terminal. If you don't mind drawing a schematic, I'll be more than happy. If you don't, I'll come back with some questions...
Many thanks!
Micheline
PostPosted: Thu Sep 29, 2011 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Look at the photo of my box above... one of the terminals (bolts) is labelled "D". I'll draw a schematic when I get back next week....
J.
PostPosted: Tue Oct 04, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, here's the schematic. I still haven't gotten the hang of Eagle, so it's easier for me to draw it by hand... enjoy.
"Spooly J" hand-drawn schematic.
 Filesize:  299.25 KB
 Viewed:  386 Time(s)
micheline
PostPosted: Fri Oct 07, 2011 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeaaaaah ! RingMad, thank you so much for that. I really appreciated it. I'll try it in a couple of days when I got home.
Many many thanks to you as well as bubzy !
micheline
PostPosted: Fri Oct 14, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I know this is a simple circuit, I thought I would be able to do it but I have to confess that my reading skills for schematic are zero. Does someone have a picture of the breaboard finished? I would be a great help for learning ...
