wildcat sample and hold
Page 1 of 1 [7 Posts]
vladosh
PostPosted: Fri Jan 21, 2011 4:04 am    Post subject: wildcat sample and hold Reply with quote  Mark this post and the followings unread
having a bit of trouble building a Rene Schmitz sample and hold i thought i 'd try a simpler design i hope this one will work so i just thought i'd share the stripboard layout .. not sure if i can replace the 2n3819 with bf245c if anyone got a clue it would be nice .. this layout is with the mods yusynth did .. it's from his wildcat page ..
 Filesize:  112.79 KB
 Viewed:  141 Time(s)
iopop3
PostPosted: Fri Jan 21, 2011 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
it is this one , http://yusynth.net/Wildcat/sandh-module.html , right? That's a really low parts module.
Btw. I think you could remove the shortest wire going to the Collector of the 3819 if you make the wire on the left side one hole shorter.
vladosh
PostPosted: Fri Jan 21, 2011 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes ,that's the one ..and thanks for the tip . Still not sure if i can replace with bf245c i can find those ..
metacohl
PostPosted: Wed Feb 09, 2011 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I looked at the data sheets and it seems to me that you could replace with the bf245c; you might need to tweak some of the input/output values though, im not sure. Most of the specs were very close.
vladosh
PostPosted: Fri Feb 11, 2011 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i found that 2n38129 so i haven't tried with bf245c .. anyway a simpler s/h which i build and it works but you may wanna check the layout if your building it .. it's from Osamu Hoshuyama design
greetings
vladosh
 Filesize:  113.1 KB
 Viewed:  132 Time(s)
citric acid
PostPosted: Wed Oct 19, 2011 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
is it right - +6v ? is 5v also ok ?
http://soundcloud.com/citric-acid-303
vladosh
PostPosted: Thu Oct 20, 2011 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Citric , i used 6v regulators which i think now must had output a bit less then exact 6 v so you can try it
greetings
mps board
