MIDI Program Change crash G2
sinswolf
PostPosted: Thu Oct 20, 2011 11:28 pm    Post subject: MIDI Program Change crash G2 Reply with quote  Mark this post and the followings unread
When I make a program change by my masterkeyboard on my modular g2, there is one performance which causes a crash of the g2. The usb connection to the G2 engines becomes lost and even all midi connections.
The only thing is to power off the G2 helps.
When I choose the performance by the g2 editor everything works fine.
Is there someone outside with the same problem or has someone fixed it or found the reason and has a workaround?
Some hints will be fine.
Niio1
