G2 Possible to assign Buttons on a already assigned Knob?
Page 1 of 1 [9 Posts]
ssgrfk
PostPosted: Sat Oct 29, 2011 7:39 am    Post subject:  G2 Possible to assign Buttons on a already assigned Knob?
Subject description: G2 Possible to assign Buttons on a already assigned Knob?
Hello.
Is it possible to assign one of the Nord's Buttons (under the LCD Knobs) to a parameter of the patch, when that Knob is already assigned to something else?
ie. the rotary knob controls one thing, the button something else
thx
http://www.materialobject.com
ark
G2 patch files: 31
PostPosted: Sat Oct 29, 2011 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think so. At least I haven't found a way to do it.
varice
G2 patch files: 46
PostPosted: Sat Oct 29, 2011 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
No. Some parameter assignments already use both the knob and button at the same time. It would also be difficult to show what the unrelated functions of the knob and the button were assigned to in the display.
varice
ssgrfk
PostPosted: Sun Oct 30, 2011 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suspected as much. Damn. I still miss my G1 with its big panel of buttons!
grimley
G2 patch files: 9
PostPosted: Sun Oct 30, 2011 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually you can ...
Dasz, let me in on this little trick many moons ago and I've been using it in nearly every patch since. I couldn't find the patch in the archive so I hope he doesn't mind me re-posting it here:
knobbuttonassign.pch2
Independent knob/button trick by Dasz Garncarz
 Filename:  knobbuttonassign.pch2
 Filesize:  1.3 KB
 Downloaded:  210 Time(s)
Sleep Distillery
Apeirophobe
ssgrfk
PostPosted: Mon Oct 31, 2011 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. will check it out. thanks for posting
varice
G2 patch files: 46
PostPosted: Mon Oct 31, 2011 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
grimley wrote:
...Dasz, let me in on this little trick many moons ago...
I had forgotten about this workaround trick.
In this topic is an example patch that demonstrates how to use MIDI modules along with MIDI CC assignments to control any parameters that cannot be controlled directly by the sequencer output signals:
http://electro-music.com/forum/post-192140.html
varice
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Nov 08, 2011 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heh, I remember that patch ... Takes me back....
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 10, 2011 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I do this one quite a lot as long as your control rate isn't too high it's perfect. Like those mad patches of Misty's that sweep the vocoder bands about.. you can do some stuff that I am pretty sure Clavia had not considered. Twisted Evil
iP (Ross)
