synthetic
Joined: Jun 02, 2007 Posts: 76 Location: Glendale, CA
Posted: Wed Jan 19, 2011 9:13 pm Post subject:
Help, my S&H never worked right |
So originally it worked but it would click:
http://electro-music.com/forum/topic-30607.html
I just gave up and lived with it. Now it's not working at all. When I plug it into a filter FM, for example, it sounds like a square wave. It sounds almost the same as the clock output, but a lower amplitude. Everything else on the module works except for this.
Thanks for your time. |
yusynth
Posted: Thu Jan 20, 2011 1:19 am Post subject:
Still have no scope ?
Try and change the BF245 (Q5 JFET) check the diode D3.
BTW, was the JFET provided by Bridechamber a BF245C ?
Also C5 must be a good quality cap (polyester film).
Concerning your previous clicking problem you can try changing the value of C4 from 1nF to 4.7nF. _________________ Yves |
synthetic
Posted: Thu Jan 20, 2011 4:56 pm Post subject:
| There's a scope I can use at work if that helps us troubleshoot. I try what you mention here, thank you. |
synthetic
Posted: Fri Jan 21, 2011 2:08 pm Post subject:
| yusynth wrote: | | BTW, was the JFET provided by Bridechamber a BF245C ? |
Yes.
| Quote: | | Also C5 must be a good quality cap (polyester film). |
It is. |
synthetic
Posted: Sat Jan 22, 2011 3:02 pm Post subject:
What is C4 supposed to be anyway?
Schematic says 10n
Parts list says 1n
Parts layout says 1n
Board says 10n
I installed a 10n, maybe I'll try a 1n. (I don't have a 4.7 right now.) |
yusynth
Posted: Sat Jan 22, 2011 3:07 pm Post subject:
C4 is the cap that sets the sampling time, with 1nF is a very short time, with 10nF it's ten times longer. Depending on this value you can or cannot hear clicks. Therefore try different values in between 1n and 10n until you obtain something that you find satisfactory. I obtained nice results both with 1n or 4.7n . _________________ Yves |
synthetic
Posted: Tue Apr 26, 2011 8:08 pm Post subject:
I've tried a few different values for that cap. My problem is not clicking, it's that the S&H is not holding. I get random peaks out of the S&H output from the white noise normalled source, but they don't hold. Check out the sound file below. I expect a stepped "random" waveform but instead get this.
http://www.jefflaity.com/music/MP3/yusynth_sh_problem.mp3 |
yusynth
Posted: Tue Apr 26, 2011 11:16 pm Post subject:
Have connected a jumper to set the LINEAR vs LOG mode (preferably LOG mode)?
If you did it then :
Can you post oscillograms (and give the settings of the scope : V/square and ms/square) of what you get at the white noise output; what you get at the G pin of the BF245C and what you get at the output of the sample and hold.
Here are the possible causes for a holding fault :
- too high white noise signal (>8Vpp)
- a dead BF245C (Q5)
- a dead TL072 (U2)
- a dead diode (D3) _________________ Yves |
synthetic
Posted: Tue Sep 20, 2011 1:14 pm Post subject:
The jumper is installed. I have replaced all of those parts except for the transistor which is on order. I noticed last night that I used a TLC071 instead of a TL071. So I ordered that part as well to replace it (again).
Is it possible to measure the white noise with a DVM? Are any of the iPad oscilloscope apps useful? If not I can bring it to work, although getting power is always a challenge. |
Benjamin AM
Posted: Wed Sep 21, 2011 12:05 pm Post subject:
| synthetic wrote: | | I noticed last night that I used a TLC071 instead of a TL071. So I ordered that part as well to replace it . | TLC071 is a single supply chip. That may explain why the hold function is not working |
Mongo1
Posted: Wed Sep 21, 2011 8:09 pm Post subject:
Subject description: Is C5 damaged? |
One other thing I'll bring up.
Last night I had to replace a polystyrene film capacitor in my MFOS Keyboard controller. It was part of the sample and hold on that board, and it suddenly decided to stop holding.
Thanks to some kind folks here, I found out that those caps are very susceptible to heat, and can be easily damaged when you solder them in. I replaced the cap, but attached alligator clips between the body of the cap and the solder joint. The clips act as heat sinks and help protect the cap.
Sure enough, that fixed the problem.
If your S&H isn't working properly, you may be experiencing the same problem. And for what it's worth, the board did work for a while before failing.
Just a thought
Gary |
synthetic
Posted: Mon Sep 26, 2011 11:55 am Post subject:
| Can you tell me the exact part you used (Mouser part number or whatever) for the polystyrene cap? Thanks. |
Mongo1
Posted: Mon Sep 26, 2011 1:38 pm Post subject:
| Quote: | | Can you tell me the exact part you used (Mouser part number or whatever) for the polystyrene cap? Thanks. |
On the board I built, the circuit called for .01 uF, which is 23PS310
It looks like Yves is calling for 100 nF, which is .1 uf. That doesn't seem to be available in polystyrene, but there are many different versions available in polyester film. Based on the picture of the layout, I think the lead spacing has to be about .3 inches (7.6 mm).
I'll try to locate one later tonight - I'm at work right now so it's a bit more work than I can sneak in right now...
Gary |
synthetic
Posted: Mon Sep 26, 2011 8:42 pm Post subject:
Well, replacing the op amp and BC245 didn't change anything, so I guess I'll replace the cap. For like the fourth time. WTF.
The project page doesn't specify C4 as a polystyrene cap. All it says is "1n (any value between 1n and 10n will do)." I'm just using a ceramic 10p disc cap for this. Last edited by synthetic on Mon Sep 26, 2011 10:16 pm; edited 1 time in total |
synthetic
Posted: Mon Sep 26, 2011 9:48 pm Post subject:
| I switched C4 for a 1n polystyrene cap, no change. |
Mongo1
Posted: Tue Sep 27, 2011 5:24 am Post subject:
C5 is the sampling cap - that's the one I'm talking about.
C4 is the one that may have something to do with the original click problem
Gary |
synthetic
Posted: Wed Sep 28, 2011 8:20 pm Post subject:
| I replaced C5, no change. |
Mongo1
Posted: Thu Sep 29, 2011 3:43 am Post subject:
Hmmm, I'm out of ideas for the moment. I've got one of those boards on order, so I may be of more help when I get that built. At least we could do some comparisons then.
Maybe Yves can be of more help...
Gary |
synthetic
Posted: Thu Sep 29, 2011 10:35 am Post subject:
Thanks for your suggestions so far.
| yusynth wrote: |
I don't have a way to measure this. As an experiment, what can I do to lower the level of the white noise? Double R36? |
Mongo1
Posted: Thu Sep 29, 2011 10:48 am Post subject:
There's a resistor on the schematic marked with ** - I show it as R27 (470K). I think if you lowered that value it would drop the noise level. As an experiment you could tack another large value (470K-1M) across that, and see if it helps. I think if that value gets too small you'll reduce the signal too much, and have a different set of problems.
Gary |
yusynth
Posted: Wed Oct 05, 2011 1:15 am Post subject:
With a DVM use the AC voltmeter function and mesure the output level of the white noise if you obtain something greater than 6V you'll have to reduce the level of the white noise for this do as suggested by Mongo1. This is done by reducing the value of R34 (try 330K or 270K). _________________ Yves |
synthetic
Posted: Thu Oct 06, 2011 9:18 pm Post subject:
Finally seems to be working. I used a DVM and it looked fine, but I found a friend with an oscillator and he measured the noise at +10V to -10V. So we changed that level and it seems to be working now. Still clicking with every pulse but I can try something new in C4 for that. Thanks.
(For interests' sake I was using a TL074 for the noise as listed in the parts list, not the LM324 listed in the schematic.) |
iopop3
Joined: May 28, 2010 Posts: 95 Location: Malmö, Sweden
Posted: Sat Nov 05, 2011 7:42 am Post subject:
| Finished up my random module yesterday. Had similar problems with the s&h, only saw spikes on the output. After reading this thread, I removed the 470k resistors and added a 500k pot to attenuate the noise. Ended up around 35k, luckily I had some 36k resistors lying around. Now everything works alright. |
