questionable
Joined: Aug 27, 2006 Posts: 42 Location: southern california
Posted: Mon Feb 01, 2010 9:16 pm Post subject:
Yusynth Modules in Euro (12 Volt) Systems |
For a number of reasons (mostly size and the availability of very interesting boutique modules), I have started a small Eurorack system. I am interested in doing some DIY work as well, and quite a few of the Yusynth modules are calling out to be included in the system.
While I have already found this thread about converting the moog filter to 12V:
http://www.electro-music.com/forum/topic-33887.html
...I'm curious:
1) Which Yusynth modules (if any) will work properly without modification in a 12V system?
2) What mods are required to get the rest working?
In particular, I'm looking at some of the bread & butter modulers (LFO, VCA, ADSR).
I really appreciate any assistance you all can give. |
yusynth
Posted: Tue Feb 02, 2010 12:59 am Post subject:
Some can be used directly in 12V :
VCA, mixer, ADSR, most of the VCF, Gate delay, pulse delay, glide, Nois&SH, saw animator, logical, random gates, FFB, VC-LFO
Some can't and need important modifications :
VCO, CV-STANDARD _________________ Yves |
questionable
Posted: Tue Feb 02, 2010 7:55 am Post subject:
Thanks, Yves. It looks like I have some etching to do!  _________________ Sounds Questionable |
questionable
Posted: Fri Feb 05, 2010 9:34 am Post subject:
Is the Steiner Filter one of the VCF's that doesn't require mods for 12V? _________________ Sounds Questionable |
yusynth
Posted: Fri Feb 05, 2010 9:51 am Post subject:
Yes _________________ Yves |
questionable
Posted: Fri Feb 05, 2010 10:08 am Post subject:
Perfect. It will be my first Yusynth project.
Thanks for making all of these projects available Yves. Very kind of you. _________________ Sounds Questionable |
turger
Posted: Mon Feb 22, 2010 2:57 am Post subject:
| If you don't mind answering another one, what about the vca-wavefolder? Can that be used within 12V configurations? |
yusynth
Posted: Mon Feb 22, 2010 3:25 am Post subject:
| turger wrote: | | If you don't mind answering another one, what about the vca-wavefolder? Can that be used within 12V configurations? |
Yes it can _________________ Yves |
turger
Posted: Mon Feb 22, 2010 10:01 am Post subject:
| yusynth wrote: |
Yes it can |
Awesome! Thank you very much! |
TomHarding
Joined: Sep 15, 2010 Posts: 16 Location: Southampton, UK
Posted: Sun Oct 31, 2010 8:14 am Post subject:
| What modifications would need to be made to the Standards module so that it would work on a 12v supply? |
dstrength
Joined: May 23, 2010 Posts: 15 Location: Mobile, Alabama, USA
Posted: Sun Oct 31, 2010 11:30 am Post subject:
The problem is that the supply rails are used to generate the octave and semitone offset voltages. Thus, you'll need to recalculate resistors R3,R5,and R7.
After a quick check I would try to change R3=15K, and R5=130K, and R7=130K.
But, I'll warn you I'm guessing I'm missing something here. I don't understand why Yve's chose R5 as 180K and R7 as 156K in the original. It seems intuitive that these should match since they're generating equally opposite voltages.
I'm sure I'm missing something...as I can guarantee you that the odd value of 156K wasn't arrived at without due consideration. |
TomHarding
Posted: Mon Nov 01, 2010 2:25 am Post subject:
Thanks
Probably a little out of my depth then. Thios dual voltage thing is a real pain.
I was looking at intergrating the three standards with 3 MFOS VCO's to give the VOC's, Octave, semitone and detune controls rather then the standard coarse and fine.
I can probaly get somthing to work with Rays ocatve switch circuit at;
http://www.musicfromouterspace.com/analogsynth/oddsandends.html |
yusynth
Posted: Mon Nov 01, 2010 3:08 am Post subject:
Hi the values proposed by dstrength should do the trick.
For dstrength : To answer your question about the odd value of 156K , I first designed the circuit with symetrical values (i.e. 180K) for R5 and R7 but (probably because of the tolerance of some component or some impedance issue I haven't figured out) it was impossible to get the right range for the lowest values, then I simply trimmed the value of R7 until I got the right behaviour. If you have a clue to explain this misbehaviour of the 180K value I buy it. _________________ Yves Last edited by yusynth on Tue May 31, 2011 3:39 am; edited 2 times in total |
dstrength
Posted: Mon Nov 01, 2010 2:01 pm Post subject:
Thanks Yves. That makes sense. I simulated the voltage divider section in Multisim in order to see if I could figure out the discrepency. As you'd expect...under simulation you arrive at equal resistor values for the semitone offsets.
I think your explanation is the most logical: an aggregate of tolerance errors...most likely in the trimmers. Perhaps also differences in the absolute value of each voltage rail.
Thanks again,
Dave |
transistor logic
Posted: Tue Jun 21, 2011 9:51 pm Post subject:
| i would like to know wich filters can be used with 12V without modification |
glitched
Joined: Mar 25, 2006 Posts: 80 Location: phila., pa USA
Posted: Fri Oct 07, 2011 8:25 am Post subject:
| I may as well ask, just to be sure: How about the ARP 7072 filter? Will everything operate as normal or will I have to pick up a few resistors? |
yusynth
Posted: Fri Oct 07, 2011 8:32 am Post subject:
| glitched wrote: | | I may as well ask, just to be sure: How about the ARP 7072 filter? Will everything operate as normal or will I have to pick up a few resistors? |
no idea you just have to try it by yourself... _________________ Yves |
hv0190
Posted: Sat Oct 08, 2011 9:16 am Post subject:
I've just finished building the 4072 Filter and it's running perfectly in my 12V Eurorack system. Thanks a lot to Yves - you are the man  |
yusynth
Posted: Sat Oct 08, 2011 1:55 pm Post subject:
Great news , no I know how to answer this question  _________________ Yves |
hv0190
yusynth
Posted: Tue Oct 11, 2011 7:54 am Post subject:
Nice and colorful modules _________________ Yves |
glitched
Posted: Tue Oct 11, 2011 10:32 am Post subject:
Great job, hv0190! I can't wait to get my kit and my panel.
Let me ask you this: how did you mount the PCBs in 4HP? Would you mind taking a picture of the back?
Thanks! |
hv0190
glitched
Posted: Tue Oct 11, 2011 1:08 pm Post subject:
Thanks so much for sharing that. I always panel-mount my pots when I do a layout on perfboard, but this time I'm getting a "real" pcb from bridechamber.com, which doesn't have spots for pots, on-board.
I don't have the tools to make brackets, so I was a little confused as to what to do! Anyway, yeah, I like your idea of mounting smaller pots on a perfboard, then mounting the PCB to that. I'll probably end up doing something like that. Thanks for the idea! |
hv0190
Posted: Mon Nov 21, 2011 9:11 am Post subject:
OK, some update from the 12V/4HP loonie:
Some other YS modules running smoothly at 12V are the ADSR (I actually made an 8HP dual-version) and the Random Module.
Both are easy to build (thanks to Yves' excellent online documentation) and have worked 100% right from the start.
Yves, I cannot bow down often enough to praise your work  |
