Where to source knobs?
Page 1 of 1 [3 Posts]
nickster
PostPosted: Mon Feb 15, 2010 5:18 am    Post subject: Where to source knobs? Reply with quote  Mark this post and the followings unread
Hi again
I am wondering about changing out the grey doepfer knobs for something a bit more retro looking.( As my system has yet to arrive I do not have the chance to have a proper look under the hood.)
And I am sure I have seen somewhere that someone has done this to their Doepfer modular and was wondering if it would be possible and where would be a good place to source knobs for Eurorack modules.
Many thanks again for any help someone could offer.
Nick
CatchAce
PostPosted: Sat May 14, 2011 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
im not sure how retro you wanna go, but im sure you could replace your knobs with abunch of small brass pipe or pressure fittings of some sort and go for a really retro steampunky look. You could even mark an indicator line with abit of clear tape and a thin-line sharpie.
its what im doing.
edit, you could also put an epoxy-line as an indicator line, or a sharpie with a spray of clearcoat to seal it, for a cleaner look than lines on a swatch of tape.
nickster
PostPosted: Sun Nov 27, 2011 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally tracked down some great knobs for Eurorack from small bear in the States. http://www.smallbearelec.com/Detail.bok?no=1192
If any one else is interested. More info on muffwiggler forums
Niio1
