Joined: Jan 07, 2009 Posts: 588 Location: Scottish Borders
Audio files: 69
slacker
Posted: Mon Dec 20, 2010 2:06 pm Post subject:
Very cool, look forward to seeing the real thing.
Out of interest what voltage are you running it off? |
Audio files: 69
Audio files: 69
Audio files: 69
Taylor
Posted: Tue Jan 18, 2011 3:53 pm Post subject:
Sounds and looks awesome Dave! Really pleased to see the boards in a modular environment. Slacker's circuit is so versatile that I find new fun things it can do all the time.
How have you done the CV for time mod? Just sending your CV to the base of the modulation transistor? _________________ musicpcb.com |
strategy
Joined: Jan 03, 2009 Posts: 66 Location: portland, oregon
Posted: Tue Jan 18, 2011 10:44 pm Post subject:
| Taylor wrote: | Sounds and looks awesome Dave! Really pleased to see the boards in a modular environment. Slacker's circuit is so versatile that I find new fun things it can do all the time.
How have you done the CV for time mod? Just sending your CV to the base of the modulation transistor? |
Yeah, do tell - would like to add an input to the standalone version I intend to build! _________________ --------
community-library.net/strategyhome.htm |
sneakthief
Posted: Wed Mar 16, 2011 11:19 am Post subject:
Skrog Productions: do tell how you implemented your cv control  _________________ Sneak-Thief - raw electrofunk |
Audio files: 69
Posted: Sun Mar 20, 2011 3:20 am Post subject:
Hi , i added the cv in via an attenuator to the wiper of the lfo amount pot , best results if you kill the internal lfo with the lfo kill switch mod to run the external cv on it's own , you may need a resistor in series with the attenuator ground pin (something like a 10K) as the lfo amount wiper connection didn't like the internal lfo getting grounded by the cv pot when set at lowest , counter clockwise .
experiment a little to get results you like
cheers.
Dave. _________________ www.myspace.com/skrogproductions |
philoop
Posted: Mon Nov 28, 2011 5:10 pm Post subject:
echobase delay Subject description: cv |
i see your extension board
any schematics?
and how to make feedback cv controlable
and a crossfeed? _________________ Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately. |
sneakthief
Posted: Tue Feb 14, 2012 2:34 am Post subject:
Re. stereo Echo Base crossfeed:
Success!
I took the feedback output (CW pin of the feedback pot) of the Left delay pcb, sending it to a non-inverting opamp buffer which then goes to a 20KA pot, and finally to a 20k mixing resistor that goes in the connection between the 4n7 capacitor and the 20k resistor that's on the pcb. (And the same for the other side.)
I used this buffer schematic and biased the input with the 5V output. I also put a 100n cap after the 10uF (very important!):
http://www.muzique.com/lab/buffers.htm
Also, the CV-input works well. I put a diode between the cv-input jack and the ground to remove all negative CV voltages. I connected it directly to the base of the BC560/2N5087 with a 20k resistor.
Please note: the Echo Base will invert your audio signal because it uses one inverting opamp and a non-inverting opamp. _________________ Sneak-Thief - raw electrofunk |
