Simple X-fader/Panning PCB project for DIY Serge Gator
Page 1 of 2 [28 Posts]
macumbista
PostPosted: Mon Nov 28, 2011 9:22 am    Post subject: Simple X-fader/Panning PCB project for DIY Serge Gator Reply with quote  Mark this post and the followings unread
I've assembled almost everything I need to do a Serge Gator clone from the CGS collection, the one thing missing would be the X-fader/VC gain module.
I've looked at two projects out there, Fonik's X-Pan-Fade from the Triple Resonator module, and M. Bareille's SSM2164-based Quad VCA. The former may not be exactly what I am looking for (as well as unavailable), the latter is a bit large and expensive. Does anyone know a simple X-Fade or stereo panning project PCB that is approximately the same size format as the CGS modules?
macumbista.net
ericcoleridge
PostPosted: Mon Nov 28, 2011 10:27 am    Post subject: Re: Simple X-fader/Panning PCB project for DIY Serge Gator Reply with quote  Mark this post and the followings unread
I've been looking for solutions to the same problem--and I know of at least two other possibilities, the second one being the one I'm leaning towards (small enough to squeeze into a Serge style quad vca/panner):
Yu Synth VCpanner
Vactrol Panner
Also, here's a voltage controlled x-fader:
Bergfotron Crossfader
richardc64
Audio files: 26
PostPosted: Mon Nov 28, 2011 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
My way is simpler.
http://www.sdiy.org/richardc64/mmvca/index.html
macumbista
PostPosted: Mon Nov 28, 2011 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
richardc64 wrote:
My way is simpler.
Oh that *is* elegant! Response is linear, isn't it? Maybe better for CV crossfade than for stereo audio output...
macumbista.net
diablojoy
PostPosted: Mon Nov 28, 2011 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Haha thanks for the reminder i must post the schematic
as i said i would, my apologies , completely forgot about it Embarassed . will try and get it posted before the weekend.
ask where the hell am I
as good an answer as any
ericcoleridge
PostPosted: Mon Nov 28, 2011 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
richardc64 wrote:
My way is simpler.
Yeah, this would be really nice for a lot of different applications. I'm always looking for a small parts count cross fader for all kinds of stuff. I'll have to try making a little layout for it.
diablojoy
PostPosted: Mon Nov 28, 2011 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
My way is simpler.
It does indeed look good
I think i could get 2 on a smallish board, would make a nice ancillary module might try and test out the lm13700 version
as long as it's ok with richardc64 ?
richardc64
Audio files: 26
PostPosted: Mon Nov 28, 2011 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Never seen my stuff called "elegant" before. I'll have to remember to keep a pinky raised whenever I post Laughing
Yeah, it's linear
Go for it. Might need a different current source than what my untested schema shows.
macumbista
PostPosted: Tue Nov 29, 2011 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
If you work that one out, please let me know. I have a ton of dual OTAs sitting around. Can you explain why the LM13700 version needs a different current source than the 3080? Couldn't the op-amp buffer used in the single arrangement also be used in the dual? This part is a bit beyond my understanding...
macumbista.net
richardc64
Audio files: 26
PostPosted: Tue Nov 29, 2011 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Mine too, actually. But no, the op-amp and diode trick supplies the 3080 Iabc (the control current), AND -V. In the LM13700 -V is common to both OTAs, so this method can't be used. That's why I show the simple one-transistor current source in the untested '13700 version, but that might be too simple, and something better -- like a current mirror -- could be needed.
Someone more knowledgeable could perhaps offer some advice, if we could get that "someone's" attention.
emdot_ambient
PostPosted: Tue Nov 29, 2011 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you've got my attention........however all this is Greek to me geek
macumbista
PostPosted: Tue Nov 29, 2011 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's interesting, since I was recently asking about the differences in OTAs in another thread. I was assured there wasn't much, now you're here to prove them wrong!
macumbista.net
diablojoy
PostPosted: Tue Nov 29, 2011 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
seems I will need to do a bit more studying on this, always something more to learn i have quite a few of 3080 and lm13600/13700 but would rather keep the 3080's back for other ccts as the lm13700 are far more common
time will tell if i can figure it out.
Eric : seems i never actually drew up a proper schematic up for that vactrol pan on my computer so if i cant find the bit of paper i scrawled it on by the weekend i will have to backtrace the cct board though i think i remember most of it anyway.
oh well at least Its a very simple cct
frijitz
Audio files: 54
PostPosted: Wed Nov 30, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all --
Richard asked me if I could comment on this discussion, especially re the OTAs.
First, this is really a brilliant design. I'm surprised it hasn't been pick up on before. I think lots of folks would be interested if boards were available. People seem to be getting more and more interested in modules with lots of features.
Comments on the original design: The reason for the oddball resistors around A4 is most likely that the left side of the 47k sees a finite impedance. If this point were buffered then the three odd resistors could all be 47k.
The unknown R below the Init control is there so the input CV (eg, envelope) can be burried below zero. I think it could actually be omitted, depending on how you like to use the CV In. IOW the Init pot can go across the +/- supply.
On the OTAs: When the 3080s were going away I suggested everybody stock up on them because of all the designs that use the Jung trick of driving through the power pin. I have a pretty good supply myself and I could probably let a few go for projects like this.
The question of whether the same drive configuration could be used on the 13600/13700 has been asked but AFAIK never resolved. Would it still work if only half the chip were used, or if the two halves were connected in parallel???
The untested current source would probably work, but I would prefer an active (opamp) summer approach. See the pt. 2 drawing here:
http://home.comcast.net/~ijfritz/Chaos/ch_cir6_chaotica.htm (lower left)
So at the cost of a dual opamp you could make the circuit a bit more precise. A matter of taste, for sure.
Ian
richardc64
Audio files: 26
PostPosted: Wed Nov 30, 2011 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa! First "elegant", now "brilliant"...
Most brilliant, IMNSHO, is that it doesn't need switches to select the different functions. Less brilliant is that, since it uses just one OTA, it can't function as two normal VCAs, like the more common panning method.
Not sure what that means scratch
I think I remember now; without the "unknown resistor" the init pot had to be rotated far off-center to make a single input come out at roughly equal levels on both outputs. Rather than figure out why that should be, I went for the expedient fix.
THAT's something that might be worth exploring. Wish I had the facilities.
Yeah, that does look better. Besides being more precise it's simple enough to make trying to apply the Jung trick to the '13700 unnecessary.
Thanks so much for your insights!
frijitz
Audio files: 54
PostPosted: Wed Nov 30, 2011 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exactly!
Hmmm... Let's try looking at it from a different angle. The outputs are not linear functions of the input pot settings, ie the gains of the two output amp circuits depends on the input pot settings. If you buffer the pot wipers, then the behavior is ideal. But maybe that's not the main issue here, especially if you do all the setup with the input pots full up or full down. So the needed R values might need a bit more explaining.
That's odd. It was OK at the endpoints but not the middle?
Ian
macumbista
PostPosted: Thu Dec 01, 2011 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Ian, thanks for checking in on this! I may just try prototyping this in the next week with your op-amp summer, I'll post back if I do.
macumbista.net
richardc64
Audio files: 26
PostPosted: Thu Dec 01, 2011 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I should have written "...had to be rotated too far clockwise..." The unknown resistor allowed the 2 outputs to be equal when the init pot was centered. In other words, without the resistor the CV was "buried" over much, much more than half of the pot's rotation.
frijitz
Audio files: 54
PostPosted: Fri Dec 02, 2011 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
richardc64 wrote:
...But no, the op-amp and diode trick supplies the 3080 Iabc (the control current), AND -V. In the LM13700 -V is common to both OTAs, so this method can't be used.
So I finally tested the power-pin biasing on the LM13700. Using one half of the pair works exactly the same as the original. Using the two halves in parallel also works. I've started a new thread on the circuits.
http://home.comcast.net/~ijfritz/Chaos/ch_cir5_twc.htm
Ian
diablojoy
PostPosted: Fri Dec 02, 2011 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Ian is really good of you to do that
will read the new thread with interest.
macumbista
PostPosted: Sun Dec 04, 2011 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, my eyes are starting to swim a bit here, let me see if I understand what is being suggested. The op amp summer shown in the attachment below (Picture1.png) should replace the transistor arrangement in the lower left of this image:
Where "c" in Ian's drawing connects where the 10K resistor enters the LM13600. Right? What pin on the IC is that, Richard? In your first, tested VCA layout you are using both 4 and 5 for the biasing. So in the second, you use which? Or does it depend which half of the OTA IC you are aiming at?
Help me connect the last dots please!
Also, do I understand you correct Ian when you say this arrangement has been tested now? Thanks for sharing your time with us!
Ian Fritz op-amp summer from http://home.comcast.net/~ijfritz/Chaos/ch_cir6_chaotica.htm
 Filesize:  9.51 KB
 Viewed:  20402 Time(s)
macumbista.net
macumbista
PostPosted: Sun Dec 04, 2011 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Last question: the CV for this VCA would be bipolar, or positive only?
macumbista.net
richardc64
Audio files: 26
PostPosted: Sun Dec 04, 2011 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Pin 1 or 16, depending on which half of '13700 is used.
The original, with the Jung current source, was intended to function with either, with proper adjustment of the "initial" pot. As for Ian's method, I think I might've gotten in a bit over my head, here.
Maybe I should've kept quiet.
macumbista
PostPosted: Sun Dec 04, 2011 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, do you think there is any way this circuit to could overall voltage-controlled gain (like the Serge X-fader)? Maybe more CV summing tricks? Or another VCA needed? Hmmm....
macumbista.net
macumbista
PostPosted: Tue Dec 06, 2011 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
This circuit shouldn't be any different with am LM13700, should it? See again my thread on differences between OTAs...
macumbista.net
