Weekend of Weirdness
Page 1 of 2 [50 Posts]
JingleJoe
PostPosted: Thu Dec 01, 2011 5:17 pm    Post subject: Weekend of Weirdness Reply with quote  Mark this post and the followings unread
I have some chips and some transistors and some ideas and a secret laboratory and I am devoting a 3 day weekend entirely to creating weird sound machines made from as few chips as possible.
What will I make!? What will it sound like!? Only Poseidon knows! Shocked (the king of the sea and therefore sea moss too)
I will share the results of my work here.
This is just a sample of the crazyness which could be in store!
 Filesize:  19.14 KB
 Viewed:  394 Time(s)
JingleJoe
PostPosted: Fri Dec 02, 2011 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe
PostPosted: Fri Dec 02, 2011 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some progress from earlier this evening after venturing into the city to buy potentiometers.
JingleJoe
PostPosted: Fri Dec 02, 2011 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's pretty much done now. I just need to fine tune things a bit Smile
Circuit description: a few low frequency oscillators made with a 7414 go into an R2RD2 resistor ladder/droid and then act as a control voltage for a VCO, then the waveform is recombobulated by my my patented pulse width modulation circuit Very Happy
inlifeindeath
PostPosted: Fri Dec 02, 2011 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
care to share?
JingleJoe
PostPosted: Sat Dec 03, 2011 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
It's probably the standard thing everyone uses Rolling Eyes but I shall explain anyway;
Simply use an op amp as a comparator.
Feed one of the inputs with an audio frequency waveform with sloping sides like a triangle sawtooth or even a sine would work. Then feed the other with a voltage, if it is above or below the peak to peak voltage of the audio waveform the comparator will output a pulse wave of 0% or 100% so it is a good idea to keep the modulation voltage between the peak to peak voltage of the audio wave.
I'll attach a graph, graphs explain everything better.
The blue triangle wave is the audio frequency input, the green rising line is the control voltage, the red wave is the output.
(the corners of the pulse are slightly rounded because I used an LM324 op amp, it would be squarer if you put it through a schmitt trigger afterwards or used a better op amp)
You can see that when the control voltage goes above and below the peak and trough of the wave, the duty cycle is 100% or 0%, the output of the comparator flips when the audio wave crosses the control voltage.
 Filesize:  17.47 KB
 Viewed:  392 Time(s)
JingleJoe
PostPosted: Sat Dec 03, 2011 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Saturday: 1700
So... Much ... Tweaking.
Two important lessons learnt from this:
Don't use TTL.
Buy the right potentiometers by double checking all your readings first.
I don't have the camera right now or I'd record a video of my latest developments, the device now makes even more bleeps and the LFO modulation of the pulse width is working great Very Happy
Still more work to do though!
inlifeindeath
PostPosted: Sat Dec 03, 2011 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome, thanks for the explanation.
JingleJoe
PostPosted: Sun Dec 04, 2011 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem Wink
I'm still making progress, but I need to attenuate the control waveform better.
JingleJoe
PostPosted: Sun Dec 04, 2011 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
After hours of fine tuning and fiddling it is finally finished! It's only on breadboard for the moment but I shall solder it up and put it in a box soon Very Happy
Circuit diagram coming soon, watch this space!
JingleJoe
PostPosted: Sun Dec 04, 2011 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
The point of this project was to finish it quickly (over one weekend) and use as few IC's as possible and still get alot of bleepy weird noises.
Now we can get down to the technical details Smile
For this device I only used an LM324 op amp, and a 7414 inverting schmitt trigger (note: never use a 7414 schmitt trigger, it's TTL and therefore very difficult to make work properly, use a 40106 instead)
The diagram shows a 40106 but these values are for a 7414 schmitt trigger.
Description of operation:
Four of the schmitts are used to make oscillators which go into four rungs of an R2R ladder, which gives the nice crazy control voltage for the VCO. This voltage is attenuated and re-combobulated by the op amps following it (lots of tweaking was required and resistors needed to be added to the potentiometers to eliminate the dead zones at the end of the turn). Ultimately they give level control and initial pitch control.
The last schmitt trigger was used to make an LFO, attenuated in the same manner and used as a pulse width modulation control.
I don't mean to blow my own horn but I think I did pretty well to get so much out of just two chips. Laughing
Error correction: R12 should connect to C5, not the output of U5. The cap gives a sort of triangular wave and the output will give a square wave.
 Filesize:  38.99 KB
 Viewed:  421 Time(s)
Inventor
Audio files: 267
PostPosted: Mon Dec 05, 2011 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent! what fun, scope videos and wacky sounds. nice thread.
Les
inlifeindeath
PostPosted: Mon Dec 05, 2011 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
inventor! where you been?
dougseidel
PostPosted: Mon Dec 05, 2011 12:17 pm    Post subject:
Subject description: totally cool machine
that's totally great - thanks. great movie too.
Doug
Mongo1
PostPosted: Mon Dec 05, 2011 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool stuff! It's a rare instrument that can capture the ambiance of both a Bagpipe AND a Geiger Counter, but I think you've just about done it. Laughing
Gary
Inventor
Audio files: 267
PostPosted: Mon Dec 05, 2011 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i was posting this summer but got little response cause other people have outdoorsy things do do in the summertime and em slows down on the forum in summer, then i stopped for a while because i moved to texas where i had a wild and insane adventure which landed me in a rehab center where i am now. Things are just settling in to the point that I can get back on em now.
Les
Mongo1
PostPosted: Tue Dec 06, 2011 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow - one more data point in my lifelong thesis "Stay the hell out of Texas". Hope you're doing ok...
Gary
JingleJoe
PostPosted: Tue Dec 06, 2011 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Gary
Mine is just "stay the hell out of america" Wink I jest.
Also: Yes, even my grandad says it sounds like bagpipes Laughing It's really good fun though and it worked exactly how I wanted it to Very Happy
Inventor
Audio files: 267
PostPosted: Tue Dec 06, 2011 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually it is Texas that is saving me, not causing the problems. I had a poor opinion of Texas before as well, imagining the place to be full of gun toting republican waco fanatics. Well nothing could be further from the truth. People here are friendly and go out of their way to help you, the medical facilities are excellent, and even the police are nice. Compared to the east coast or west coast, Texas is the best kept secret in the USA. I'm very happy here. Who would have thought that?
Mongo1
PostPosted: Tue Dec 06, 2011 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad to hear that - I've got some friends that absolutely love the place. I've had some bad samples I guess, most notably driving through west Texas with the family when we moved cross country. Nothing but Rednecks and Dairy Queens as far as the eye could see (and you can see a LONG way in west Texas).
Anyway, I'm glad to hear you're doing well. Stay strong and feel better...
Gary
inlifeindeath
PostPosted: Tue Dec 06, 2011 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd have to say Florida is a much worse place than Texas. Also, I completely agree about West Texas. Pretty miserable.
Glad to hear you're on a better track Les! Best wishes!
inlifeindeath
PostPosted: Tue Dec 06, 2011 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
And for those critical of America, let this man explain to you that...
http://www.youtube.com/watch?v=itf7IS3p93s
JingleJoe
PostPosted: Wed Dec 07, 2011 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
This thread
Carry on Smile
Inventor
Audio files: 267
PostPosted: Wed Dec 07, 2011 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hahahhahha, thanks for the laugh!
Yes, sometimes it feels like a train wreck in slow motion...
Les
dougseidel
PostPosted: Thu Dec 08, 2011 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyway, I'd love to see a picture of this thing when you put it in a box, etc. And then i'd like to hear more music from it!
Doug
