 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Big versatile reverb
Page 1 of 1 [4 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Mar 11, 2005 12:49 am    Post subject: Big versatile reverb Reply with quote  Mark this post and the followings unread
Hi all,
Here's an improved version of an earlier patch. It's a complex reverb patch for processing external signals. It includes a simple synth for testing the reverb settings & a switch to select internal synth sound or external audio input.
It's basically two separate reverbs - The first is a simple small room with predelay & EQ. This provides early reflection type effects. It's located in the upper screen because I couldn't fit the whole patch in one DSP.
In the CVA, the second reverb is a big lush reverb made by combining a "Hall" reverb & a "Large" reverb and using morphs to link their controls. This big reverb also has EQ, a long variable predelay, a pre-chorus, and some randomly swept delays applied individually to one side of each stereo reverb to thicken things up. Also has a control for setting the mix of dry vs. room signal being fed to the big reverb's input, and a stereo width control for the reverb output.
I've used it on some mixes, and it sounds better than my Lexicon in some applications. Really nice with acoustic piano. Enjoy!
EXT Lux Reverb2.pch2
Big complex reverb for processing external signals.
 Filename:  EXT Lux Reverb2.pch2
 Filesize:  3.52 KB
 Downloaded:  1929 Time(s)
Dave Peck
Audio files: 211
PostPosted: Fri Mar 11, 2005 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is a great sounding patch. This sounds like a professional reverb, to me at least. Thanks, Dave.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Mar 11, 2005 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice tail Very Happy
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Mar 11, 2005 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for noticing. I've been spending more time at the gym. Wink
Dave Peck
