  bingsatellites Mostly Ambient
Steiner VCF Reso problem
Page 1 of 1 [7 Posts]
Pehr
PostPosted: Thu Dec 08, 2011 6:31 am    Post subject: Steiner VCF Reso problem
Subject description: too loud
I've got three steiner VCF from CGS, the old version (green PCB).
Running on dual 12V.
One of the filters sounds good, but the two others have way too loud resonance and they start to resonate at too high frequency.
Where should I start troubleshooting for reso level/freq?
btw, the overall level of the filters is equal (no reso).
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Pehr
PostPosted: Thu Dec 08, 2011 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I think i'll try swapping transistors first
YouTube channel
flickr photostream
Pehr
PostPosted: Fri Dec 09, 2011 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
they sound good with no resonance
so I guess I'll have to take a look at the feedback stage
I'll try to post a scope-vid
YouTube channel
flickr photostream
jumunius
PostPosted: Fri Dec 09, 2011 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC, you might vary one of the 2.2k resistors, or use 3904/3906 transistors instead of those that are spec'd. There's more info in this thread.
-Jim
Pehr
PostPosted: Sat Dec 10, 2011 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems that I only have one filter of three that is not working. The one I previously thought was broken just has some extra resonance Very Happy
I've chaqnged all the transistors to BC-types now, and now it's not working at all.
weird
must be a solder joint or something...
YouTube channel
flickr photostream
Abby Normal
PostPosted: Sat Dec 10, 2011 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Pehr. if you went from the transistor "2n" type to "BC" type, the pinout is reversed between them. You might want to check the datasheet for the exact transistor that you're using for the correct pinout.
Pehr
PostPosted: Mon Dec 12, 2011 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, double checked with the datasheet to be sure. For bc the new layout is actually ok. It is 390x that should be reversed.
YouTube channel
flickr photostream
