Troubleshooting a CGS75 - Voltage-Controlled Slope..
Page 1 of 1 [4 Posts]
MC1495
PostPosted: Sun Dec 25, 2011 11:35 pm    Post subject: Troubleshooting a CGS75 - Voltage-Controlled Slope..
Subject description: Troubleshooting a CGS75 - Voltage-Controlled Slope..
Currently attempting to build the CGS75 from scratch (no PCB) - and running into a little bit of difficulty. Obviously, this is a minefield - but maybe I can explain the problem sufficiently to merit suggestions.
There seems to be a lot that is hinged on the PNP/NPN differential pairs - specifically in the "Exponential 1v/oct" that is attached to the bases of the bottom NPN and PNP.
With the voltage divider attached to the bases, I get short blips - and if I adjust the Rise/Fall CVs, eventually I get to a point where the Envelope (and LED) is sticks at varying voltages after being triggered. Without the voltage divider, I seem to be able to effectively control the "Rise", but have no control of the "Fall."
I'm assuming this potentially has some relationship to the LM3900 - which is ideally configured to control the positive- or negative-going slope, depending on a threshold?
Any advice would be greatly appreciated!
Mongo1
PostPosted: Tue Dec 27, 2011 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi MC,
I haven't built the VCS, but I did build the DUSG which is similar. With the complexity of these boards I would really suggest buying the PCB from Ken. There's an awful lot that can go wrong, and isolating is going to be very difficult.
Barring that, I'd suggest posting a photograph of the front and back of your project. That way people can at least see where things stand.
Good Luck -
Gary
MC1495
PostPosted: Tue Dec 27, 2011 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't have a way to photograph this circuit at the moment.
I will say that I just realized I had the input resistors for the "In" stage arranged incorrectly and that does seem to fix, or at least "change" the problem.
Mongo1
PostPosted: Tue Dec 27, 2011 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That's good news!
Niio2
