Is it safe to create a feedback loop using external in
Page 1 of 1 [4 Posts]
Astral
PostPosted: Thu Dec 22, 2011 12:37 am    Post subject: Is it safe to create a feedback loop using external in Reply with quote  Mark this post and the followings unread
I got this little monotron analog micro synth. You can aux in a signal and process it. I was thinking of feeding it the andromeda headphone out, then the monotron out to the andromeda external in.
Will this kind of feedback loop fry anything?
Mefistophelees
PostPosted: Thu Dec 22, 2011 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
It *should* be OK providing you keep the level going into the A6 in check, Be careful of resonance settings.
Feedback loops like that can create some very interesting sounds. I did the same with an MS-20 and a Micromoog and the bass was nothing short of awesome.
http://soundcloud.com/Mefistophelees
sunny pedaal
Audio files: 12
PostPosted: Mon Dec 26, 2011 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
officially it should be possible.
i did it once, could replace the aux board afterwards.
would really want some info from others on how they did it, before i'll try it again.
anybody had more and better results ?
CoolColJ
PostPosted: Fri Dec 30, 2011 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
A6 has a feedback knob for this purpose Smile
Niio1
