picotiller
Posted: Wed Dec 28, 2011 12:55 pm Post subject:
BOOTLOADER 1.20.37 |
HI MYBE THISIS WRONG SECTION BUT I HAVE NEED TO HELP ABOUT BOOTLOADER 1.20.37 FOR MY ANDROMEDA A6 WERE I CAN FIND THIS FILE?
TANKS BEST REGARD |
CoolColJ
Posted: Wed Dec 28, 2011 6:34 pm Post subject:
Why do you need it for?
I have copes of the firmware, but not bootloader |
picotiller
Posted: Wed Dec 28, 2011 11:01 pm Post subject:
because i have to try to load new user sound and now the display is frozen with " andromeda a6 "
if i will start with soft button 2 or 3 the machine will start normally
i have try to reinstall software 1.42 from official site and that's ok
boot loader is 1.20.37 and i see it on display but defect remain
i have try to reset sotf and hard but nothing to do
im afraid that bootloader is corrupted
i have founded the bootloader version 1.20.31 but i don't know if it work with firmware 1.42
please help me i know that boot loader can be saved on pc between midiox or similar program form andromeda in syx can you try? |
soundwave106
Joined: Nov 24, 2004 Posts: 309 Location: Elmo's Mud Wrestling Club
Posted: Thu Dec 29, 2011 7:22 am Post subject:
Re: BOOTLOADER 1.20.37 |
| picotiller wrote: | because i have to try to load new user sound and now the display is frozen with " andromeda a6 "
Actually, that sounds more like a corrupt patch? Try holding soft button 1 while powering up and see what happens. (This turns on the synth with the initialized patch loaded instead of what is stored on the card.)
I'm surprised that after a soft button 3 (reset user RAM) the synth wouldn't function normally, but probably the RAM reset doesn't affect the card data (never tried it...) |
Shreddie
Posted: Thu Dec 29, 2011 2:04 pm Post subject:
As I recall, the bootloader can't be updated by the user. It's an internal bit of software that can only be updated by sending the Andy back to Alesis and letting them re-flash the chips I think.
It's either a corrupted patch or dodgy firmware. If you want to update the firmware (OS v1.40.12), you can find it in the docs and downloads section on this page. The OS update instructions are on that page too. |
tmste
Posted: Fri Dec 30, 2011 12:53 am Post subject:
bootloader |
"As I recall, the bootloader can't be updated by the user. It's an internal bit of software that can only be updated by sending the Andy back to Alesis and letting them re-flash the chips I think. "
Are you shure?
In the service manual talks about updating it via Sysex. there's a dedicated soft button on startup to do it.. |
CoolColJ
Posted: Fri Dec 30, 2011 7:11 pm Post subject:
Can't see how the bootloader can be corrupt. If it was, your A6 wouldn't turn on at all. It's what boots up the firmware
Looks like a corrupt patch or maybe some of the cables aren't seated properly inside? |
Shreddie
Posted: Sat Dec 31, 2011 12:39 am Post subject:
Re: bootloader |
| tmste wrote: | "As I recall, the bootloader can't be updated by the user. It's an internal bit of software that can only be updated by sending the Andy back to Alesis and letting them re-flash the chips I think. "
Are you shure?
I did say "I think" so no, I'm not 100% sure... But I do recall reading or hearing that it can't be user updated... Then again, I may be thinking of another of my synths. |
