metal_head_82
Mongo1
Posted: Tue Oct 11, 2011 12:18 pm Post subject:
Hi Hendrik - that looks pretty neat!
I'm a little unclear on the circuit though. What is the function of the diode in the feedback path of the opamp?
Thanks
Gary |
metal_head_82
Posted: Wed Oct 12, 2011 1:32 am Post subject:
Hey Gary,
the Diode sets the charge time of the cap to zero and therefore generating the sawtooth.
The discharge time of the cap is then determined by by Rce of the transistor which changes with the voltage present at its base.
You could exchange the CV-input section including the transistor with a pot connected to ground. Altering the pot would have the same effect on the pitch.
Basically this in an op amp version of a schmitt trigger oscillator.
Hope this helped a little...
Hendrik _________________ "I don't care much about music. What I like is sounds." |
oryxs
Posted: Tue Nov 08, 2011 3:10 pm Post subject:
| this is great. i'm a big fan forgoing stability for the sake of simplicity in module designes. i'd love to see a saw to tri converter for this, as well as an LFO. have you had any luck patching a few of these together with one in the lfo range? also, something i've been scouring the web for with little success is a simple VCO with only discrete transistors (no op amps). maybe you could lend a hand in designing something like this? |
Mongo1
Posted: Tue Nov 08, 2011 3:44 pm Post subject:
| Quote: | | also, something i've been scouring the web for with little success is a simple VCO with only discrete transistors (no op amps). maybe you could lend a hand in designing something like this? |
That shouldn't be all that hard to do. There are tons of transistor oscillators in existence. If you replace the 'R' that controls the frequency with an FET or perhaps a vactrol, you should be able to do it. But what do you gain by doing that? Opamps are pretty darned handy.
One other thought - look for schematics for vintage Korg synths. They used to use a lot of transistors in their designs. You might find something useful there.
Gary |
willi
Joined: Oct 20, 2008 Posts: 13 Location: Portland, Oregon
Posted: Thu Nov 10, 2011 6:58 am Post subject:
Opamps are great, but for me, discrete circuits might be easier to understand at a fundamental level. Nice circuit, maybe I will build it when I have a chance!  |
oldcrow
Joined: Sep 24, 2008 Posts: 21 Location: Chicago, IL USA
Posted: Tue Dec 20, 2011 7:13 pm Post subject:
| Mongo1 wrote: | One other thought - look for schematics for vintage Korg synths. They used to use a lot of transistors in their designs. You might find something useful there.
Gary |
Korg liked using a thyristor VCO circuit. I used a modified version of their VCO for the 2nd VCO bank for my Polysix. I added sync I/O, detune, etc. This was in 1996, so I'd have to find the documents on an old hard disk image.
Crow
/**/ _________________ http://www.last.fm/music/Scott+Rider |
umschmitt
Posted: Fri Dec 30, 2011 9:35 am Post subject:
Hey. Is it me, or shouldn't the CV transistor have emitter and collector swapped ? Or does this resistance thing work also with collector at a lower voltage than emitter ? Just asking, I'm pretty ignorant.
(ok I should just try it myself) _________________ ::U::N::S::C::H::N::E::L::L:: |
umschmitt
metal_head_82
Posted: Wed Jan 04, 2012 4:40 am Post subject:
Yes, it can!
BUT you are using it as some sort of FM.
If you want hardsync you should connect the pulse-out of the first vco via a diode and a switch to the diode at the opamp's output of the second VCO.
(Hope this is clear enough - else I'll try to put a schematic online)
I've done this in the vco I'm currently working on. It's based on this design and has FM and hardsync. It's working pretty well BUT the expo converter gives me a headache.
Hope I could help you.
Cheers _________________ "I don't care much about music. What I like is sounds." |
umschmitt
Posted: Wed Jan 04, 2012 5:14 am Post subject:
Yep. I forgot the diode ! And a switch ! Oh well I was nearly at it. But with the switch put as you explain, wouldn't osc#2 just reflect osc#1's frequency ? Hardsync as I understand it would be letting osc#2 live its own frequency life AND discharge its capacitor at osc#1's frequency… Anyway it was simply an idea I had while seeing your design, I'm not trying it yet. The whole thing would make quite a compact double VCO though !
Good luck in your researches ! _________________ ::U::N::S::C::H::N::E::L::L:: |
metal_head_82
Posted: Wed Jan 04, 2012 6:22 am Post subject:
Sync - in this case hardsync - means that one osc restarts the cycle of another osc everytime its own cycle restarts. In this case that means that you need to set the output to high level and let the cap discharge - thus forming a saw.
But you could also discharge the cap. But the way you did it you simply set the CV with every pulse to the highest possible value => FM
But this sort of FM could sound very interesting - I would like to hear a sample of that
Keep up that great work and - in the words of Ray Wilson - stay ingenious! _________________ "I don't care much about music. What I like is sounds." |
umschmitt
Posted: Wed Jan 04, 2012 7:55 am Post subject:
Ok thanks. My naive idea was to have the pulse to suddenly lower the transistor's resistance, thus discharging the cap enough to allow the comparator to restart a cycle. Fairly complicated indeed. And doesn't work, then…
For the moment, I'll stay un-genius, thanks ! _________________ ::U::N::S::C::H::N::E::L::L:: |
metal_head_82
Posted: Mon Jan 09, 2012 1:11 am Post subject:
While searching the forums for a nice and simple expo converter, I stumbled across a thread by synthmonger. He basically did the same thing as I did BUT he used a 40106 ic... It's the same thing but he uses schmitt triggers and I use an op amp as schmitt trigger... funny thing...
Here's the thread: http://electro-music.com/forum/topic-28799-0.html&postdays=0&postorder=asc&highlight=40106+vco _________________ "I don't care much about music. What I like is sounds." |
synthesist
Posted: Sun Feb 26, 2012 9:07 am Post subject:
hey hendrik,
thanks for the simple circuit. I didtn build it yet because I am more interested in a single supply lfo that outputs triangle, ramp or sawtooth.
But isnt it possible to use your circuit as a lfo? I mean is there a way to get a lower range out?
This would be double sick - cause then you would already have a VC-controlled LFO.
Xonrad |
metal_head_82
Posted: Sun Feb 26, 2012 12:32 pm Post subject:
You could raise the cap value to a higher value, e.g. 1uF. This should work as well. But you have to keep in mind that the output of this circuit has DC offset. So instead of using a transistor for buffering you should use an opamp to add some gain and remove the offset.
I'll have to update my initial post as some values aren't correct. But basically this will also work as LFO with saw output. With a total of 3 opamps you could get saw and square/pulse.
I'll add the "advanced" version as soon as I have the time AND the schemaics finished. _________________ "I don't care much about music. What I like is sounds." |
garcho
Posted: Sun Sep 09, 2012 9:39 pm Post subject:
BUMP! nice one Metal Head, hope you update us on this _________________ "The life of a repo man is always intense." |
Tomoroh Hidari
JL
Adolf Christus
Posted: Sun May 05, 2013 12:53 pm Post subject:
man, that's the most satisfying piece of circuit, I ever found.
A sawtooth vco for ~ 1€ and it worked fine on breadboard.
Just wanted to tell that you really made me happy THANK YOU!
I'm pretty new to electronics, built my first 40106 schmitt trigger multivibrator in november 2012 :DDD
So if I feed the sawtooth output into the inverting input of an opamp and
e.g. a triangle lfo voltage into the non-inverting input, I get a pwm square/pulse wave? Is it really that easy? |
metal_head_82
Posted: Thu May 09, 2013 7:47 am Post subject:
In principle yes.
It's a basic Comparator.
The output is high as long as the level of the saw is above the threshold (the level of your modulation signal). If you change the threshold voltage you change the pulsewidth.
I hope I explained it right. You should check out the following site:
http://falstad.com/circuit
This is a very cool realtime circuit simulator with scopes. So you can check if your ideas work. But beware - it uses idealized components...
But definately worth a try to evaluate your ideas (the schematic obove is made from a screenshot of that simulator ) _________________ "I don't care much about music. What I like is sounds." |
Adolf Christus
Posted: Thu May 09, 2013 4:09 pm Post subject:
Yaay! this is great. much better than the spice simulators for my purposes
worked on the falstad sim. But I should buffer it with an op amp
as you said to remove the dc offset.
breadboarded three of them a few days ago FAAT!
I would like to make them respond to a common control voltage.
got nice results with simply splitting the CV but only about half an octave
with loose tuning  |
