HexInverter
Posted: Fri Dec 30, 2011 12:31 am Post subject:
| skylab76 wrote: | Got my kit right before xmas day and built it with ease. The drill template worked the first time without any filing. It's the blackest module in my cabinet. None more black:
Hex, awesome product and the build docs are superb. I'm going to get another full kit as soon the wake of xmas clears.  |
Awesome! So glad to hear it worked out for you
It looks like you're using it exactly the way it's intended -- a super simple, no frills voltage source! _________________ hexinverter.net -- Shop DIY projects and modules for modular synthesis
sympleSEQ -- the simple to build analog step-sequencer
seqSQUARED -- the Analogue Pattern Generator
--> Put yourself on the hexinverter.net mailing list to be notified when in stock! |
diablojoy
Joined: Sep 07, 2008 Posts: 737 Location: melbourne australia
HexInverter
Posted: Fri Dec 30, 2011 11:02 pm Post subject:
| diablojoy wrote: | finished drilling the front panel
for my not so SympleSEQ64
a few more minor changes
now if only the kits would show up
should be any day now i hope
oh well still have a long way to go
anyways |
Wooooooweeeee! Looks great  _________________ hexinverter.net -- Shop DIY projects and modules for modular synthesis
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
Posted: Sat Dec 31, 2011 7:05 pm Post subject:
diablojoy...you know, of course, that you are an maniac, yeah?
F-ing outstanding (in a very OCD way)!
You make me feel like my own crazy scheme is so tame.  _________________ Looking for a certain ratio since 1978 |
diablojoy
Posted: Sun Jan 01, 2012 1:20 am Post subject:
thanks guys really nice that you should say such things
now if only everything plays together as it should
this will be a most wonderfull sequencer
I added a 2nd main gate out [thats the odd jack added to the last column]
just above that is now a 12 throw rotary switch to select various gates
for that output from the 8 sequencer columns via a diode matrix.
A very last minute change as i originally intended a pot to go there for
another function that didnt work out, ha so much for evil genius
of course it would have been better to have 8 on/off switches for that
but i had already drilled for a pot and now lacked the necessary panel space, so diode matrix and 12 way switch it is.
I also have a second main cv output to go with that gate output but with an added switchable offset
-5 to +5 octaves and 0 to +11 semitones
nice to be able to do that from the sequencer
feature creep always seems to become a little rampant whenever i build
anything  _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
HexInverter
Posted: Wed Jan 04, 2012 5:21 pm Post subject:
| diablojoy wrote: | thanks guys really nice that you should say such things
anything  |
Wow, that looks like some project you've got going! Definitely awesome to see this develop  _________________ hexinverter.net -- Shop DIY projects and modules for modular synthesis
Paradigm X
Joined: Feb 15, 2011 Posts: 254 Location: Null and void
Posted: Thu Jan 05, 2012 3:43 am Post subject:
Blimey!
Very neat drilling! My first attempt (at something else!) was far wonkier!
Going to be amazing when its done. |
diablojoy
Posted: Thu Jan 05, 2012 6:13 pm Post subject:
Matthias
I always do an FPD drawing for laying out panels first
though in this particular case i used the drill templates
for drilling the sequencer positions and my own FPD drawing
for all the add ons
if i get my kits before you , so i can do a double check
i may have an FPD i can send you [there is a very small discrepancy between my workings out and the actual drill template measurements ]
not enough to be a huge concern but enough that i woudnt want to pass it on before checking. _________________ In an infinite universe one might very well
rosch
Posted: Mon Jan 09, 2012 11:23 am Post subject:
got my boards today, i had them waiting at customs for a week already, ha.
looks fine, should be easy build!
thanks hex |
Mongo1
Posted: Mon Jan 09, 2012 11:34 am Post subject:
| Quote: | got my boards today, i had them waiting at customs for a week already, ha.
looks fine, should be easy build! |
That gives me hope- I was theorizing that mine were caught on a ice floe somewhere, being eyed by a hungry polar bear. Hopefully it's just a customs issue.
Gary |
Paradigm X
Posted: Mon Jan 09, 2012 12:23 pm Post subject:
yeah mine arrived today, nic eone hex !
rosch
Posted: Mon Jan 09, 2012 4:39 pm Post subject:
yes i got a notice from "post" that a package had been handed over to customs because there was no bill included on the outside. it was about a week ago but i made it there just today.
btw i must have been one of the last guys who got it sent, it was well after the whole indiegogo thing. |
Mongo1
Posted: Mon Jan 09, 2012 5:23 pm Post subject:
Yippee!!! The ice floe melted, the Polar Bears swam away, and my sequencers showed up in the mail today.
Can't wait to build these guys!!!!
Thanks
Gary |
Posted: Thu Jan 12, 2012 1:25 pm Post subject:
today is the day: PCBs/kits arrived save and sound
now to the frontpanels.
i decided to do a 6U/19'' panel, with 4x symplseq's, two dividers, two seqswitches, and a mixer. some multiples too. will have to ponder about the mixer though (matrix?).
it will be mostly modular, so i have all the freedom.
BTW today i tried my inverting divider and the seqswitch, and have been able to create 4x 8 steps in series (to link the sympleseq's in series): 12345678-12345678-12345678-12345678,
and running the seqswitch at the same speed as the clock, to step thru the 4 sequencers 1st steps, then the 2nd, then the 3rd and so forth:1111-2222-3333-4444-5555-6666-7777-8888.
with two sets of divider/seqswitches/multiples and a common mixer for all 4 seq's i could create rather complex structures, i believe.
@diablojoy: did you try that? you suggested to have double triggers due to the propagation time of the CMOS? _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Mongo1
Posted: Thu Jan 12, 2012 2:17 pm Post subject:
Hi Fonik -
I'm interested in some sort of clock controller and related stuff. I just ordered a Yusynth clock divider, but it seems like there could be a lot more interesting things possible....
Gary |
emdot_ambient
Posted: Thu Jan 12, 2012 4:02 pm Post subject:
| fonik wrote: | BTW today i tried my inverting divider and the seqswitch, and have been able to create 4x 8 steps in series (to link the sympleseq's in series): 12345678-12345678-12345678-12345678,
and running the seqswitch at the same speed as the clock, to step thru the 4 sequencers 1st steps, then the 2nd, then the 3rd and so forth:1111-2222-3333-4444-5555-6666-7777-8888. |
Excellent to hear!
I'm trying to figure out a way to set up 4 sympleSEQs as a matrix sequencer.
So if Seq1 is set to play 4 steps, Seq2 is set to play 6 steps, Seq3 is set to play 2 steps and Seq4 is set to play 8 steps, you'd end up with this 20 step pattern: 1234-123456-12-12345678.
Having a hard time trying to figure out how to do that. Thought I had it figured out a couple times, but none of my schemes work in the end.  _________________ Looking for a certain ratio since 1978 |
diablojoy
Posted: Thu Jan 12, 2012 5:01 pm Post subject:
gotta love feature creep and so it begins
havent tried anything yet in real life so to speak
still waiting for sequencer kits to show
so its all in my head but quietly confident
i should be getting my prototype dual 8 way sequential switch back
from the board house early next week
and I will be using a CGS VC divider to clock it
so odd patterns should be available | Quote: | | So if Seq1 is set to play 4 steps, Seq2 is set to play 6 steps, Seq3 is set to play 2 steps and Seq4 is set to play 8 steps, you'd end up with this 20 step pattern: 1234-123456-12-12345678 | I should be able to do this with a CV in real time
in theory
the concern i had with propagation delays i resolved by delaying the switched clock pulses in relation to the clock pulses sent to the 4017[ 4 sections of a cd40106 in series giving roughly 240nano seconds of delay ]
controlling the sequential switch as the DG412 switching time could allow
enough of a clock pulse through to step each SympleSEQ twice before
actually switching to the next sequential switch step
hope that makes sense _________________ In an infinite universe one might very well
diablojoy
Posted: Thu Jan 12, 2012 5:36 pm Post subject:
oh also added yet another jack that i almost forgot
a reset jack for the divider yet more mayhem
now at 74 x 1/4 inch jacks i think that might be some sort of record for
one panel that isnt just a patch bay Patch city  _________________ In an infinite universe one might very well
