Transistor gate control?
Page 1 of 1 [4 Posts]
blackdiscoball
PostPosted: Wed Jan 11, 2012 12:05 pm    Post subject: Transistor gate control? Reply with quote  Mark this post and the followings unread
So I've got a simple osc that I would like to control the gate of. I was thinking there should be a way to hook a transistor to one of the outs to use as a simple vca? Im basically just wanting to use a gate signal to have it either sound when voltage is applied, or no sound, when no voltage is applied. Anyone have a simple circuit that could do this?
Draal
PostPosted: Wed Jan 11, 2012 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tend to keep a few 4093's specifically for this purpose. Scroll down to the NAND osc. section at this great site: http://www.vidiotsquad.com/synth-stuff/simple-oscillators/
I'm sure someone here will help ya regarding transistors, I use the 4093 cuz it's less stuff I need to keep track of on my builds.
Zontar Prevails!
Draal
PostPosted: Wed Jan 11, 2012 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You want transistor gate control? Alright..here ya go!
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/trangate.html
Dug up from deep in the bowels of my cluttered "saved for later" folders Laughing !
Or check this out:
This snippet is from http://www.robthefiddler.com/electronics-audio-diy/circuit-experiments/big-johnson-signal-generator/
Here he's using a trannie to gate in time with the clock.
 Filesize:  80.92 KB
 Viewed:  1164 Time(s)
Zontar Prevails!
sizone
Audio files: 48
PostPosted: Fri Jan 13, 2012 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
NPN transistor.
Input goes to the emitter, switch goes to the base, output goes to the collector.
http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
