PmCimini
Joined: Mar 23, 2008 Posts: 11 Location: Palo Alto, CA
Posted: Tue Jan 17, 2012 10:41 am Post subject:
Single Buss 1V/Octave Keyboard - Need Help! |
Here is the deal: I am trying to connect a keyboard I salvaged from an old Casio, but it makes contact with a rubber switch. The problem is that the conductive rubber has a rather high resistance, so I don't think this would be effective in this circuit.
Is there anything I can do in order to make this work? I don't really care about component count or anything. I thought about using some CD4066 in order to control the actual circuit, but the datasheet says it has a Ron of about 80 ohms, and I think that is also high, comparing to the 100 ohm resistors...
Please help me, I need to get this pcb sent by friday, but I am actually out of ideas that could work in this circuit.... Thanks
(on the top right of the schematic, there are the 100 ohm resistors and switches)
Mongo1
Posted: Tue Jan 17, 2012 1:43 pm Post subject:
I know you won't want to hear this, but I've seen a number of people install magnetic read switches in keyboards like that, specifically because of the problem you're having.
Other than that I'm not sure what you can do.
Gary |
Mongo1
Posted: Tue Jan 17, 2012 1:47 pm Post subject:
One other suggestion -
Take a look at Craigslist and see if you can find an old Organ. I bought one for $20 and am using the Keyboard from it - it works great - nice clean contacts and no hassles.
Gary |
PmCimini
Posted: Tue Jan 17, 2012 2:45 pm Post subject:
The thing is that I already have the whole layout laid down and it's based on the keyboard theat I have... I could use a reed switch, but I wanted to know if there is a way to do this electronically... |
Mongo1
Posted: Tue Jan 17, 2012 3:00 pm Post subject:
Do you have any idea how much resistance we're talking about? The keyboard on this MFOS is basically just a big voltage divider. I guess the keys in your case end up looking like large value resistors.
I'm wondering if you could put a similar value in the feedback loop of U2-A to compensate for it? |
PmCimini
Posted: Tue Jan 17, 2012 3:37 pm Post subject:
It is about 1kohm... do you think it would work if I put a buffer before U2A? |
Mongo1
Posted: Tue Jan 17, 2012 4:10 pm Post subject:
Well, U2A and U2B really are buffers, so I don't think that would really fix anything. Have you been able to look at what's really happening with a scope?
Gary |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Tue Jan 17, 2012 11:35 pm Post subject:
with this cct i am fairly sure the resistance value is not that important
what is vital is the that the resistances have as little variation between them as possible ie they are all closely matched, within 1% is ok better if within 0.1%
with a keyboard such as the one you are using that is impossible
to accomplish as with those type of contacts the resistance varies considerably
take a look at rays matrix scanning keyboard cct, it is a far better choice for the keyboard you have. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
PmCimini
Posted: Wed Jan 18, 2012 12:37 am Post subject:
I just checked the matrix scanning circuit and it seems very fine! Thank you a lot. However, if I use high-resistance switches (about 1kohm), are there any modifications necessary? |
diablojoy
Posted: Wed Jan 18, 2012 5:48 pm Post subject:
I wouldnt think you would need to do any mods
as the keys are simply polled as to there state on or off
the correct voltage level to output is decided by the cct independently
of the switches resistance
but ray wilson would be the better person to ask here
try sending him an email _________________ In an infinite universe one might very well
adhdboy
Posted: Sat Feb 04, 2012 9:25 am Post subject:
Resistive switches Subject description: C5 May need reduced if you use resistive switches. |
C5 is at the end of the chain. The matrix is driven through R5 1K as it is just fine. If it works you're golden if not try reducing C5 to 22pF or 10pF.
Good luck _________________ There 10 kinds of people in this world that understand binary those that do and those that don't. |
adhdboy
Posted: Sat Feb 04, 2012 9:29 am Post subject:
Single Buss Keyboard may work with low R switches too Subject description: 1K to 2K resitance in the switches may actually be alright. |
The design may tolerate up to 1 or 2 K of switch resistance without degrading performance. The voltage from the divider is dropped on 10M so you should be getting very close to the correct voltages regardless of a bit of resistance. _________________ There 10 kinds of people in this world that understand binary those that do and those that don't. |
